Many (14) COM ports with Teensy 4.1
was-ja
I am planning to build a system where I have many (14 pcs) esp32 boards connected to one Teensy 4.1. I need a possibility to reprogram each esp32 from Teensy 4.1 on fly (each has the same firmware).
So, I am expecting to use 8 hardware serial and 6 software serial.
During programming, it would be very nice to program all esp32 in parallel because the firmware upload takes about 3 minutes at 115200, so, sequential programming of all 14 boards will take about 40 minutes!!!
During working an average traffic between T4.1 and each esp32 is about 200-500 Bytes/s on both directions and it is unsynchronized, usually each esp32 send its data when ready, and T4.1 acknowledge with some short info for the next set for data processing.
I am afraid that 6 software serial can work in parallel, I tried to understand how it is implemented in arduino-1.8.19/hardware/teensy/avr/libraries/SoftwareSerial/SoftwareSerial.cpp
and it seems that it cannot work with many software serial connections in parallel.
Please, advice me is it possible to handle in the same time 8 hardware serial and 6 software serial at, lets say 115200 so that teensy itself still do other work: several I2C and SPI sensors and some heavy numerical computations will also run on it.
Thank you!
Thank you very much, PaulStoffregen, for interesting example.
AFAIK, receiving on many software serial is the key problem, and I cannot sync my slave esp32 so that they send data at the same time. In the example you mention, it is only sending on 7 non-hardware serial ports...
Theoretically, I can join all transmitters into one pin, but I need 14 receivers... It is the key problem for me.
Sorry been distracted, trying to get another computer to work...
Here is a sketch I tried long ago, with just doing output...
// Test to create multiple Flex Serial output objects and see how they
// all interact...
#include <FlexIO_t4.h>
#include <FlexSerial.h>
FlexSerial FlexSerials[] = {
  { -1, 2, -1, 0, 0, 0, 0, 0},
  { -1, 3, -1, 0, 0, 0, 1, 1},
  { -1, 4, -1, 0, 0, 0, 2, 2},
  { -1, 5, -1, 0, 0, 0, 3, 3},
  { -1, 10, -1, 0, 0, 1, 1, 1},
  { -1, 11, -1, 0, 0, 1, 2, 2},
  { -1, 12, -1, 0, 0, 1, 3, 3},
  { -1, 38, -1, 0, 0, 2, 0, 0},
  { -1, 39, -1, 0, 0, 2, 1, 1},
  { -1, 40, -1, 0, 0, 2, 2, 2},
  { -1, 41, -1, 0, 0, 2, 3, 3}
const uint8_t count_flexSerials = sizeof(FlexSerials) / sizeof(FlexSerials[0]);
Stream *streams[7 + count_flexSerials] = {&Serial1, &Serial2, &Serial3, &Serial4, &Serial5, &Serial6, &Serial7, &Serial8};
const uint8_t count_streams = sizeof(streams) / sizeof(streams[0]);
#define BUFFER_SIZE 75
#define BAUD 115200
uint8_t buffer[BUFFER_SIZE];
uint8_t loop_count = 0;
void outputStr(Stream *pstream, const char *str_buf, uint8_t index) {
  digitalWriteFast(13, HIGH);
  pstream->write(str_buf);
  pstream->print(index, DEC);
  //  pstream->flush();
  digitalWriteFast(13, LOW);
  pinMode(13, OUTPUT);
  pinMode(12, OUTPUT);
  while (!Serial && millis() < 4000);
  delay(250);
  // Lets initialize all of the Hardware Serial ports.
  Serial1.begin(BAUD); outputStr(&Serial1, "Serial", 1); // 0, 1
  Serial2.begin(BAUD); outputStr(&Serial2, "Serial", 2);// 7, 8
  Serial3.begin(BAUD); outputStr(&Serial3, "Serial", 3);// 15, 14
  Serial4.begin(BAUD); outputStr(&Serial4, "Serial", 4);// 16, 17
  Serial5.begin(BAUD); outputStr(&Serial5, "Serial", 5);// 21, 20
  Serial6.begin(BAUD); outputStr(&Serial6, "Serial", 6);// 25, 24
  Serial7.begin(BAUD); outputStr(&Serial7, "Serial", 7);// 28, 29
  Serial8.begin(BAUD); outputStr(&Serial8, "Serial", 8);// 34, 35
  delay(5);
  for (uint8_t i = 0; i < count_flexSerials; i++) {
    Serial.println("\nFlexSerial object begin");
    if (!FlexSerials[i].begin(BAUD)) Serial.println("   *** Failed ***\n");
    streams[8 + i] = &FlexSerials[i];
    outputStr(&FlexSerials[i], "FlexSerial", i);
    delay(5);
  Serial.println("End Setup");
uint8_t loop_char = 'a';
  loop_count++;
  // maybe first 10 bytes will bee loop count;
  memset(buffer, loop_count, 10);
  for (uint16_t bi = 10; bi < sizeof(buffer); bi++) buffer[bi] = bi & 0xff;
  uint16_t buffer_indexes[count_streams] = {0};
  uint32_t start_time = millis();
  bool not_done_yet = true;
  while (not_done_yet) {
    digitalWriteFast(12, HIGH);
    not_done_yet = false; // assume we are done.
    for (uint8_t serial_index = 0; serial_index < count_streams; serial_index++) {
      if (buffer_indexes[serial_index] < sizeof(buffer)) {
        uint16_t cbOutput = sizeof(buffer) - buffer_indexes[serial_index];
        uint16_t cbAvailForWrite = streams[serial_index]->availableForWrite();
        if (cbAvailForWrite < cbOutput) {
          cbOutput = cbAvailForWrite;
        streams[serial_index]->write(&buffer[buffer_indexes[serial_index]], cbOutput);
        buffer_indexes[serial_index] += cbOutput;
    //delayMicroseconds(10);
    digitalWriteFast(12, LOW);
  // Now lets wait until all of them finish their output
    streams[serial_index]->flush();
  Serial.printf("loop %u time: %u\n", loop_count, millis() - start_time);
  delay(250);
  Serial.printf("end F1:%x %x F2:%x %x F3: %x %x\n", FLEXIO1_SHIFTSTAT, FLEXIO1_SHIFTSIEN,
                FLEXIO2_SHIFTSTAT, FLEXIO2_SHIFTSIEN, FLEXIO3_SHIFTSTAT, FLEXIO3_SHIFTSIEN );
  Serial.printf("CCM_CDCDR: %x\n", CCM_CDCDR);
  Serial.printf("VERID:%x PARAM:%x CTRL:%x PIN: %x\n", IMXRT_FLEXIO1_S.VERID, IMXRT_FLEXIO1_S.PARAM, IMXRT_FLEXIO1_S.CTRL, IMXRT_FLEXIO1_S.PIN);
  Serial.printf("SHIFTSTAT:%x SHIFTERR=%x TIMSTAT=%x\n", IMXRT_FLEXIO1_S.SHIFTSTAT, IMXRT_FLEXIO1_S.SHIFTERR, IMXRT_FLEXIO1_S.TIMSTAT);
  Serial.printf("SHIFTSIEN:%x SHIFTEIEN=%x TIMIEN=%x\n", IMXRT_FLEXIO1_S.SHIFTSIEN, IMXRT_FLEXIO1_S.SHIFTEIEN, IMXRT_FLEXIO1_S.TIMIEN);
  Serial.printf("SHIFTSDEN:%x SHIFTSTATE=%x\n", IMXRT_FLEXIO1_S.SHIFTSDEN, IMXRT_FLEXIO1_S.SHIFTSTATE);
  Serial.printf("SHIFTCTL:%x %x %x %x\n", IMXRT_FLEXIO1_S.SHIFTCTL[0], IMXRT_FLEXIO1_S.SHIFTCTL[1], IMXRT_FLEXIO1_S.SHIFTCTL[2], IMXRT_FLEXIO1_S.SHIFTCTL[3]);
  Serial.printf("SHIFTCFG:%x %x %x %x\n", IMXRT_FLEXIO1_S.SHIFTCFG[0], IMXRT_FLEXIO1_S.SHIFTCFG[1], IMXRT_FLEXIO1_S.SHIFTCFG[2], IMXRT_FLEXIO1_S.SHIFTCFG[3]);
  Serial.printf("TIMCTL:%x %x %x %x\n", IMXRT_FLEXIO1_S.TIMCTL[0], IMXRT_FLEXIO1_S.TIMCTL[1], IMXRT_FLEXIO1_S.TIMCTL[2], IMXRT_FLEXIO1_S.TIMCTL[3]);
  Serial.printf("TIMCFG:%x %x %x %x\n", IMXRT_FLEXIO1_S.TIMCFG[0], IMXRT_FLEXIO1_S.TIMCFG[1], IMXRT_FLEXIO1_S.TIMCFG[2], IMXRT_FLEXIO1_S.TIMCFG[3]);
  Serial.printf("TIMCMP:%x %x %x %x\n", IMXRT_FLEXIO1_S.TIMCMP[0], IMXRT_FLEXIO1_S.TIMCMP[1], IMXRT_FLEXIO1_S.TIMCMP[2], IMXRT_FLEXIO1_S.TIMCMP[3]);
  // Lets see if there if the user hit anything to tell us to pause
  if (Serial.available()) {
    while (Serial.read() != -1) ;
    Serial.println("Paused enter anything to continue running");
    while (Serial.read() == -1) ;
  delay(250);
