Results 1 to 6 of 6
Thread: Microphone FFT Hardware Test Not Working
    Jul 2022
    8
    Hi everyone,
    I've recently bought a SPH0645LM4H from Adafruit, and am running the SPH0645 hardware test example file (code below). I am using a teensy 4.1 and have the pins connected using jumper wires as follows:
    SEL: GND
    LRCL: 20
    DOUT: 8
    BCLK: 21
    GND: GND
    3V: 3.3V
    These is the configuration from this post. When I run the file, this is the output I get:
Name:	Screen Shot 2022-08-01 at 3.28.00 PM.png
    Any ideas?
    Code below:
    /* SPH0645 MEMS Microphone Test (Adafruit product #3421)
     * Forum thread with connection details and other info:
     * https://forum.pjrc.com/threads/60599?p=238070&viewfull=1#post238070
    AudioInputI2S            i2s1;           //xy=180,111
    AudioFilterStateVariable filter1;        //xy=325,101
    AudioAmplifier           amp1;           //xy=470,93
    AudioAnalyzeFFT1024      fft1024_1;      //xy=616,102
    AudioConnection          patchCord1(i2s1, 0, filter1, 0);
    AudioConnection          patchCord2(filter1, 2, amp1, 0);
    AudioConnection          patchCord3(amp1, fft1024_1);
      AudioMemory(50);
      filter1.frequency(30); // filter out DC & extremely low frequencies
      amp1.gain(8.5);        // amplify sign to useful range
      if (fft1024_1.available()) {
        // each time new FFT data is available
        // print 20 bins to the Arduino Serial Monitor
        Serial.print("FFT: ");
        for (int i = 0; i < 20; i++) {
          float n = fft1024_1.read(i);
          if (n >= 0.001) {
            Serial.print(n, 3);
            Serial.print(" ");
            Serial.print("  --  "); // don't print "0.000"
    26,787
    It really should work.
    Can you show us photos of your wiring? Maybe there an issue we'll be able to see.
    Jul 2022
    8
    Hi Paul,
    Thanks for taking the time. I'm at work right now so I don't have any photos of the setup. However, it is really simple so I believe I can describe it accurately. I have soldered a Teensy 4.1 to a rev d audio shield using some header pins. I have only soldered the pins that the audio shield uses, according to the diagram below found on the PJRC website.
    I then soldered an electret microphone to the MIC & GND pins on the audio shield. I soldered the pins according to the diagram below, with the traces to the case connected to the GND terminal on the shield.
    I tried running the FFT example with this setup and no luck.
    I have used this sequence to "hear" the audio signal
    AudioInputAnalog         adc1;
    AudioOutputI2S           i2s1;
    This is the configuration sequence that has worked in the FFT analyzer (if something is missing in the configuration I am all ears):
    AudioAnalyzeFFT1024      fft1024_2;
    AudioConnection          patchCord3(adc1, fft1024_2);
    Try to raise the resolution in the Setup by:
    analogReadResolution(12);
    Before
    AudioMemory(50);
    Jul 2022
    8
    As per TFTLCDCyg's suggestion, I've tried the code below (I am pasting the whole program for transparency). Now my output is:
    FFT: 0.07 0.04 - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -
    // FFT Test
    // Compute a 1024 point Fast Fourier Transform (spectrum analysis)
    // on audio connected to the Left Line-In pin.  By changing code,
    // a synthetic sine wave can be input instead.
    // The first 40 (of 512) frequency analysis bins are printed to
    // the Arduino Serial Monitor.  Viewing the raw data can help you
    // understand how the FFT works and what results to expect when
    // using the data to control LEDs, motors, or other fun things!
    //const int myInput = AUDIO_INPUT_LINEIN;
    const int myInput = AUDIO_INPUT_MIC;
    // Create the Audio components.  These should be created in the
    // order data flows, inputs/sources -> processing -> outputs
    AudioAnalyzeFFT1024      myFFT;
    AudioConnection          patchCord3(adc1, myFFT);
    //AudioConnection patchCord1(sinewave, 0, myFFT, 0);
      AudioMemory(12);
      // Enable the audio shield and set the output volume.
      audioShield.enable();
      audioShield.inputSelect(myInput);
      audioShield.volume(2);
      // Configure the window algorithm to use
      myFFT.windowFunction(AudioWindowHanning1024);
      //myFFT.windowFunction(NULL);
      float n;
      int i;
      if (myFFT.available()) {
        // print it all to the Arduino Serial Monitor
        for (i=0; i<40; i++) {
          n = myFFT.read(i);
          if (n >= 0.01) {
            Serial.print(n);
            Serial.print(" ");
            Serial.print("  -  "); // don't print "0.00"
    Jul 2022
    8
    As per TFTLCDCyg's suggestion, I've tried the code below (I am pasting the whole program for transparency. Now my output is:
    // FFT Test
      AudioMemory(12);
      float n;
      int i;
          n = myFFT.read(i);
          if (n >= 0.01) {
            Serial.print(n);
            Serial.print(" ");
