Results 1 to 3 of 3
Thread: nativeethernet not stable.
    When more connections are established, the library pauses every now and then.
    This stops the whole program for a few seconds.
    How can I fix that.
    I am using version 1.0.5
    Thanks in advance.
    Attached Files Attached Files
    Quote Originally Posted by Stanleyvc View Post
    How can I fix that.
    Thanks in advance.
    May I suggest trying QNEthernet instead? I had better luck and the developer (Shawn) is very responsive. Search the forum for th thread with releases.
    Jun 2018
    Berlin
    23
    Yes you should give QNEthernet a try. i had some timing issues with NativeEthernet and timer interrupt driven functions.
    With the use of QNEthernet these problems are gone.
