Hi, I am trying to use the i2c_t3 library (found linked on the Teensy website i2c page) to do fast DMA based i2c to control an LED driver.
Simultaneously, I am trying to run an audio library program.
Because the audio library uses the Wire library for some objects (which i am not using for my project btw), it has conflicting definitions with the i2c_t3 library.
This happens even when I make a completely blank sketch with both included:
I get the following error:
Do you have any suggestions on how to fix / work around this? I would rather not switch to wire since I want to use DMA because of speed.
#include <i2c_t3.h>
/var/folders/j0/_sxbhppj1b9bmytyldk9lt600000gp/T/arduino_build_778229/libraries/Wire/WireKinetis.cpp.o: In function `i2c0_isr':
/private/var/folders/j0/_sxbhppj1b9bmytyldk9lt600000gp/T/AppTranslocation/1AE95969-E134-4286-9B52-BCFDC8FF82AD/d/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire/WireKinetis.cpp:912: multiple definition of `i2c0_isr'
/var/folders/j0/_sxbhppj1b9bmytyldk9lt600000gp/T/arduino_build_778229/libraries/i2c_t3/i2c_t3.cpp.o:/private/var/folders/j0/_sxbhppj1b9bmytyldk9lt600000gp/T/AppTranslocation/1AE95969-E134-4286-9B52-BCFDC8FF82AD/d/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/i2c_t3/i2c_t3.cpp:1134: first defined here
/private/var/folders/j0/_sxbhppj1b9bmytyldk9lt600000gp/T/AppTranslocation/1AE95969-E134-4286-9B52-BCFDC8FF82AD/d/Teensyduino.app/Contents/Java/hardware/tools/arm/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ld: Disabling relaxation: it will not work with multiple definitions
/var/folders/j0/_sxbhppj1b9bmytyldk9lt600000gp/T/arduino_build_778229/libraries/Wire/WireKinetis.cpp.o: In function `Print::availableForWrite()':
/private/var/folders/j0/_sxbhppj1b9bmytyldk9lt600000gp/T/AppTranslocation/1AE95969-E134-4286-9B52-BCFDC8FF82AD/d/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire/WireKinetis.h:133: multiple definition of `i2c1_isr'
/var/folders/j0/_sxbhppj1b9bmytyldk9lt600000gp/T/arduino_build_778229/libraries/i2c_t3/i2c_t3.cpp.o:/private/var/folders/j0/_sxbhppj1b9bmytyldk9lt600000gp/T/AppTranslocation/1AE95969-E134-4286-9B52-BCFDC8FF82AD/d/Teensyduino.app/Contents/Java/hardware/teensy/avr/cores/teensy3/Print.h:61: first defined here
/var/folders/j0/_sxbhppj1b9bmytyldk9lt600000gp/T/arduino_build_778229/libraries/Wire/WireKinetis.cpp.o: In function `Print::availableForWrite()':Multiple libraries were found for "SD.h"
Used: /private/var/folders/j0/_sxbhppj1b9bmytyldk9lt600000gp/T/AppTranslocation/1AE95969-E134-4286-9B52-BCFDC8FF82AD/d/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SD
Not used: /private/var/folders/j0/_sxbhppj1b9bmytyldk9lt600000gp/T/AppTranslocation/1AE95969-E134-4286-9B52-BCFDC8FF82AD/d/Teensyduino.app/Contents/Java/libraries/SD
/private/var/folders/j0/_sxbhppj1b9bmytyldk9lt600000gp/T/AppTranslocation/1AE95969-E134-4286-9B52-BCFDC8FF82AD/d/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire/WireKinetis.h:133: multiple definition of `Wire1'
/private/var/folders/j0/_sxbhppj1b9bmytyldk9lt600000gp/T/AppTranslocation/1AE95969-E134-4286-9B52-BCFDC8FF82AD/d/Teensyduino.app/Contents/Java/hardware/tools/arm/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ld: Warning: size of symbol `Wire1' changed from 20 in /var/folders/j0/_sxbhppj1b9bmytyldk9lt600000gp/T/arduino_build_778229/libraries/i2c_t3/i2c_t3.cpp.o to 108 in /var/folders/j0/_sxbhppj1b9bmytyldk9lt600000gp/T/arduino_build_778229/libraries/Wire/WireKinetis.cpp.o
/private/var/folders/j0/_sxbhppj1b9bmytyldk9lt600000gp/T/AppTranslocation/1AE95969-E134-4286-9B52-BCFDC8FF82AD/d/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/Wire/WireKinetis.h:133: multiple definition of `Wire'
/private/var/folders/j0/_sxbhppj1b9bmytyldk9lt600000gp/T/AppTranslocation/1AE95969-E134-4286-9B52-BCFDC8FF82AD/d/Teensyduino.app/Contents/Java/hardware/tools/arm/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ld: Warning: size of symbol `Wire' changed from 20 in /var/folders/j0/_sxbhppj1b9bmytyldk9lt600000gp/T/arduino_build_778229/libraries/i2c_t3/i2c_t3.cpp.o to 108 in /var/folders/j0/_sxbhppj1b9bmytyldk9lt600000gp/T/arduino_build_778229/libraries/Wire/WireKinetis.cpp.o
collect2: error: ld returned 1 exit status
Error compiling for board Teensy 3.2 / 3.1.
