Results 1 to 8 of 8
Thread: Teensyduino 1.57 Beta #5
    Administrator Paul's Avatar
    Oct 2012
    437
    Here is a fifth beta test for Teensyduino 1.57.
    Linux 32 bit:
    https://www.pjrc.com/teensy/td_157-b...nstall.linux32
    Linux 64 bit:
    https://www.pjrc.com/teensy/td_157-b...nstall.linux64
    Linux ARM:
    https://www.pjrc.com/teensy/td_157-b...stall.linuxarm
    Linux ARM64:
    https://www.pjrc.com/teensy/td_157-b...l.linuxaarch64
    MacOS (Catalina to Monterey)
    https://www.pjrc.com/teensy/td_157-b...S_Catalina.zip
    Old MacOS (Lion to Mojave)
    https://www.pjrc.com/teensy/td_157-b...inoInstall.dmg
    Windows:
    https://www.pjrc.com/teensy/td_157-b...inoInstall.exe
    Arduino IDE 2.0.0-rc9 (all systems):
    https://www.pjrc.com/teensy/td_156/p...nsy_index.json
    Changes since Teensyduino 1.56-beta4:
    Add signature to teensy_secure.exe on Windows
    Fix bug affecting oldest (maybe beta) Lockable Teensy
    10,975
    Download on W10 both versions (1.8.19 and IDE2 RC9)
    Confirmed both teensy_secure.exe had the signed page.
    Tested on Original beta locked T4, T4.1 and MMOD - and they all uploaded correctly, no longer Christmas tree lights
    Tested on most recent locked board and it works as well.
    10,975
    Installed on RPI4 running Ubuntu 64 bit... 1.8.19
    Tried building Blink for T4.1 locked...
    Build ran, but teensy app said, needs EHEX file...
    Also installed RC9 on the RPI4... Again build ran, but Teensy app, again said EHEX file needed for locked Teensy
    26,814
    Did you copy your key.pem file to that Raspberry Pi? The teensy_secure program needs your key to create the .ehex file.
    10,975
    Maybe not... Will check
    Yes that was it
    16,366
    Installed 1.8.19 TD 1.57b5 on Win 11 no problem.
    Ran with latest two T_4.1's I got and both working well ... hopefully the same after soldering ... found a pack of 3 PSRAM's ... will see what I have for a FLASH and pins ...
    Yes that was it
    I sent that guess in email before visiting the forum this AM
    16,366
    Updated IDE 2 RC9 Win 10 laptop to TD 1.57b5 and it worked to update and program the last T_4.1 I got.
    Both T_4.1's soldered up with pins - and still working!
    Submitted Certified Teensy_Secure to MalwareBytes support to get it whitelisted as safe.
    10,975
    Quick update: I downloaded this both ways to a MAC and it worked both with locked T4.1 using Teensyduino.
    and unlocked T4.1 on IDE2 RC9
