I have a Teensy 3.6 and BMP280 barometric pressure sensor (datasheet: https://www.bosch-sensortec.com/media/boschsensortec/downloads/datasheets/bst-bmp280-ds001.pdf)
I only want to read temperature for now. But my code has a bug I couldn't find.
I use <i2c_t3.h> (https://github.com/nox771/i2c_t3) instead of <Wire.h>.
Here is the code:
And the output:
And schematic
I have several questions:
1) Is there a problem with reading and writing because I couldn't understand that part in datasheet. Especially RW bit, it's address is not provided how am I going to write it? Is it an automatic process?
2) As you can see from the output the most unstable byte is raw_temperature.arr[2] among raw_temperature.arr[X] values.
But I assigned raw_temperature.arr[2] as the most significant byte.
Does it mean I made a mistake about assignment indexes or reading?
3) Dig_TX values (trimming values) does not change, is this normal?
4) Dig_T3 has a value much larger than 16 bits what could be the reason?
Note: I know there is a BMP280 library but I want to learn how to use it without it's library.
Thank you in advance.
Here is the code:
#include <i2c_t3.h>
#define SCL_pin 37
#define SDA_pin 38
#define bmp_address 0x76
#define bmp_control_address 0xF4 // ctr_meas in BMP280 datasheet. See chapter 4.2 and 5.2
#define bmp_config_address 0xF5 // config in datasheet. See chapter 4.2 and 4.3.5
union byteArrayToInt32{
byte arr[4];
int32_t integer;
union byteArrayToInt16{
byte arr[2];
int16_t integer;
union byteArrayToUInt16{
byte arr[2];
uint16_t integer;
byte temperature_register_address[3]={0xFA,0xFB,0xFC};
byte dig_T1_register_address[2]={0x88,0x89};//LSB,MSB See chapter 3.12;
byte dig_T2_register_address[2]={0x8A,0x8B};
byte dig_T3_register_address[2]={0x8C,0x8D};
union byteArrayToUInt16 dig_T1;
union byteArrayToInt16 dig_T2, dig_T3;
union byteArrayToInt32 raw_temperature;
int32_t t_fine;
Wire1.begin(I2C_MASTER, 0x00, SCL_pin, SDA_pin); // SCL:37 SDA:38 on Teensy 3.6
Wire1.setDefaultTimeout(10000);
Wire1.beginTransmission(bmp_address);
Wire1.write(bmp_control_address);
Set oversampling rates and operating mode
bmp_control_address (ctrl_meas) is 8 bits
Lets say it is abcdefgh
abc is temperature oversampling rate (chapter 3.3.2)
def is pressure oversampling rate (chapter 3.3.1)
gh is power mode ( chapter 3.6 )
Also see chapter 4.3.4 for ctrl_meas
osrs_t[2:0] Temp / Pressure oversampling | mode[1:0] Mode
000 skipped | 00 sleep mode
001 x1 | 01,10 forced mode
010 x2 | 11 normal mode
011 x4 |
100 x8 |
101,110,111 x16 |
Wire1.write(163); // 101 000 11 = 163. Temperature oversampling x16, pressure skipped, normal mode
Wire1.endTransmission();
Wire1.write(bmp_config_address);
Set standby time, IIR filter coefficent and spi mode
bmp_config_address (config) is 8 bits
abc is standby time in normal mode ( chapter 3.6.3 )
def is time constant of IIR filter (chapter 3.3.3 and 3.5)
g is a read only bit
h is spi mode ( chapter 5.3 )
Also see chapter 4.3.5 for config
t_sb[2:0] Standby time (ms) | (I am not completely sure since) | spi3w_en[0] SPI Mode
000 0.5 | (values were not in the datasheet) | 0 4 Wire
001 62.5 | | 1 3 Wire
010 125 | filter[2:0] Filter coefficent |
011 250 | 000 off |
100 500 | 010 2 |
101 1000 | 011 4 |
110 2000 | 100 8 |
111 4000 | 101,110,111 16 |
Wire1.write(44); // 001 100 00 = 0: Standby time 62.5 ms, filter coefficent 8, 4 wire SPI
Serial.begin(15200);
Serial.println(" DECIMAL ---> BINARY");
Wire1.write(temperature_register_address,3);
Wire1.requestFrom(bmp_address,3);
raw_temperature.arr[3]=0;
raw_temperature.arr[2]=Wire1.read();//msb_t;
raw_temperature.arr[1]=Wire1.read();//lsb_t;
raw_temperature.arr[0]=Wire1.read();//xlsb_t;
showRawTemperature();
Wire1.write(dig_T1_register_address,2);
Wire1.requestFrom(bmp_address,2);
dig_T1.arr[0]=Wire1.read();
dig_T1.arr[1]=Wire1.read();
Wire1.write(dig_T2_register_address,2);
dig_T2.arr[0]=Wire1.read();
dig_T2.arr[1]=Wire1.read();
Wire1.write(dig_T3_register_address,2);
dig_T3.arr[0]=Wire1.read();
dig_T3.arr[1]=Wire1.read();
showDigTs();
Serial.print(compensateTemperature(raw_temperature.integer)/100);
Serial.println(" *C");
Serial.println("########################");
smartDelay(200);
void smartDelay(unsigned int wait_for){
unsigned int beginning=millis();
while(millis()-beginning<wait_for){}
return;
void showRawTemperature(){
Serial.print("raw_temperature.arr[0] : ");
Serial.print(raw_temperature.arr[0]);
Serial.print(" ---> ");
Serial.println(raw_temperature.arr[0],BIN);
Serial.print("raw_temperature.arr[1] : ");
Serial.print(raw_temperature.arr[1]);
Serial.println(raw_temperature.arr[1],BIN);
Serial.print("raw_temperature.arr[2] : ");
Serial.print(raw_temperature.arr[2]);
Serial.println(raw_temperature.arr[2],BIN);
Serial.print("raw_temperature.arr[3] : ");
Serial.print(raw_temperature.arr[3]);
Serial.println(raw_temperature.arr[3],BIN);
Serial.print("raw_temperature.integer: ");
Serial.print(raw_temperature.integer);
Serial.println(raw_temperature.integer,BIN);
void showDigTs(){
Serial.print("Dig_T1: ");
Serial.print(dig_T1.integer);
Serial.println(dig_T1.integer,BIN);
Serial.print("Dig_T2: ");
Serial.print(dig_T2.integer);
Serial.println(dig_T2.integer,BIN);
Serial.print("Dig_T3: ");
Serial.print(dig_T3.integer);
Serial.println(dig_T3.integer,BIN);
//See chapter 3.11.3 for compensation code
int32_t compensateTemperature(int32_t adc_T){
int32_t var1, var2, T;
var1 = ((((adc_T>>3) - ((int32_t)dig_T1.integer<<1))) * ((int32_t)dig_T2.integer))>>11;
var2 = (((((adc_T>>4) - ((int32_t)dig_T1.integer)) * ((adc_T>>4) - ((int32_t)dig_T1.integer))) >>12) * ((int32_t)dig_T3.integer))>>14;
t_fine=var1+var2;
T = (t_fine*5+128)>>8;
return T;
And the output:
DECIMAL ---> BINARY
raw_temperature.arr[0] : 112 ---> 1110000
raw_temperature.arr[1] : 131 ---> 10000011
raw_temperature.arr[2] : 192 ---> 11000000
raw_temperature.arr[3] : 0 ---> 0
raw_temperature.integer: 12616560 ---> 110000001000001101110000
Dig_T1: 28059 ---> 110110110011011
Dig_T2: 26349 ---> 110011011101101
Dig_T3: -1000 ---> 11111111111111111111110000011000
139 *C
raw_temperature.arr[2] : 224 ---> 11100000
raw_temperature.integer: 14713712 ---> 111000001000001101110000
-25 *C
raw_temperature.arr[2] : 16 ---> 10000
raw_temperature.integer: 1082224 ---> 100001000001101110000
194 *C
raw_temperature.arr[2] : 48 ---> 110000
raw_temperature.integer: 3179376 ---> 1100001000001101110000
41 *C
raw_temperature.arr[2] : 64 ---> 1000000
raw_temperature.integer: 4227952 ---> 10000001000001101110000
-41 *C
And schematic
