Results 1 to 9 of 9
Thread: Trouble with SCL2 and SDA2 IC2 with 4.1
    Aug 2022
    4
    Hello!
    Recently, I have been trying to get data off a BMP388 using pins 24 and 25 (SCL2 and SDA2). I cannot get anything to work. Here is the code I have been using. I really need help.
    #include <Adafruit_Sensor.h>
    #include "Adafruit_BMP3XX.h"
    #include "WireIMXRT.h"
    #define BMP_SCK 24
    #define BMP_MISO 12
    #define BMP_MOSI 25
    #define BMP_CS 10
    #define Wire Wire2
    #define SEALEVELPRESSURE_HPA (1013.25)
    Adafruit_BMP3XX bmp;
      Wire2.begin();
      while (!Serial);
      Serial.println("Adafruit BMP388 / BMP390 test");
      if (!bmp.begin_I2C(&Wire2)){   // hardware I2C mode, can pass in address & alt Wire
      //if (! bmp.begin_SPI(BMP_CS)) {  // hardware SPI mode
      //if (! bmp.begin_SPI(BMP_CS, BMP_SCK, BMP_MISO, BMP_MOSI)) {  // software SPI mode
        Serial.println("Could not find a valid BMP3 sensor, check wiring!");
        while (1);
      // Set up oversampling and filter initialization
      bmp.setTemperatureOversampling(BMP3_OVERSAMPLING_8X);
      bmp.setPressureOversampling(BMP3_OVERSAMPLING_4X);
      bmp.setIIRFilterCoeff(BMP3_IIR_FILTER_COEFF_3);
      bmp.setOutputDataRate(BMP3_ODR_50_HZ);
      if (! bmp.performReading()) {
        Serial.println("Failed to perform reading :(");
        return;
      Serial.print("Temperature = ");
      Serial.print(bmp.temperature);
      Serial.println(" *C");
      Serial.print("Pressure = ");
      Serial.print(bmp.pressure / 100.0);
      Serial.println(" hPa");
      Serial.print("Approx. Altitude = ");
      Serial.print(bmp.readAltitude(SEALEVELPRESSURE_HPA));
      Serial.println(" m");
      delay(2000);
    Last edited by defragster; 08-09-2022 at 03:37 AM. Reason: Added $ CODE markers for readability
    16,358
    If all instances of Wire have been changed to Wire2 this could be removed: #define Wire Wire2
    Has this been tested to work on Wire with the appropriate changes?
    > proper pullups and wiring?
    Some i2c Devices start slower and some delay can help before activating them.
    26,787
    Looks like this should work. Adafruit's library is designed to work with any I2C port, so you shouldn't need to use "#define Wire Wire2" or edit the library to change "Wire" to "Wire2", as is needed with older libraries that are designed for only the default Wire port.
    My guess is you may have a mistake or misunderstanding in the wiring. Maybe we could help more if you show photos of how you connected the hardware to Teensy?
    Aug 2022
    4
    Yeah, everything works when I have the wires connected to SCL and SDA (pins 19 and 18).
    According to the header file:
     bool begin_I2C(uint8_t addr = BMP3XX_DEFAULT_ADDRESS,
                     TwoWire *theWire = &Wire);
    I would try this:
    bmp.begin_I2C(BMP3XX_DEFAULT_ADDRESS, &Wire2);
    26,787
    Quote Originally Posted by LionA View Post
    I'm assuming you're editing this line when you connect the wires to pins 18 and 19?
    But I can't see your screen. Maybe you're editing it to "bmp.begin_I2C(&Wire)" or maybe "bmp.begin_I2C()"? Sometimes small details matter. And I still can't see how you're connecting the wires to pins 24 & 25, though hearing the hardware works with pins 18 & 19 is a good sign. Still, very difficult to help like this, basically blind guessing, but trying anyway.
    16,358
    Quote Originally Posted by MarkzP View Post
    I would try this:
    That makes sense. I saw note for passing address, but didn't look into the prototype for expected ordering of the values.
    Aug 2022
    4
    MarkzP the savior. Thank you guys so much for all of your help!!!!
    Aug 2022
    4
