Results 1 to 4 of 4
Thread: Many (14) COM ports with Teensy 4.1
    Nov 2021
    60
    I am planning to build a system where I have many (14 pcs) esp32 boards connected to one Teensy 4.1. I need a possibility to reprogram each esp32 from Teensy 4.1 on fly (each has the same firmware).
    So, I am expecting to use 8 hardware serial and 6 software serial.
    During programming, it would be very nice to program all esp32 in parallel because the firmware upload takes about 3 minutes at 115200, so, sequential programming of all 14 boards will take about 40 minutes!!!
    During working an average traffic between T4.1 and each esp32 is about 200-500 Bytes/s on both directions and it is unsynchronized, usually each esp32 send its data when ready, and T4.1 acknowledge with some short info for the next set for data processing.
    I am afraid that 6 software serial can work in parallel, I tried to understand how it is implemented in arduino-1.8.19/hardware/teensy/avr/libraries/SoftwareSerial/SoftwareSerial.cpp
    and it seems that it cannot work with many software serial connections in parallel.
    Please, advice me is it possible to handle in the same time 8 hardware serial and 6 software serial at, lets say 115200 so that teensy itself still do other work: several I2C and SPI sensors and some heavy numerical computations will also run on it.
    Thank you!
    26,810
    SoftwareSerial won't work. FlexSerial from Kurt's FlexIO_t4 library is probably your best chance.
    I really don't know if FlexSerial supports 6 ports operating full duplex simultaneously, but this examples has 7 ports transmitting at the same time, while also sending on 7 normal serial ports, which seems like a good sign.
    https://github.com/KurtE/FlexIO_t4/b...ny_streams.ino
    Nov 2021
    60
    Thank you very much, PaulStoffregen, for interesting example.
    AFAIK, receiving on many software serial is the key problem, and I cannot sync my slave esp32 so that they send data at the same time. In the example you mention, it is only sending on 7 non-hardware serial ports...
    Theoretically, I can join all transmitters into one pin, but I need 14 receivers... It is the key problem for me.
    10,974
    Sorry been distracted, trying to get another computer to work...
    Here is a sketch I tried long ago, with just doing output...
    // Test to create multiple Flex Serial output objects and see how they
    // all interact...
    #include <FlexIO_t4.h>
    #include <FlexSerial.h>
    FlexSerial FlexSerials[] = {
      { -1, 2, -1, 0, 0, 0, 0, 0},
      { -1, 3, -1, 0, 0, 0, 1, 1},
      { -1, 4, -1, 0, 0, 0, 2, 2},
      { -1, 5, -1, 0, 0, 0, 3, 3},
      { -1, 10, -1, 0, 0, 1, 1, 1},
      { -1, 11, -1, 0, 0, 1, 2, 2},
      { -1, 12, -1, 0, 0, 1, 3, 3},
      { -1, 38, -1, 0, 0, 2, 0, 0},
      { -1, 39, -1, 0, 0, 2, 1, 1},
      { -1, 40, -1, 0, 0, 2, 2, 2},
      { -1, 41, -1, 0, 0, 2, 3, 3}
    const uint8_t count_flexSerials = sizeof(FlexSerials) / sizeof(FlexSerials[0]);
    Stream *streams[7 + count_flexSerials] = {&Serial1, &Serial2, &Serial3, &Serial4, &Serial5, &Serial6, &Serial7, &Serial8};
    const uint8_t count_streams = sizeof(streams) / sizeof(streams[0]);
    #define BUFFER_SIZE 75
    #define BAUD 115200
    uint8_t buffer[BUFFER_SIZE];
    uint8_t loop_count = 0;
    void outputStr(Stream *pstream, const char *str_buf, uint8_t index) {
      digitalWriteFast(13, HIGH);
      pstream->write(str_buf);
      pstream->print(index, DEC);
      //  pstream->flush();
      digitalWriteFast(13, LOW);
      pinMode(13, OUTPUT);
      pinMode(12, OUTPUT);
      while (!Serial && millis() < 4000);
      delay(250);
      // Lets initialize all of the Hardware Serial ports.
      Serial1.begin(BAUD); outputStr(&Serial1, "Serial", 1); // 0, 1
      Serial2.begin(BAUD); outputStr(&Serial2, "Serial", 2);// 7, 8
      Serial3.begin(BAUD); outputStr(&Serial3, "Serial", 3);// 15, 14
      Serial4.begin(BAUD); outputStr(&Serial4, "Serial", 4);// 16, 17
      Serial5.begin(BAUD); outputStr(&Serial5, "Serial", 5);// 21, 20
      Serial6.begin(BAUD); outputStr(&Serial6, "Serial", 6);// 25, 24
      Serial7.begin(BAUD); outputStr(&Serial7, "Serial", 7);// 28, 29
      Serial8.begin(BAUD); outputStr(&Serial8, "Serial", 8);// 34, 35
      delay(5);
      for (uint8_t i = 0; i < count_flexSerials; i++) {
        Serial.println("\nFlexSerial object begin");
        if (!FlexSerials[i].begin(BAUD)) Serial.println("   *** Failed ***\n");
        streams[8 + i] = &FlexSerials[i];
        outputStr(&FlexSerials[i], "FlexSerial", i);
        delay(5);
      Serial.println("End Setup");
    uint8_t loop_char = 'a';
      loop_count++;
      // maybe first 10 bytes will bee loop count;
      memset(buffer, loop_count, 10);
      for (uint16_t bi = 10; bi < sizeof(buffer); bi++) buffer[bi] = bi & 0xff;
      uint16_t buffer_indexes[count_streams] = {0};
      uint32_t start_time = millis();
      bool not_done_yet = true;
      while (not_done_yet) {
        digitalWriteFast(12, HIGH);
        not_done_yet = false; // assume we are done.
        for (uint8_t serial_index = 0; serial_index < count_streams; serial_index++) {
          if (buffer_indexes[serial_index] < sizeof(buffer)) {
            uint16_t cbOutput = sizeof(buffer) - buffer_indexes[serial_index];
            uint16_t cbAvailForWrite = streams[serial_index]->availableForWrite();
            if (cbAvailForWrite < cbOutput) {
              cbOutput = cbAvailForWrite;
            streams[serial_index]->write(&buffer[buffer_indexes[serial_index]], cbOutput);
            buffer_indexes[serial_index] += cbOutput;
        //delayMicroseconds(10);
        digitalWriteFast(12, LOW);
      // Now lets wait until all of them finish their output
        streams[serial_index]->flush();
      Serial.printf("loop %u time: %u\n", loop_count, millis() - start_time);
      delay(250);
      Serial.printf("end F1:%x %x F2:%x %x F3: %x %x\n", FLEXIO1_SHIFTSTAT, FLEXIO1_SHIFTSIEN,
                    FLEXIO2_SHIFTSTAT, FLEXIO2_SHIFTSIEN, FLEXIO3_SHIFTSTAT, FLEXIO3_SHIFTSIEN );
      Serial.printf("CCM_CDCDR: %x\n", CCM_CDCDR);
      Serial.printf("VERID:%x PARAM:%x CTRL:%x PIN: %x\n", IMXRT_FLEXIO1_S.VERID, IMXRT_FLEXIO1_S.PARAM, IMXRT_FLEXIO1_S.CTRL, IMXRT_FLEXIO1_S.PIN);
      Serial.printf("SHIFTSTAT:%x SHIFTERR=%x TIMSTAT=%x\n", IMXRT_FLEXIO1_S.SHIFTSTAT, IMXRT_FLEXIO1_S.SHIFTERR, IMXRT_FLEXIO1_S.TIMSTAT);
      Serial.printf("SHIFTSIEN:%x SHIFTEIEN=%x TIMIEN=%x\n", IMXRT_FLEXIO1_S.SHIFTSIEN, IMXRT_FLEXIO1_S.SHIFTEIEN, IMXRT_FLEXIO1_S.TIMIEN);
      Serial.printf("SHIFTSDEN:%x SHIFTSTATE=%x\n", IMXRT_FLEXIO1_S.SHIFTSDEN, IMXRT_FLEXIO1_S.SHIFTSTATE);
      Serial.printf("SHIFTCTL:%x %x %x %x\n", IMXRT_FLEXIO1_S.SHIFTCTL[0], IMXRT_FLEXIO1_S.SHIFTCTL[1], IMXRT_FLEXIO1_S.SHIFTCTL[2], IMXRT_FLEXIO1_S.SHIFTCTL[3]);
      Serial.printf("SHIFTCFG:%x %x %x %x\n", IMXRT_FLEXIO1_S.SHIFTCFG[0], IMXRT_FLEXIO1_S.SHIFTCFG[1], IMXRT_FLEXIO1_S.SHIFTCFG[2], IMXRT_FLEXIO1_S.SHIFTCFG[3]);
      Serial.printf("TIMCTL:%x %x %x %x\n", IMXRT_FLEXIO1_S.TIMCTL[0], IMXRT_FLEXIO1_S.TIMCTL[1], IMXRT_FLEXIO1_S.TIMCTL[2], IMXRT_FLEXIO1_S.TIMCTL[3]);
      Serial.printf("TIMCFG:%x %x %x %x\n", IMXRT_FLEXIO1_S.TIMCFG[0], IMXRT_FLEXIO1_S.TIMCFG[1], IMXRT_FLEXIO1_S.TIMCFG[2], IMXRT_FLEXIO1_S.TIMCFG[3]);
      Serial.printf("TIMCMP:%x %x %x %x\n", IMXRT_FLEXIO1_S.TIMCMP[0], IMXRT_FLEXIO1_S.TIMCMP[1], IMXRT_FLEXIO1_S.TIMCMP[2], IMXRT_FLEXIO1_S.TIMCMP[3]);
      // Lets see if there if the user hit anything to tell us to pause
      if (Serial.available()) {
        while (Serial.read() != -1) ;
        Serial.println("Paused enter anything to continue running");
        while (Serial.read() == -1) ;
      delay(250);
