Results 1 to 10 of 10
Thread: Teensy 4.1 delay times
    Aug 2022
    5
    Simple question, what is the maximum audio delay time you can reasonably expect from a teensy 4.1 with the Delay effect & using internal memory?
    And how many audio blocks would you need to allocate for that?
    I've seen plenty of specs for the 3.2 but not for the 4.1!
    26,797
    Each audio block gives 2.9ms delay, since the block size is 128 samples.
    Aug 2022
    5
    so how many audio blocks can you have on the 4.1?
    Thanks for the quick reply by the way :-)
    Apr 2021
    Cambridgeshire, UK
    443
    896 (see line 36)
    Aug 2022
    5
    Quote Originally Posted by h4yn0nnym0u5e View Post
    229376 (see line 36)
    Thanks, that makes things easier to calculate :-)
    Apr 2021
    Cambridgeshire, UK
    443
    Please note I made an error initially - 229376 is the memory in bytes, not blocks: I edited my post accordingly. Also, it looks as if you can allocate more than that and the memory will be used, but the audio library will only make use of the first 896 blocks, the rest will be wasted.
    Aug 2022
    5
    Please note I made an error initially - 229376 is the memory in bytes, not blocks: I edited my post accordingly. Also, it looks as if you can allocate more than that and the memory will be used, but the audio library will only deal with the first 1792 blocks, the rest will be wasted.
    yeah I just figured that out, so divided the memory by 128 :-)
    Cheers for the quick amendment :-)
    Apr 2021
    Cambridgeshire, UK
    443
    I was still in error - divide by 256, each sample is 2 bytes ... 896 is my final offer!
    26,797
    You could just edit the code to change MAX_AUDIO_MEMORY if you *really* wanted to use more.
    Aug 2022
    5
    I was wondering if that would be an option, Thanks for the heads up :-)
