BriComp
// Wire Master Reader
// by Nicholas Zambetti <http://www.zambetti.com>
// Demonstrates use of the Wire library
// Reads data from an I2C/TWI slave device
// Refer to the "Wire Slave Sender" example for use with this
// Created 29 March 2006
int led = LED_BUILTIN;
pinMode(led, OUTPUT);
Wire1.begin(); // join i2c bus (address optional for master)
Serial.begin(9600); // start serial for output
Serial.print("read: ");
digitalWrite(led, HIGH); // briefly flash the LED
Wire1.requestFrom(8, 6); // request 6 bytes from slave device #8
while(Wire1.available()) { // slave may send less than requested
char c = Wire1.read(); // receive a byte as character
Serial.print(c); // print the character
digitalWrite(led, LOW);
Can anyone help with this or is there a problem with the Wire Library?
EDIT: Ignore above, just seen Paul's post about editing WireKinetis.h.
