4.9175997 , SETUP , 0x0 , 0x0 , <GET_DESCRIPTOR - DEVICE #:0 I:0x0 L:0x8> , 0x80 0x6 0x0 0x1 0x0 0x0 0x8 0x0
4.91790898 , IN , 0x0 , 0x0 , , 0x12 0x1 0x10 0x1 0x0 0x0 0x0 0x8
4.91867734 , SETUP , 0x0 , 0x0 , <SET_ADDRESS I:0x0 L:0x0> , 0x0 0x5 0x1 0x0 0x0 0x0 0x0 0x0
4.91967736 , SETUP , 0x0 , 0x1 , <GET_DESCRIPTOR - DEVICE #:0 I:0x0 L:0x12> , 0x80 0x6 0x0 0x1 0x0 0x0 0x12 0x0
4.91998648 , IN , 0x0 , 0x1 , , 0x12 0x1 0x10 0x1 0x0 0x0 0x0 0x8
4.92021352 , IN , 0x0 , 0x1 , , 0x3c 0x41 0x13 0x21 0x10 0x1 0x0 0x2
4.92040048 , IN , 0x0 , 0x1 , , 0x0 0x1
4.92167736 , SETUP , 0x0 , 0x1 , <GET_DESCRIPTOR - STRING #:0 I:0x0 L:0x7fc> , 0x80 0x6 0x0 0x3 0x0 0x0 0xfc 0x7
4.9219868 , IN , 0x0 , 0x1 , , 0x4 0x3 0x9 0x4
4.92267738 , SETUP , 0x0 , 0x1 , <GET_DESCRIPTOR - STRING #:2 I:0x409 L:0x7fc> , 0x80 0x6 0x2 0x3 0x9 0x4 0xfc 0x7
4.92302714 , IN , 0x0 , 0x1 , , 0x34 0x3 0x44 0x0 0x65 0x0 0x6c 0x0
4.92325416 , IN , 0x0 , 0x1 , , 0x6c 0x0 0x20 0x0 0x4b 0x0 0x42 0x0
4.92359974 , IN , 0x0 , 0x1 , , 0x32 0x0 0x31 0x0 0x36 0x0 0x20 0x0
4.92382768 , IN , 0x0 , 0x1 , , 0x57 0x0 0x69 0x0 0x72 0x0 0x65 0x0
4.92405538 , IN , 0x0 , 0x1 , , 0x64 0x0 0x20 0x0 0x4b 0x0 0x65 0x0
4.9242824 , IN , 0x0 , 0x1 , , 0x79 0x0 0x62 0x0 0x6f 0x0 0x61 0x0
4.92459974 , IN , 0x0 , 0x1 , , 0x72 0x0 0x64 0x0
4.92567738 , SETUP , 0x0 , 0x1 , <GET_DESCRIPTOR - CONFIG #:0 I:0x0 L:0x9> , 0x80 0x6 0x0 0x2 0x0 0x0 0x9 0x0
4.92598636 , IN , 0x0 , 0x1 , , 0x9 0x2 0x3b 0x0 0x2 0x1 0x0 0xa0
4.92613326 , IN , 0x0 , 0x1 , , 0x32
4.9266774 , SETUP , 0x0 , 0x1 , <GET_DESCRIPTOR - CONFIG #:0 I:0x0 L:0x3b> , 0x80 0x6 0x0 0x2 0x0 0x0 0x3b 0x0
4.92698616 , IN , 0x0 , 0x1 , , 0x9 0x2 0x3b 0x0 0x2 0x1 0x0 0xa0
4.9272132 , IN , 0x0 , 0x1 , , 0x32 0x9 0x4 0x0 0x0 0x1 0x3 0x1
4.92744026 , IN , 0x0 , 0x1 , , 0x1 0x0 0x9 0x21 0x11 0x1 0x0 0x1
4.9276399 , IN , 0x0 , 0x1 , , 0x22 0x41 0x0 0x7 0x5 0x81 0x3 0x8
4.92786692 , IN , 0x0 , 0x1 , , 0x0 0x18 0x9 0x4 0x1 0x0 0x1 0x3
4.92809396 , IN , 0x0 , 0x1 , , 0x0 0x0 0x0 0x9 0x21 0x11 0x1 0x0
4.928321 , IN , 0x0 , 0x1 , , 0x1 0x22 0x6d 0x0 0x7 0x5 0x82 0x3
4.92859978 , IN , 0x0 , 0x1 , , 0x8 0x0 0x30
4.9296774 , SETUP , 0x0 , 0x1 , <SET_CONFIGURATION I:0x0 L:0x0> , 0x0 0x9 0x1 0x0 0x0 0x0 0x0 0x0
4.93067742 , SETUP , 0x0 , 0x1 , <HID SET_IDLE I:0x0 L:0x0> , 0x21 0xa 0x0 0x0 0x0 0x0 0x0 0x0
4.93092934 , SETUP , 0x0 , 0x1 , <GET_DESCRIPTOR - HID REPORT I:0x1 L:0x6d> , 0x81 0x6 0x0 0x22 0x1 0x0 0x6d 0x0
4.93127802 , IN , 0x0 , 0x1 , , 0x5 0x1 0x9 0x80 0xa1 0x1 0x85 0x1
4.93159978 , IN , 0x0 , 0x1 , , 0x19 0x81 0x29 0x83 0x15 0x0 0x25 0x1
4.93182746 , IN , 0x0 , 0x1 , , 0x75 0x1 0x95 0x3 0x81 0x2 0x75 0x5
4.93205448 , IN , 0x0 , 0x1 , , 0x95 0x1 0x81 0x1 0xc0 0x5 0xc 0x9
4.93228152 , IN , 0x0 , 0x1 , , 0x1 0xa1 0x1 0x85 0x2 0xa 0xb5 0x0
4.9325998 , IN , 0x0 , 0x1 , , 0xa 0xb6 0x0 0xa 0xb7 0x0 0xa 0x83
4.932826960000001 , IN , 0x0 , 0x1 , , 0x1 0xa 0xcd 0x0 0xa 0xe9 0x0 0xa
4.933054 , IN , 0x0 , 0x1 , , 0xea 0x0 0xa 0xe2 0x0 0xa 0x24 0x2
4.933281020000001 , IN , 0x0 , 0x1 , , 0xa 0x8a 0x1 0xa 0x25 0x2 0xa 0x23
4.9336403 , IN , 0x0 , 0x1 , , 0x2 0xa 0x21 0x2 0xa 0x26 0x2 0xa
4.9338672 , IN , 0x0 , 0x1 , , 0x27 0x2 0xa 0x2a 0x2 0xa 0x92 0x1
4.93409424 , IN , 0x0 , 0x1 , , 0xa 0x94 0x1 0x9 0xb8 0xa 0xa7 0x1
4.9343226 , IN , 0x0 , 0x1 , , 0x75 0x1 0x95 0x14 0x81 0x2 0x75 0x1
4.9345998 , IN , 0x0 , 0x1 , , 0x95 0x4 0x81 0x1 0xc0
Where I often will simply paste into Excel... Used to think I needed to save t file and then import from text/csv, but recently found I could simply paste it in, and then in Data tab use the Text to columns button...
