Hi All,
I'm working on a project to control some servos with Automation Direct's SureServo2 line of products and I am running into an issue I can't seem to resolve.
I'm currently using Paul's Modbus RTU Library as found here: https://github.com/PaulStoffregen/Modbus-Master-Slave-for-Arduino
I modified one of the examples for testing as shown:
As you can see I've only modified the parameters to match the default parameters that the Servo Drive requires. Then at the bottom I've added a little loop to spit out all the data via my serial monitor to see if everything is working.
Short answer: it's not
To clarify, the serial monitor is spitting out nothing but the following each loop:
0000000000000000..
However I've attached a screenshot from my logic analyzer to show that I should be receiving "7554" in there somewhere (this is just the encoder count for the servo's current rotational position, this will change a lot as it is rotating). Note that I am reading these data from my analyzer with the listed signals connected to the appropriate teeny pins (0,1 & 2 in this example)
I've gone through A LOT of troubleshooting. Here's what I've tried:
With my current hardware setup and this new model of servo drive, the result is always the same: query goes out, expected response comes back, but I don't get any usable data out of the library functions.
Please tell me I'm not overlooking something simple! I've been going nuts trying to get something I can work with, but I've had no luck so far. Actually, I will take a simple fix! Anything to help me move on and start being able to use my servos
Thanks in advance for any insight ya'll might be able to provide.
#include <ModbusRtu.h>
uint16_t au16data[16];
uint8_t u8state;
Modbus master(0,Serial1,2); //
modbus_t telegram;
unsigned long u32wait;
Serial.begin(9600); // for viewing result during testing
Serial1.begin(38400, SERIAL_8N2); // servo drive default com parameters
master.begin(38400);
master.setTimeOut( 2000 ); // if there is no answer in 2000 ms, roll over
u32wait = millis() + 1000;
u8state = 0;
switch( u8state ) {
case 0:
if (millis() > u32wait) u8state++; // wait state
case 1:
telegram.u8id = 127; // slave address
telegram.u8fct = 3; // function code (this one is registers read)
telegram.u16RegAdd = 18; // start address in slave
telegram.u16CoilsNo = 2; // number of elements (coils or registers) to read
telegram.au16reg = au16data; // pointer to a memory array in the Arduino
master.query( telegram ); // send query (only once)
u8state++;
case 2:
master.poll(); // check incoming messages
if (master.getState() == COM_IDLE) {
u8state = 0;
for (int i=0; i<16; i++) {
Serial.print(au16data[i]);
Serial.println("..");
0000000000000000..
- Different Teensy 4.1s
- Different Serial Ports on the Teensys (Serial1 and Serial2)
- Different MAX3485 ICs (with 120ohm resistor installed).
- Changing parameters in the servo drive to use different speed, data format (and of course updating the code to reflect those changes)
- Different libraries: both the Smarmengol library which Paul's was forked from, and 4-20ma's (Doc Walker) ModbusMaster library which I had successfully used previously with the previous generation of SureServo (not SureServo2) drives via RS232 with a MAX3232 chip.
