Mems Mic over I2S_ Calculate sound level (db) out of FFT values
Baseladams
New member
i connecting a mems mic to teensy over I2S and getting 20 fft values after each measurement. I have a very basic question :D. How to calculate the sound level in db out of the fft values?
Thanks, Basel
P.s. I am using following code:
AudioInputI2S input;
AudioAnalyzeFFT1024 fft;
AudioConnection connection(input, 0, fft, 0);
AudioMemory(50);
float n;
int i;
if(fft.available()){
// each time new FFT data is available
// print it all to the Arduino Serial Monitor
//Serial.print("FFT: ");
for (i = 0; i < 20; i++) {
n = fft.read(i);
if (n >= 0.0002) {
Serial.print(n*1000, 3);
Serial.print(" ");
Serial.print(" -- "); // don't print "0.00"
Serial.println(sum);
	AudioMemory(50);
	float n;
	int i;
	if (fft.available()) {
			n = fft.read(i);
			if (n >= 0.0002) {
				Serial.print(n * 1000, 3);
				Serial.print(" ");
			else {
In future could you enclose your posted code between code tags using the # button, I think you will agree that it makes your code much easier to understand. This will make it more likely that someone will be able to help you.
Unfortunately I have no experience using the Audio card so I do not fall into that group.
This is what I am using to get to dB after the FFT has been calculated (note I am using a floating point FFT here)
 for(j=0;j<samples/2;j++){
      vReal[j] /= (double)samples/2.0; // bring back to original units
      vReal[j] = 20.0*log10f(vReal[j]);             // convert to dB
