Hi All,
I am using Quad Timers to measure an external PWM signal and I was wondering if anyone could tell me the difference between attaching a Interrupt Service routine using
or using
within the following setup function
In this case, do I really need to have this below?
Thank You!
attachInterrupt(digitalPinToInterrupt(11), ISR_TMR1_CH2, FALLING);
or using
attachInterruptVector(IRQ_QTIMER1,Timer_ISR);
NVIC_ENABLE_IRQ(IRQ_QTIMER1);
unsigned long t1,t2;
unsigned long TestValue;
Setup_TMR1_CH2();
t1 = millis();
t2 = t1;
t1 = millis();
if((t1-t2) >= 500)
Serial.println(TestValue);
void Setup_TMR1_CH2()
CCM_CCGR6 |= CCM_CCGR6_QTIMER1(CCM_CCGR_ON);
TMR1_CTRL2 = 0; // stop
TMR1_LOAD2 = 0;
TMR1_CSCTRL2 = 0;
TMR1_LOAD2 = 0; // start val after compare
TMR1_COMP12 = 0x00FF; // count up to this val, interrupt, and start again
TMR1_COMP22 = 0x000F;
TMR1_CMPLD12 = 0x0000;
TMR1_SCTRL2 = TMR_SCTRL_CAPTURE_MODE(1); //rising
TMR1_SCTRL2 |= TMR_SCTRL_TOFIE | TMR_SCTRL_TCFIE; // enable interrupts
TMR1_CSCTRL2 |= TMR_CSCTRL_TCF1EN; // enable interrupt
TMR1_CTRL2 |= TMR_CTRL_CM(1) | TMR_CTRL_SCS(2) | TMR_CTRL_LENGTH ; // prescale
//*(portConfigRegister(11)) = 1; // ALT 1
__asm volatile ("dsb");
void Timer_ISR()
TestValue = TMR1_CNTR2;
TMR1_CNTR2 = 0;
asm volatile ("dsb"); // wait for clear memory barrier
Thank You!
