I've successfully completed Teensy Projects with the Teenys 2.0 before and wanted to get into the Teensy LC. For this, I came up with a PCB design for a custom gamepad with 16 (on)-off-(on) switches and had in manufactured.
Both assembly and HW testing went well. Now, i am struggling with the Software part.
Initially I had planned on using QMK to program the Teensy but soon gave up due to the (from what I could tell) bad Joystick-support for the Teensy MCU within QMK.
Now, I am using Teensyduino but I have trouble getting the Joystick buttons to work
Here is what I am trying so far
1) use the KeyPad library to get the state-changes of the switches (note for anyone who stumbles upon this: I had to modify KeyPad.cpp to not be active-low in Keypad::scanKeys() so it works with a Keyboard matrix with diodes)
2) if a switch is "pressed", send
3) if a switch is "released", send
Note: I'm tryuing to use the useManualSend feature but the effect is the same with or without it
Complete code:
From the serial port, I can see, that the switch press/releases are detected very well. However, Windows does not recognize any Joystick button presses:
Do you folks have an idea on why the joystick buttons might not be registered by windows?
Any help is greatly appreciated.
Cheers
JR
Joystick.button(idx, 1);
Joystick.button(idx, 0);
Complete code:
/* @file MultiKey.ino
|| @version 1.0
|| @author Mark Stanley
|| @contact mstanley@technologist.com
|| @description
|| | The latest version, 3.0, of the keypad library supports up to 10
|| | active keys all being pressed at the same time. This sketch is an
|| | example of how you can get multiple key presses from a keypad or
|| | keyboard.
#include <Keypad.h>
const byte ROWS = 8;
const byte COLS = 4;
char keys[ROWS][COLS] = {
{'0', '1', '2', '3'},
{'4', '5', '6', '7'},
{'8', '9', 'a', 'b'},
{'c', 'd', 'e', 'f'},
{'g', 'h', 'i', 'j'},
{'k', 'l', 'm', 'n'},
{'o', 'p', 'q', 'r'},
{'s', 't', 'u', 'v'}
byte rowPins[ROWS] = {8, 4, 1, 3, 23, 22, 15, 19};
byte colPins[COLS] = {5, 16, 17, 21};
Keypad kpd = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
unsigned long loopCount;
unsigned long startTime;
String msg;
loopCount = 0;
startTime = millis();
msg = "";
Joystick.useManualSend(true);
loopCount++;
if ( (millis()-startTime)>5000 ) {
Serial.print("Average loops per second = ");
Serial.println(loopCount/5);
loopCount = 0;
// Fills kpd.key[ ] array with up-to 10 active keys.
// Returns true if there are ANY active keys.
if (kpd.getKeys())
for (int i=0; i<LIST_MAX; i++) // Scan the whole key list.
if ( kpd.key[i].stateChanged ) // Only find keys that have changed state.
switch (kpd.key[i].kstate) { // Report active key state : IDLE, PRESSED, HOLD, or RELEASED
case PRESSED:
msg = " PRESSED.";
Joystick.button(kpd.key[i].kcode, 1);
case HOLD:
msg = " HOLD.";
case RELEASED:
msg = " RELEASED.";
Joystick.button(kpd.key[i].kcode, 0);
case IDLE:
msg = " IDLE.";
Joystick.send_now();
Serial.print("Key ");
Serial.print(kpd.key[i].kchar);
Serial.print(" Code: ");
Serial.print(kpd.key[i].kcode);
Serial.println(msg);
} // End loop
Cheers
JR
