I am currently trying to create an 8-band equalizer with amplifier that uses 3.5mm input/output. I have attached a picture of my setup as well as my code at the end.
Currently, I am facing two problems. The first is that when testing a single band of the EQ, at higher gains I get really bad noise. Here is a sample of 1760Hz pure tone with the 1k-2kHz band being set to +10dB, then +45dB, then +30dB.
http://sndup.net/cgrp
Finally, when using the equalizer with a sample gain profile or from a friend who uses hearing aids, there is massive saturation going on. You can see this in the picture below:
The top is the raw audio and the bottom is filtered.
Can anyone shed some light as to what is going on?
https://i.imgur.com/m9Ce2IA.jpg
#include <Tympan_Library.h>
#include <U8g2lib.h>
#include <EEPROM.h>
#define B_RE(signal, state) (state=(state<<1)|signal)==B00001111
#define B_FE(signal, state) (state=(state<<1)|signal)==B11110000
//GLOBAL VARIABLES
int N_Bands = 8;
const float samplerate = 44100.0f ;
const int num_blocks = 128;
unsigned long PreviousMillis = 0;
const long interVal = 5;
int MenuIndex = 0;
int SelectionIndex = 10;
int InputHold = 0;
int ValueChanged = 0;
int InitialDraw = 1;
int ButtonPressed = 0;
byte ValB0, ValB1, ValB2, ValB3, ValB4, ValB5, ValB6, ValB7, ValA;
byte ButtonFalling, ButtonRising;
//CONSTRUCTORS
AudioSettings_F32 audio_settings(samplerate, num_blocks);
AudioInputI2S i2s_in;
AudioConvert_I16toF32 convertIN_L;
AudioConvert_I16toF32 convertIN_R;
AudioConvert_F32toI16 convertOUT_L;
AudioConvert_F32toI16 convertOUT_R;
AudioFilterbankBiquad_F32 filterbank_L(audio_settings);
AudioFilterbankBiquad_F32 filterbank_R(audio_settings);
AudioEffectGain_F32 gain_L[8];
AudioEffectGain_F32 gain_R[8];
AudioMixer8_F32 mixer_L(audio_settings);
AudioMixer8_F32 mixer_R(audio_settings);
AudioEffectGain_F32 gainFINAL_L;
AudioEffectGain_F32 gainFINAL_R;
AudioOutputI2S i2s_out;
U8G2_SSD1327_MIDAS_128X128_F_HW_I2C u8g2(U8G2_R0, U8X8_PIN_NONE);
//WIRE TIME
AudioConnection patchCord1(i2s_in, 0, convertIN_L, 0);
AudioConnection patchCord2(i2s_in, 1, convertIN_R, 0);
AudioConnection_F32 patchCord3(convertIN_L, 0, filterbank_L, 0);
AudioConnection_F32 patchCord4(convertIN_R, 0, filterbank_R, 0);
AudioConnection_F32 patchCord11(filterbank_L, 0, gain_L[0], 0);
AudioConnection_F32 patchCord12(filterbank_L, 1, gain_L[1], 0);
AudioConnection_F32 patchCord13(filterbank_L, 2, gain_L[2], 0);
AudioConnection_F32 patchCord14(filterbank_L, 3, gain_L[3], 0);
AudioConnection_F32 patchCord15(filterbank_L, 4, gain_L[4], 0);
AudioConnection_F32 patchCord16(filterbank_L, 5, gain_L[5], 0);
AudioConnection_F32 patchCord17(filterbank_L, 6, gain_L[6], 0);
AudioConnection_F32 patchCord18(filterbank_L, 7, gain_L[7], 0);
AudioConnection_F32 patchCord21(filterbank_R, 0, gain_R[0], 0);
AudioConnection_F32 patchCord22(filterbank_R, 1, gain_R[1], 0);
AudioConnection_F32 patchCord23(filterbank_R, 2, gain_R[2], 0);
AudioConnection_F32 patchCord24(filterbank_R, 3, gain_R[3], 0);
AudioConnection_F32 patchCord25(filterbank_R, 4, gain_R[4], 0);
AudioConnection_F32 patchCord26(filterbank_R, 5, gain_R[5], 0);
AudioConnection_F32 patchCord27(filterbank_R, 6, gain_R[6], 0);
AudioConnection_F32 patchCord28(filterbank_R, 7, gain_R[7], 0);
AudioConnection_F32 patchCord31(gain_L[0], 0, mixer_L, 0);
AudioConnection_F32 patchCord32(gain_L[1], 0, mixer_L, 1);
AudioConnection_F32 patchCord33(gain_L[2], 0, mixer_L, 2);
AudioConnection_F32 patchCord34(gain_L[3], 0, mixer_L, 3);
AudioConnection_F32 patchCord35(gain_L[4], 0, mixer_L, 4);
AudioConnection_F32 patchCord36(gain_L[5], 0, mixer_L, 5);
AudioConnection_F32 patchCord37(gain_L[6], 0, mixer_L, 6);
AudioConnection_F32 patchCord38(gain_L[7], 0, mixer_L, 7);
AudioConnection_F32 patchCord41(gain_R[0], 0, mixer_R, 0);
AudioConnection_F32 patchCord42(gain_R[1], 0, mixer_R, 1);
AudioConnection_F32 patchCord43(gain_R[2], 0, mixer_R, 2);
AudioConnection_F32 patchCord44(gain_R[3], 0, mixer_R, 3);
AudioConnection_F32 patchCord45(gain_R[4], 0, mixer_R, 4);
AudioConnection_F32 patchCord46(gain_R[5], 0, mixer_R, 5);
AudioConnection_F32 patchCord47(gain_R[6], 0, mixer_R, 6);
AudioConnection_F32 patchCord48(gain_R[7], 0, mixer_R, 7);
AudioConnection_F32 patchCord51(mixer_L, 0, gainFINAL_L, 0);
AudioConnection_F32 patchCord52(mixer_R, 0, gainFINAL_R, 0);
AudioConnection_F32 patchCord61(gainFINAL_L, 0, convertOUT_L, 0);
AudioConnection_F32 patchCord62(gainFINAL_R, 0, convertOUT_R, 0);
AudioConnection patchCord71(convertOUT_L, 0, i2s_out, 0);
AudioConnection patchCord72(convertOUT_R, 0, i2s_out, 1);
void u8g2_prepare(void) {
//buffer write preparation
//u8g2.setFont(u8g2_font_simple1_tf);
u8g2.setFont(u8g2_font_squeezed_r7_tr);
//u8g2.setFont(u8g2_font_5x8_tf);
u8g2.setFontRefHeightExtendedText();
u8g2.setDrawColor(1);
u8g2.setFontPosTop();
u8g2.setFontDirection(0);
void grab_eeprom(void){
//grab saved data from EEPROM
switch(MenuIndex){
case 0:
ValB0 = EEPROM.read(0);
if (ValB0 > 80){
ValB0 = 80;
ValB1 = EEPROM.read(1);
if (ValB1 > 80){
ValB1 = 80;
ValB2 = EEPROM.read(2);
if (ValB2 > 80){
ValB2 = 80;
ValB3 = EEPROM.read(3);
if (ValB3 > 80){
ValB3 = 80;
ValB4 = EEPROM.read(4);
if (ValB4 > 80){
ValB4 = 80;
ValB5 = EEPROM.read(5);
if (ValB5 > 80){
ValB5 = 80;
ValB6 = EEPROM.read(6);
if (ValB6 > 80){
ValB6 = 80;
ValB7 = EEPROM.read(7);
if (ValB7 > 80){
ValB7 = 80;
case 1:
ValA = EEPROM.read(8);
if (ValA > 80) {
ValA = 80;
void set_values(void) {
gain_L[0].setGain_dB(ValB0);
gain_L[1].setGain_dB(ValB1);
gain_L[2].setGain_dB(ValB2);
gain_L[3].setGain_dB(ValB3);
gain_L[4].setGain_dB(ValB4);
gain_L[5].setGain_dB(ValB5);
gain_L[6].setGain_dB(ValB6);
gain_L[7].setGain_dB(ValB7);
gain_R[0].setGain_dB(ValB0);
gain_R[1].setGain_dB(ValB1);
gain_R[2].setGain_dB(ValB2);
gain_R[3].setGain_dB(ValB3);
gain_R[4].setGain_dB(ValB4);
gain_R[5].setGain_dB(ValB5);
gain_R[6].setGain_dB(ValB6);
gain_R[7].setGain_dB(ValB7);
gainFINAL_L.setGain_dB(ValA);
gainFINAL_R.setGain_dB(ValA);
AudioMemory(12);
AudioMemory_F32(32);
sgtl5000_1.enable();
sgtl5000_1.adcHighPassFilterDisable();
sgtl5000_1.volume(0.5);
float crossfreq[N_Bands - 1]={125.0, 250.0, 500.0, 1000.0, 2000.0, 4000.0, 8000.0};
int test_L = filterbank_L.designFilters(N_Bands, 6, samplerate, num_blocks, crossfreq);
int test_R = filterbank_R.designFilters(N_Bands, 6, samplerate, num_blocks, crossfreq);
if (test_L < 0 || test_R < 0){
Serial.println("It broke :(");
else{
Serial.println("It didn't break :)");
pinMode(13, INPUT_PULLUP);
pinMode(38, INPUT_PULLUP);
pinMode(37, INPUT_PULLUP);
pinMode(36, INPUT_PULLUP);
Serial.println("Done!");
u8g2.begin();
//LOOP SPECIFIC VARIABLES
int D_Val = !(digitalRead(13));
int U_Val = !(digitalRead(36));
int R_Val = !(digitalRead(37));
int L_Val = !(digitalRead(38));
unsigned long CurrentMillis = millis();
static unsigned long PreviousDebounce;
//DRAW DISPLAY + UPDATE VALUES)
if ((CurrentMillis - PreviousMillis >= interVal) && ((ValueChanged == 1) || (InitialDraw == 1))) {
PreviousMillis = CurrentMillis;
Serial.println(PreviousMillis);
grab_eeprom();
set_values();
u8g2.clearBuffer();
u8g2_prepare();
switch(MenuIndex){
case 0:
u8g2.drawStr( 0, -1, "Equalizer (dB)");
u8g2.drawStr( 90, -1, "Next Menu");
u8g2.drawHLine(0, 9, 128);
u8g2.drawBox(1, (107 - (ValB0 + 1)),14,(ValB0 + 1));
u8g2.drawBox(17,(107 - (ValB1 + 1)),14,(ValB1 + 1));
u8g2.drawBox(33,(107 - (ValB2 + 1)),14,(ValB2 + 1));
u8g2.drawBox(49,(107 - (ValB3 + 1)),14,(ValB3 + 1));
u8g2.drawBox(65,(107 - (ValB4 + 1)),14,(ValB4 + 1));
u8g2.drawBox(81,(107 - (ValB5 + 1)),14,(ValB5 + 1));
u8g2.drawBox(97,(107 - (ValB6 + 1)),14,(ValB6 + 1));
u8g2.drawBox(113,(107 - (ValB7 + 1)),14,(ValB7 + 1));
u8g2.drawHLine(0, 107, 128);
u8g2.setCursor(5, 109);
u8g2.print(ValB0);
u8g2.setCursor(21, 109);
u8g2.print(ValB1);
u8g2.setCursor(37, 109);
u8g2.print(ValB2);
u8g2.setCursor(53, 109);
u8g2.print(ValB3);
u8g2.setCursor(69, 109);
u8g2.print(ValB4);
u8g2.setCursor(85, 109);
u8g2.print(ValB5);
u8g2.setCursor(101, 109);
u8g2.print(ValB6);
u8g2.setCursor(117, 109);
u8g2.print(ValB7);
u8g2.drawHLine(0, 118, 128);
u8g2.drawStr(12, 120, "125");
u8g2.drawStr(28, 120, "250");
u8g2.drawStr(43, 120, "500");
u8g2.drawStr(61, 120, "1k");
u8g2.drawStr(78, 120, "2k");
u8g2.drawStr(94, 120, "4k");
u8g2.drawStr(110, 120, "8k");
switch(SelectionIndex) {
case 0: u8g2.drawTriangle(4,(107 - (ValB0 + 1) - 6), 12,(107 - (ValB0 + 1) - 6), 8,(107 - (ValB0 + 1) - 2)); break;
case 1: u8g2.drawTriangle(20,(107 - (ValB1 + 1) - 6), 28,(107 - (ValB1 + 1) - 6), 24,(107 - (ValB1 + 1) - 2)); break;
case 2: u8g2.drawTriangle(36,(107 - (ValB2 + 1) - 6), 44,(107 - (ValB2 + 1) - 6), 40,(107 - (ValB2 + 1) - 2)); break;
case 3: u8g2.drawTriangle(52,(107 - (ValB3 + 1) - 6), 60,(107 - (ValB3 + 1) - 6), 56,(107 - (ValB3 + 1) - 2)); break;
case 4: u8g2.drawTriangle(68,(107 - (ValB4 + 1) - 6), 76,(107 - (ValB4 + 1) - 6), 72,(107 - (ValB4 + 1) - 2)); break;
case 5: u8g2.drawTriangle(84,(107 - (ValB5 + 1) - 6), 92,(107 - (ValB5 + 1) - 6), 88,(107 - (ValB5 + 1) - 2)); break;
case 6: u8g2.drawTriangle(100,(107 - (ValB6 + 1) - 6), 108,(107 - (ValB6 + 1) - 6), 104,(107 - (ValB6 + 1) - 2)); break;
case 7: u8g2.drawTriangle(116,(107 - (ValB7 + 1) - 6), 124,(107 - (ValB7 + 1) - 6), 120,(107 - (ValB7 + 1) - 2)); break;
case 10: u8g2.drawTriangle(85,0, 85,8, 89,4); break;
case 1:
u8g2.drawStr(0, -1, "Amplifier (dB)");
u8g2.drawStr(90, -1, "Next Menu");
u8g2.setCursor(0, 12);
u8g2.print(ValA);
u8g2.drawBox(24,52,ValA,10);
u8g2.drawVLine(24, 50, 14);
u8g2.drawVLine(104, 50, 14);
case 0: u8g2.drawTriangle((21 + ValA), 47, (27 + ValA),47, (24 + ValA),50); break;
u8g2.sendBuffer();
InitialDraw = 0;
ValueChanged = 0;
if (CurrentMillis - PreviousDebounce >= interVal) {
PreviousDebounce = CurrentMillis;
if (B_RE((D_Val || U_Val || R_Val || L_Val), ButtonRising)) {
Serial.print ("Rising edge (button depressed) StateVar: ");
Serial.println (ButtonRising);
ButtonPressed = 1;
if (B_FE((D_Val || U_Val || R_Val || L_Val), ButtonFalling)) {
Serial.print ("Falling edge (button released) StateVar: ");
Serial.println (ButtonFalling);
//NAVIGATION AND VALUE CHANGE
if (ButtonPressed == 1){
switch(MenuIndex){
case 0:
if (D_Val == 1 && InputHold == 0){
InputHold = 1;
case 0: ValB0 = ValB0 - 1; EEPROM.write(0, ValB0); ValueChanged = 1; break;
case 1: ValB1 = ValB1 - 1; EEPROM.write(1, ValB1); ValueChanged = 1; break;
case 2: ValB2 = ValB2 - 1; EEPROM.write(2, ValB2); ValueChanged = 1; break;
case 3: ValB3 = ValB3 - 1; EEPROM.write(3, ValB3); ValueChanged = 1; break;
case 4: ValB4 = ValB4 - 1; EEPROM.write(4, ValB4); ValueChanged = 1; break;
case 5: ValB5 = ValB5 - 1; EEPROM.write(5, ValB5); ValueChanged = 1; break;
case 6: ValB6 = ValB6 - 1; EEPROM.write(6, ValB6); ValueChanged = 1; break;
case 7: ValB7 = ValB7 - 1; EEPROM.write(7, ValB7); ValueChanged = 1; break;
case 10: break;
if (U_Val == 1 && InputHold == 0){
InputHold = 1;
case 0: ValB0 = ValB0 + 1; EEPROM.write(0, ValB0); ValueChanged = 1; break;
case 1: ValB1 = ValB1 + 1; EEPROM.write(1, ValB1); ValueChanged = 1; break;
case 2: ValB2 = ValB2 + 1; EEPROM.write(2, ValB2); ValueChanged = 1; break;
case 3: ValB3 = ValB3 + 1; EEPROM.write(3, ValB3); ValueChanged = 1; break;
case 4: ValB4 = ValB4 + 1; EEPROM.write(4, ValB4); ValueChanged = 1; break;
case 5: ValB5 = ValB5 + 1; EEPROM.write(5, ValB5); ValueChanged = 1; break;
case 6: ValB6 = ValB6 + 1; EEPROM.write(6, ValB6); ValueChanged = 1; break;
case 7: ValB7 = ValB7 + 1; EEPROM.write(7, ValB7); ValueChanged = 1; break;
case 10: MenuIndex = 1; ValueChanged = 1; break;
if (R_Val == 1 && InputHold == 0){
InputHold = 1;
case 7: SelectionIndex = 10; ValueChanged = 1; break;
case 10: SelectionIndex = 7; ValueChanged = 1; break;
default: SelectionIndex = SelectionIndex + 1; ValueChanged = 1; break;
if (L_Val == 1 && InputHold == 0){
InputHold = 1;
case 0: SelectionIndex = 10; ValueChanged = 1; break;
case 10: SelectionIndex = 0; ValueChanged = 1; break;
default: SelectionIndex = SelectionIndex - 1; ValueChanged = 1; break;
case 1:
InputHold = 1;
switch(SelectionIndex){
case 0: break;
InputHold = 1;
case 10: MenuIndex = 0; ValueChanged = 1; break;
InputHold = 1;
case 0: ValA = ValA + 1; EEPROM.write(8, ValA); ValueChanged = 1; break;
case 10: break;
InputHold = 1;
case 0: ValA = ValA - 1; EEPROM.write(8, ValA); ValueChanged = 1; break;
case 10: break;
InputHold = 0;
ButtonPressed = 0;
