DD4WH
Many people suffer from high frequency hearing loss, especially people above the age of 50. Lang Elliott had the idea of lowering the pitch of bird songs with a special device in order to help bird enthusiasts with high frequency hearing loss to hear those higher-pitched bird songs [https://hearbirdsagain.org/]. These higher-pitched songs would normally be outside of their hearing ranges. His idea motivated me to try this on the Teensy 4.0. The plan is to experiment with different pitch shifting algorithms. I want to evaluate their specific suitability for pitch shifting of bird songs. [Bird songs differ a lot from the normal audio application range, i.e. speech or music !]
My scan of the Teensy forum revealed several existing libraries/algorithms for altering the pitch of audio sounds:
So, after finding those implementations, I wanted to experiment with them in realtime by sending bird song audio from my smartphone to the Teensy and switch between those algorithms and tweak their parametres in order to find the best sounding solution for altering the pitch of bird songs by ear.
I use a Teensy 4.0 with an ADC PCM1808 and DAC5102a, but it should also run with a Teensy 4 and the Teensy audio board by using the Stereo line inputs.
The following sketch contains a real-time implementation of all the above mentioned methods, so I can switch and tweak them. Audio comes from the 3.5mm audio plug of my smartphone into the ADC and I can hear the result in my headphones. I implemented all methods in Stereo. Five buttons are used to toggle ON/OFF an input 2.5kHz highpass filter, to switch between the algorithms and to increase/decrease the amount of pitch shift of the specific method.
This is the setup (please note that all modules in the bottom right corner are float 32-bit processing modules; everything right and below of the "convertInR")
If you want to run the sketch, read carefully through the comments in the header: you need to download and copy some files into your local Arduino folder. It runs on Teensy 4 only (and has 75% CPU load).
Now I have the following questions:
* Are there any other methods for pitch shifting that could be useful for bird sounds and that I am missing here ?
* Can you recommend useful settings for the methods above ? I am new to all of those algorithms and they all seem to have their pros and cons.
* Also, it would be great if you could point me to any errors in the implementations of the different methods
EDIT: the current state of the code can also be found here
https://github.com/DD4WH/BirdSongPitchShifter
- Granular effect - in the Teensy Audio library
- Heterodyning, i.e. multiplying the audio with a sine wave of given frequency - implementable with the Audio Library
- Vocoder / pitch shifting in the frequency domain - sophisticated algorithm by Stephan Bernsee, implemented by Duff2013 for the Teensy
- Formant shifting in the frequency domain - sophisticated algorithm by Chip Audette, implemented in the Tympan library and later by Bob Larkin in the OpenAudio_Arduino_lib
- Frequency shifting by Quadrature Modulation - implemented by Bob Larkin in the OpenAudio library, originally intended for Software Defined Radio
* PITCH SHIFTING, FORMANT SHIFTING AND FREQUENCY SHIFTING OF BIRD SOUNDS
* (c) Frank DD4WH
* Experiments with the Teensy 4.0 & ADC PCM1808 & DAC PCM5102
* to aid people with hearing loss to hear birds (again)
* inspired & motivated by Lang Elliott
* https://hearbirdsagain.org/
* using the following code libraries:
* Teensy Audio Library: Paul Stoffregen
* Pitch Shifting using FFT: Stephan Bernsee & duff2013
* OpenAudioLibrary: Chip Audette & Bob Larkin
* experimental platform
* all licenses remain those of the original code snippets that I used,
* mostly MIT license, but also some use GNU GPLv3 license
* July, 27th 2022
* Pitch Shifting:
* 1.) advanced algorithm (smbPitchShift) modified by duff2013
* Heterodyning:
* 2.) simple mixing of Audio signal with sine oscillator
* Granular Effect:
* 3.) from Audio Library
* Frequency Shifting:
* 4.) Quadrature Modulator: designed for Software Defined Radios by Bob Larkin
* Formant shifting:
* 5.) Tympan library by Chip Audette, version taken from OpenAudio lib
* Only for Teensy 4.0 or Teensy 4.1 !!! This does not work with Teensy 3.2/3.5/3.6
* Use the latest Arduino 1.8.19 and Teensyduino version 1.57
* In order for this code to compile correctly, please install these libraries into your Arduino folder:
* 1.) https://github.com/duff2013/AudioEffectPhaseVocoder
* you have to correct line 26 of this file: effect_phaseVocoder.cpp --> should be: "#include "effect_phaseVocoder.h""
* 2.) https://github.com/chipaudette/OpenAudio_ArduinoLibrary
* this is the source for Formant Shift and Quadrature modulation-based frequency shift
* 3.) copy the file "hilbert251A.h" from folder OpenAudio_ArduinoLibrary/examples/FineFreqShift_OA to your sketch folder
Audio MEM INT16 Cur/Peak: 20/24
Audio MEM Float32 Cur/Peak: 24/26
CPU INT16 Cur/Peak: 60.39%/62.68%
CPU F32 Cur/Peak: 15.60%/16.17%
Memory Usage on Teensy 4.0:
FLASH: code:98420, data:81032, headers:8960 free for files:1843204
RAM1: variables:227104, code:95816, padding:2488 free for local variables:198880
RAM2: variables:23808 free for malloc/new:500480
#include "AudioStream_F32.h"
#include "OpenAudio_ArduinoLibrary.h"
#include "AudioEffectFormantShiftFD_OA_F32.h" //the local file holding your custom function
#include <Bounce.h>
//#include <Wire.h>
//#include <SPI.h>
//#include <SD.h>
//#include <SerialFlash.h>
// Filter for AudioFilter90Deg_F32 hilbert1
#include "hilbert251A.h"
// this is only needed for F32 OpenAudio lib !
//set the sample rate and block size
const float sample_rate_Hz = 44100.f; ; // other frequencies in the table in AudioOutputI2S_F32 for T3.x only
const int audio_block_samples = 128; //for freq domain processing, a power of 2: 16, 32, 64, 128
AudioSettings_F32 audio_settings(sample_rate_Hz, audio_block_samples);
AudioInputI2S i2s1; //xy=153,323
AudioAmplifier ampL; //xy=327,398
AudioAmplifier ampR; //xy=335,254
AudioFilterBiquad highpassL; //xy=479,350
AudioFilterBiquad highpassR; //xy=480,296
AudioMixer4 HPswitchR; //xy=639,241
AudioMixer4 HPswitchL; //xy=639,421
AudioSynthWaveformSine sine1; //xy=645,325
AudioEffectPhaseVocoder VocoderR; //xy=855,117
AudioEffectPhaseVocoder VocoderL; //xy=858,174
AudioEffectMultiply multiplyR; //xy=859,287
AudioEffectMultiply multiplyL; //xy=859,363
AudioEffectGranular granularR; //xy=504,155
AudioEffectGranular granularL; //xy=504,155
AudioMixer4 switchR; //xy=1042,202
AudioMixer4 switchL; //xy=1046,362
AudioFilterBiquad lowpassR; //xy=1195,230
AudioFilterBiquad lowpassL; //xy=1199,331
AudioOutputI2S i2s2; //xy=1338,285
// Formant Shifter
AudioConvert_I16toF32 convertInR; // Convert to float
AudioConvert_I16toF32 convertInL; // Convert to float
AudioEffectFormantShiftFD_OA_F32 formantShiftR(audio_settings); // the frequency-domain processing block
AudioEffectFormantShiftFD_OA_F32 formantShiftL(audio_settings); // the frequency-domain processing block
AudioEffectGain_F32 formantGainR; //Applies digital gain to audio data.
AudioEffectGain_F32 formantGainL; //Applies digital gain to audio data.
AudioConvert_F32toI16 convertOutR;
AudioConvert_F32toI16 convertOutL;
AudioMixer4_F32 MixerR;
AudioMixer4_F32 MixerL;
AudioConnection patchCord31(HPswitchR, 0, convertInR, 0);
AudioConnection patchCord32(HPswitchL, 0, convertInL, 0);
AudioConnection_F32 patchCord33(convertInR, 0, formantShiftR, 0);
AudioConnection_F32 patchCord34(convertInL, 0, formantShiftL, 0);
AudioConnection_F32 patchCord35(formantShiftR, 0, MixerR, 2);
AudioConnection_F32 patchCord36(formantShiftL, 0, MixerL, 2);
AudioConnection_F32 patchCord39(MixerR, 0, convertOutR, 0);
AudioConnection_F32 patchCord40(MixerL, 0, convertOutL, 0);
AudioConnection patchCord37(convertOutR, 0, switchR, 2);
AudioConnection patchCord38(convertOutL, 0, switchL, 2);
// Frequency Mixer
RadioIQMixer_F32 IQMixerR;
RadioIQMixer_F32 IQMixerL;
AudioFilter90Deg_F32 HilbertR;
AudioFilter90Deg_F32 HilbertL;
AudioConnection_F32 patchCord51(convertInR, 0, IQMixerR, 0);
AudioConnection_F32 patchCord52(convertInR, 0, IQMixerR, 1);
AudioConnection_F32 patchCord53(convertInL, 0, IQMixerL, 0);
AudioConnection_F32 patchCord54(convertInL, 0, IQMixerL, 1);
AudioConnection_F32 patchCord55(IQMixerR, 0, HilbertR, 0);
AudioConnection_F32 patchCord56(IQMixerR, 1, HilbertR, 1);
AudioConnection_F32 patchCord57(IQMixerL, 0, HilbertL, 0);
AudioConnection_F32 patchCord58(IQMixerL, 1, HilbertL, 1);
AudioConnection_F32 patchCord59(HilbertR, 0, MixerR, 0);
AudioConnection_F32 patchCord60(HilbertR, 1, MixerR, 1);
AudioConnection_F32 patchCord61(HilbertL, 0, MixerL, 0);
AudioConnection_F32 patchCord62(HilbertL, 1, MixerL, 1);
AudioConnection patchCord1(i2s1, 0, ampR, 0);
AudioConnection patchCord2(i2s1, 1, ampL, 0);
AudioConnection patchCord3(ampL, highpassL);
AudioConnection patchCord4(ampL, 0, HPswitchL, 0);
AudioConnection patchCord5(ampR, highpassR);
AudioConnection patchCord6(ampR, 0, HPswitchR, 0);
AudioConnection patchCord7(highpassL, 0, HPswitchL, 1);
AudioConnection patchCord8(highpassR, 0, HPswitchR, 1);
AudioConnection patchCord9(HPswitchR, VocoderR);
AudioConnection patchCord10(HPswitchR, 0, multiplyR, 0);
AudioConnection patchCord11(HPswitchL, VocoderL);
AudioConnection patchCord12(HPswitchL, 0, multiplyL, 1);
AudioConnection patchCord13(sine1, 0, multiplyR, 1);
AudioConnection patchCord14(sine1, 0, multiplyL, 0);
AudioConnection patchCord15(VocoderR, 0, switchR, 0);
AudioConnection patchCord16(VocoderL, 0, switchL, 0);
AudioConnection patchCord17(multiplyR, 0, switchR, 1);
AudioConnection patchCord18(multiplyL, 0, switchL, 1);
AudioConnection patchCord19(switchR, lowpassR);
AudioConnection patchCord20(switchL, lowpassL);
AudioConnection patchCord70(HPswitchR, granularR);
AudioConnection patchCord71(HPswitchL, granularL);
AudioConnection patchCord72(granularR, 0, switchR, 3);
AudioConnection patchCord73(granularL, 0, switchL, 3);
AudioConnection patchCord21(lowpassR, 0, i2s2, 0);
AudioConnection patchCord22(lowpassL, 0, i2s2, 1);
AudioControlSGTL5000 sgtl5000_1; //xy=154,532
elapsedMillis count;
int shift = -12; // 12 semitones == one octave downshift
int heterodyne_freq = 3600;
float formant_scaling = 0.5f; // 1.0f == no shift
int formant_overlap_factor = 4;
float quadrature_freq = 2500.0f;
float delayms = 1.0f;
int highPass_freq = 2500;
int lowPass_freq = 3500;
uint8_t HPfilter_ON = 0; // 0 = OFF, 1 = ON
#define GRANULAR_MEMORY_SIZE 12800 // enough for 290 ms at 44.1 kHz
int16_t granularMemoryR[GRANULAR_MEMORY_SIZE];
int16_t granularMemoryL[GRANULAR_MEMORY_SIZE];
float granular_ratio = 0.5f;
float granular_ms = 30.0f;
#define MODE_MIN 0
#define MODE_HETERODYNE 0
#define MODE_VOCODER 1
#define MODE_FORMANT 2
#define MODE_QUADRATURE 3
#define MODE_GRANULAR 4
#define MODE_MAX 4
int mode = MODE_HETERODYNE;
#define HETERODYNE_STANDARD_FREQ 2500
Bounce button0 = Bounce(26, 20); // UP Decrease the pitch of the sound
Bounce button1 = Bounce(24, 20); // DOWN Increase the pitch of the sound
Bounce button2 = Bounce(28, 20); // Klick middle Restore shift parameter to STANDARD value (= zero shift)
Bounce button3 = Bounce(32, 20); // RIGHT Toggle different "modes"= shifting methods
Bounce button4 = Bounce(30, 20); // LEFT Toggle HighPass Filter ON/OFF
AudioMemory(30);
AudioMemory_F32(200, audio_settings);
pinMode(26, INPUT_PULLUP);
pinMode(24, INPUT_PULLUP);
pinMode(28, INPUT_PULLUP);
pinMode(32, INPUT_PULLUP);
pinMode(30, INPUT_PULLUP);
sgtl5000_1.enable();
sgtl5000_1.volume(0.9);
ampR.gain(2.5f);
ampL.gain(2.5f);
// Configure the frequency-domain algorithm for Formant Shift
//int overlap_factor = 4; //set to 4 or 8 or either 75% overlap (4x) or 87.5% overlap (8x)
int N_FFT = audio_block_samples * formant_overlap_factor;
formantShiftR.setup(audio_settings, N_FFT); //do after AudioMemory_F32();
formantShiftL.setup(audio_settings, N_FFT); //do after AudioMemory_F32();
Set_Formant(formant_scaling);
Set_Vocoder(shift);
Set_Heterodyne(heterodyne_freq, lowPass_freq, highPass_freq);
Set_Quadrature(quadrature_freq);
HilbertR.begin(hilbert251A, 251); // Set the Hilbert transform FIR filter
HilbertL.begin(hilbert251A, 251); // Set the Hilbert transform FIR filter
Set_HighPass (HPfilter_ON, highPass_freq);
Switch_Mode(mode);
// the Granular effect requires memory to operate
granularR.begin(granularMemoryR, GRANULAR_MEMORY_SIZE);
granularL.begin(granularMemoryL, GRANULAR_MEMORY_SIZE);
Set_Granular(granular_ratio, granular_ms);
button0.update();
button1.update();
button2.update();
button3.update();
button4.update();
if(count > 2000)
print_Info();
count = 0;
if(mode == MODE_VOCODER)
if (button0.fallingEdge())
shift += 2;
Set_Vocoder(shift);
if (button1.fallingEdge())
shift -= 2;
Set_Vocoder(shift);
if (button2.fallingEdge())
shift = 0;
Set_Vocoder(shift);
else if(mode == MODE_HETERODYNE)
heterodyne_freq -= 200;
heterodyne_freq += 200;
heterodyne_freq = HETERODYNE_STANDARD_FREQ;
else if(mode == MODE_FORMANT)
formant_scaling -= 0.05f;
formant_scaling += 0.05f;
formant_scaling = 1.0f;
else if(mode == MODE_QUADRATURE)
quadrature_freq -= 200.0f;
quadrature_freq += 200.0f;
else if(mode == MODE_GRANULAR)
granular_ratio -= 0.05f;
granular_ratio += 0.05f;
// this is for mode changing
if (button3.fallingEdge())
mode += 1;
mode = clamp_turnover(mode,MODE_MIN,MODE_MAX);
Switch_Mode(mode);
if (button4.fallingEdge())
if(HPfilter_ON == 1)
HPfilter_ON = 0;
HPfilter_ON = 1;
Set_HighPass(HPfilter_ON, highPass_freq);
void Switch_Mode(int mode)
Serial.println("MODE Vocoder was selected");
ampR.gain(3.5f);
ampL.gain(3.5f);
// switch on Vocoder, switch off everything else
switchR.gain(0,1.0f);
switchR.gain(1,0.0f);
switchR.gain(2,0.0f);
switchR.gain(3,0.0f);
switchL.gain(0,1.0f);
switchL.gain(1,0.0f);
switchL.gain(2,0.0f);
switchL.gain(3,0.0f);
// lowpass
lowpassR.setLowpass(0,lowPass_freq,0.54);
lowpassR.setLowpass(1,lowPass_freq,1.3);
lowpassR.setLowpass(2,lowPass_freq,0.54);
lowpassR.setLowpass(3,lowPass_freq,1.3);
lowpassL.setLowpass(0,lowPass_freq,0.54);
lowpassL.setLowpass(1,lowPass_freq,1.3);
lowpassL.setLowpass(2,lowPass_freq,0.54);
lowpassL.setLowpass(3,lowPass_freq,1.3);
sine1.amplitude(1.0f);
sine1.frequency(heterodyne_freq);
// switch on Heterodyne, switch off everything else
switchR.gain(0,0.0f);
switchR.gain(1,1.3f);
switchL.gain(0,0.0f);
switchL.gain(1,1.3f);
// lowpass
Serial.println("MODE Heterodyne was selected");
// switch on Formant, switch off everything else
switchR.gain(2,1.0f);
switchL.gain(2,1.0f);
// lowpass
MixerR.gain(0,0.0f);
MixerR.gain(1,0.0f);
MixerR.gain(2,1.0f);
MixerR.gain(3,0.0f);
MixerL.gain(0,0.0f);
MixerL.gain(1,0.0f);
MixerL.gain(2,1.0f);
MixerL.gain(3,0.0f);
Serial.println("MODE Formant Shift was selected");
// switch on Formant or Freq shifting, switch off everything else
// lowpass
MixerR.gain(0,0.5f);
MixerR.gain(1,0.5f);
MixerR.gain(2,0.0f);
MixerL.gain(0,0.5f);
MixerL.gain(1,0.5f);
MixerL.gain(2,0.0f);
Serial.println("MODE Quadrature was selected");
switchR.gain(3,1.0f);
switchL.gain(3,1.0f);
// lowpass
Serial.println("MODE Granular was selected");
Serial.println("ERROR: no sensible mode selected !");
} // END "Switch_Mode"
void Set_Vocoder(int shift)
VocoderR.setPitchShift(shift);
VocoderL.setPitchShift(shift);
Serial.print(" PITCH SHIFT IN SEMITONES: "); Serial.println(shift);
void Set_Heterodyne(int freq, int lowpass_freq, int highpass_freq)
heterodyne_freq = clamp(freq,0,10000);
Serial.print(" HETERODYNE SHIFT IN HZ: "); Serial.println(heterodyne_freq);
void Set_Formant(float scale_factor)
// formantShiftR.setScaleFactor(1.587401f); // up-shift ! 1.0 is no formant shifting.
// formantShiftL.setScaleFactor(1.587401f); // up-shift ! 1.0 is no formant shifting.
formant_scaling = clamp_f(scale_factor,0.1f,2.0f);
formantShiftR.setScaleFactor(formant_scaling); //1.0 is no formant shifting.
formantShiftL.setScaleFactor(formant_scaling); //1.0 is no formant shifting.
void Set_Quadrature(float frequencyLO)
IQMixerR.frequency(frequencyLO); // Frequency shift, Hz
IQMixerL.frequency(frequencyLO); // Frequency shift, Hz
void Set_Granular(float ratio, float ms)
granular_ratio = clamp_f(ratio,0.2f, 3.0f);
granular_ms = clamp_f(ms, 25, 2500);
granularR.beginPitchShift(granular_ms); // ??? maybe 25 to 2500 ?
granularR.setSpeed(ratio); // 0.5 to 2.0
granularL.beginPitchShift(granular_ms); // ??? maybe 25 to 2500 ?
granularL.setSpeed(ratio); // 0.5 to 2.0
Serial.print(" GRANULAR RATIO is: "); Serial.print(granular_ratio);
void Set_HighPass (uint8_t on, int freq)
if(on == 1)
HPswitchR.gain(0,0.0f);
HPswitchR.gain(1,1.0f);
HPswitchL.gain(0,0.0f);
HPswitchL.gain(1,1.0f);
HPswitchR.gain(0,1.0f);
HPswitchR.gain(1,0.0f);
HPswitchL.gain(0,1.0f);
HPswitchL.gain(1,0.0f);
HPswitchL.gain(2,0.0f);
HPswitchL.gain(3,0.0f);
HPswitchR.gain(2,0.0f);
HPswitchR.gain(3,0.0f);
highpassR.setHighpass(0, freq, 0.54);
highpassR.setHighpass(1, freq, 1.3);
highpassR.setHighpass(2, freq, 0.54);
highpassR.setHighpass(3, freq, 1.3);
highpassL.setHighpass(0, freq, 0.54);
highpassL.setHighpass(1, freq, 1.3);
highpassL.setHighpass(2, freq, 0.54);
highpassL.setHighpass(3, freq, 1.3);
int clamp_turnover(int var, int Min, int Max)
if(var > Max) var = Min;
if(var < Min) var = Max;
return var;
int clamp(int var, int Min, int Max)
if(var > Max) var = Max;
if(var < Min) var = Min;
return var;
float clamp_f(float var, float Min, float Max)
return var;
void print_Info(void)
Serial.print("We are in ");
//Serial.println(mode);
Serial.println(" VOCODOER mode");
else if (mode == MODE_HETERODYNE)
Serial.println(" HETERODYNE mode");
Serial.print(" HETERODYNE FREQUENCY is: "); Serial.print(heterodyne_freq); Serial.println(" Hz");
Serial.println("QUADRATURE/FREQUENCY SHIFT mode");
Serial.print(" FREQUENCY SHIFT is: "); Serial.print(quadrature_freq); Serial.println(" Hz");
Serial.println("FORMANT SHIFT mode");
Serial.print(" Formant scaling factor is: "); Serial.println(formant_scaling);
Serial.println("GRANULAR mode");
Serial.print(" Granular ratio is: "); Serial.println(granular_ratio);
Serial.println(" no sensible mode, something wrong here . . .");
Serial.print("Audio Input HighPass Filter is ");
if(HPfilter_ON == 1) Serial.println("ON");
else Serial.println("OFF");
Serial.print("Audio MEM INT16 Cur/Peak: ");
Serial.print(AudioMemoryUsage());
Serial.print("/");
Serial.println(AudioMemoryUsageMax());
Serial.print("Audio MEM Float32 Cur/Peak: ");
Serial.print(AudioMemoryUsage_F32());
Serial.print("/");
Serial.println(AudioMemoryUsageMax_F32());
Serial.print("CPU INT16 Cur/Peak: ");
Serial.print (AudioProcessorUsage());
Serial.print("%/");
Serial.print (AudioProcessorUsageMax());
Serial.println("%, ");
Serial.print("CPU F32 Cur/Peak: ");
Serial.print(audio_settings.processorUsage());
Serial.print("%/");
Serial.print(audio_settings.processorUsageMax());
Serial.print("%, ");
