VS1053b audio codec - no audio output
thecomfychair
I am trying to play audio from the Teensy 4.1's SD card with a VS1053b audio codec chip. I am using the library from Tobias van Dyk, who has ported the Adafruit library into a single sketch version for the T3.6 and T4.1 (super helpful, thanks Tobias!).
The breakout board that I'm using is from Aliexpress rather than Adafruit, since I don't need the spare SD card slot. It looks like this:
The library compiles and runs fine on my T4.1 (after commenting out any references to SREG). However I hear no audio through the headphone jack, just low-level white noise.
I added some debug printouts and it's not clear whether it gets past opening the audio file in the setup() function - often it doesn't make it to loop(). It doesn't seem to be any memory overruns or anything like that though, since the T4.1 stays running and doesn't reset.
I tried changing the volume values too, but this had no effect.
This is the same with two identical VS1053b breakout boards (I bought two just in case).
This is my current sketch. I have modified it slightly to change the pins used for XRST, XCS, XDCS, and XDREQ, as the pins specified in the example are already used in the project that I am trying to integrate this module into. However, I think I have taken care to select new pins with the same characteristics?
//https://github.com/TobiasVanDyk/VS1053B-Teensy36-Teensy41-SDCard-Music-Player
// Modified for Teensy 3.6 Tobias van Dyk October 2020
// Also based on PJRC.com Teensy libraries
  This is a library for the Adafruit VS1053 Codec Breakout
  Designed specifically to work with the Adafruit VS1053 Codec Breakout
  ----> https://www.adafruit.com/products/1381
  products from Adafruit!
  BSD license, all text above must be included in any redistribution
#include <Arduino.h>
// Connect SCLK, MISO and MOSI to standard hardware SPI pins.
#define SCLK 13       // SPI Clock shared with SD card
//#define MISO 12       // Input data from vs1053 or SD card
//#define MOSI 11       // Output data to vs1053 or SD card
// These are the pins used for the Adafruit vs1053B breakout module
#define XRST  33                // vs1053 reset (output)
#define XCS   36               // vs1053 chip select (output)
#define XDCS  35                // vs1053 Data select (output)
#define XDREQ 34                // vs1053 Data Ready an Interrupt pin (input)
#define SDCS  BUILTIN_SDCARD   // Use Teensy built-in card
// For Teensy 3.5, 3.6, 4.0, 4.1 better to use its built-in SDCard
//#define SDCS 4                // Use vs1053 SDCard Card chip select pin
// vs1053B.h
#define vs1053_FILEPLAYER_TIMER0_INT 255 // allows useInterrupt to accept pins 0 to 254
#define vs1053_FILEPLAYER_PIN_INT 5      // Interrupt number from dreqinttable dreq pin # = 3
#define vs1053_SCI_READ 0x03
#define vs1053_SCI_WRITE 0x02
#define vs1053_REG_MODE  0x00
#define vs1053_REG_STATUS 0x01
#define vs1053_REG_BASS 0x02
#define vs1053_REG_CLOCKF 0x03
#define vs1053_REG_DECODETIME 0x04
#define vs1053_REG_AUDATA 0x05
#define vs1053_REG_WRAM 0x06
#define vs1053_REG_WRAMADDR 0x07
#define vs1053_REG_HDAT0 0x08
#define vs1053_REG_HDAT1 0x09
#define vs1053_REG_VOLUME 0x0B
#define vs1053_GPIO_DDR 0xC017
#define vs1053_GPIO_IDATA 0xC018
#define vs1053_GPIO_ODATA 0xC019
#define vs1053_INT_ENABLE  0xC01A
#define vs1053_MODE_SM_DIFF 0x0001
#define vs1053_MODE_SM_LAYER12 0x0002
#define vs1053_MODE_SM_RESET 0x0004
#define vs1053_MODE_SM_CANCEL 0x0008
#define vs1053_MODE_SM_EARSPKLO 0x0010
#define vs1053_MODE_SM_TESTS 0x0020
#define vs1053_MODE_SM_STREAM 0x0040
#define vs1053_MODE_SM_SDINEW 0x0800
#define vs1053_MODE_SM_ADPCM 0x1000
#define vs1053_MODE_SM_LINE1 0x4000
#define vs1053_MODE_SM_CLKRANGE 0x8000
#define vs1053_SCI_AIADDR 0x0A
#define vs1053_SCI_AICTRL0 0x0C
#define vs1053_SCI_AICTRL1 0x0D
#define vs1053_SCI_AICTRL2 0x0E
#define vs1053_SCI_AICTRL3 0x0F
#define vs1053_DATABUFFERLEN 32
File currentTrack;
boolean playingMusic;
uint8_t SoundBuffer[vs1053_DATABUFFERLEN];
// vs1053B.cpp
#define vs1053_CONTROL_SPI_SETTING  SPISettings(250000,  MSBFIRST, SPI_MODE0) // 2.5 MHz SPI speed Control
#define vs1053_DATA_SPI_SETTING     SPISettings(8000000, MSBFIRST, SPI_MODE0) // 8 MHz SPI speed Data
// Configure interrupt for Data XDREQ from vs1053
// XDREQ is low while the receive buffer is full
void vs1053Interrupt()
{ SPI.usingInterrupt(XDREQ);                          // Disable Interrupt during SPI transactions
  attachInterrupt(XDREQ, vs1053FeedBuffer, CHANGE);   // Interrupt on Pin XDREQ state change
}                                                    // feeder->feedBuffer executed (lines 26, 209)
// Set the card to be disabled while we get the vs1053 up
void vs1053DisableCard ()
{ playingMusic = false;
  pinMode(SDCS, OUTPUT);
  digitalWrite(SDCS, HIGH);
// Play file without interrupts
boolean vs1053PlayFullFile(const char *trackname) {
  Serial.print("Playing ");
  Serial.println(trackname);
   if (! vs1053StartPlayingFile(trackname)) return false;
    while (playingMusic) { vs1053FeedBuffer(); }
    return true;
void vs1053StopPlaying()
  currentTrack.close();
void vs1053PausePlaying(boolean pause)
{ if (pause) playingMusic = false; else { playingMusic = true; vs1053FeedBuffer(); }
boolean vs1053Paused()
{ return (!playingMusic && currentTrack);
boolean vs1053Stopped()
{ return (!playingMusic && !currentTrack);
boolean vs1053StartPlayingFile(const char *trackname)  {
    Serial.println("vs1053StartPlayingFile");
    currentTrack = SD.open(trackname);
    if (!currentTrack) {
      Serial.print("Failed to open from SD: ");
      return false;
      else{
        Serial.print("Opened from SD: ");
    while (!vs1053ReadyForData() );                                    // wait for ready for data
    while (playingMusic && vs1053ReadyForData()) vs1053FeedBuffer();   // then send data
    return true;
void vs1053FeedBuffer() { //debugging this function causes memory overruns
//  Serial.println("vs1053FeedBuffer");
  static uint8_t running = 0;
  uint8_t sregsave;
  // Do not allow 2 FeedBuffer instances to run concurrently
  // SREG bit 7 = OFF => no interrupts until bit 7 = ON
//  sregsave = SREG; // Status Register can clear/set interrupt enable bit 7 cli or sei
  cli();           // Clear interrupt enable bit 7 in SREG => disable interrupts
//  if (running) { SREG = sregsave; return; } else { running = 1; SREG = sregsave;  }
  // paused or stopped. no SDCard track open, XDREQ=0 receive buffer full
  if ((!playingMusic)||(!currentTrack)||(!vs1053ReadyForData())) { running = 0; return; }
//  if (!playingMusic){
//    Serial.println("Paused or stopped");
//    running = 0; return;
//  if (!currentTrack){
//    Serial.println("No track open from SD card");
//  if(!vs1053ReadyForData()){
//    Serial.println("XDREQ=0 receive buffer full");
//  Serial.println("Ready to send buffer");
  // Send buffer
  while (vs1053ReadyForData())
        { int bytesread = currentTrack.read(SoundBuffer, vs1053_DATABUFFERLEN);
          if (bytesread == 0)           // End of File
               running = 0;
               return;
          vs1053PlayData(SoundBuffer, bytesread);
  running = 0;
  return;
// XDREQ is true while the receive buffer has space
boolean vs1053ReadyForData()
{ return digitalRead(XDREQ);
void vs1053PlayData(uint8_t *buffer, uint8_t buffsiz)
{ SPI.beginTransaction(vs1053_DATA_SPI_SETTING);
  digitalWrite(XDCS, LOW);
  for (uint8_t i=0; i<buffsiz; i++) { vs1053SpiWrite(buffer[i]); }  // buffsiz = 32
  digitalWrite(XDCS, HIGH);
  SPI.endTransaction();
void vs1053SetVolume(uint8_t left, uint8_t right)
{ uint16_t v;
  v = left;
  v <<= 8;
  v |= right;
  cli();
  vs1053SciWrite(vs1053_REG_VOLUME, v);
  sei();
uint16_t vs1053DecodeTime()
{ cli();
  uint16_t t = vs1053SciRead(vs1053_REG_DECODETIME);
  sei();
  return t;
void vs1053SoftReset()
{ vs1053SciWrite(vs1053_REG_MODE, vs1053_MODE_SM_SDINEW | vs1053_MODE_SM_RESET);
void vs1053Reset()
{ if (XRST >= 0)
     { digitalWrite(XRST, LOW);
       digitalWrite(XRST, HIGH);
  digitalWrite(XCS, HIGH);
  vs1053SoftReset();
  vs1053SciWrite(vs1053_REG_CLOCKF, 0x6000);
  vs1053SetVolume(40, 40);
uint8_t vs1053Begin()
{ if (XRST >= 0) { pinMode(XRST, OUTPUT);  // if reset = -1 ignore
  pinMode(XCS, OUTPUT);
  pinMode(XDCS, OUTPUT);
  pinMode(XDREQ, INPUT);
  SPI.begin();
//  SPI.setDataMode(SPI_MODE0);
//  SPI.setBitOrder(MSBFIRST);
//  SPI.setClockDivider(SPI_CLOCK_DIV128);
  vs1053Reset();
  return (vs1053SciRead(vs1053_REG_STATUS) >> 4) & 0x0F;
uint16_t vs1053SciRead(uint8_t addr)
{ uint16_t data;
  SPI.beginTransaction(vs1053_CONTROL_SPI_SETTING);
  digitalWrite(XCS, LOW);
  vs1053SpiWrite(vs1053_SCI_READ);
  vs1053SpiWrite(addr);
  delayMicroseconds(10);
  data = vs1053SpiRead();
  data <<= 8;
  data |= vs1053SpiRead();
  return data;
void vs1053SciWrite(uint8_t addr, uint16_t data)
{ SPI.beginTransaction(vs1053_CONTROL_SPI_SETTING);
  vs1053SpiWrite(vs1053_SCI_WRITE);
  vs1053SpiWrite(data >> 8);
  vs1053SpiWrite(data & 0xFF);
static volatile uint8_t *clkportreg;
static uint8_t clkpin;
uint8_t vs1053SpiRead()
{ int8_t x;
  x = 0;
  //clkportreg = portOutputRegister(digitalPinToPort(SCLK));
  //clkpin = digitalPinToBitMask(SCLK);
  // MSB first, clock low when inactive (CPOL 0), data valid on leading edge (CPHA 0)
  // Make sure clock starts low
  x = SPI.transfer(0x00);
  // Make sure clock ends low
  //*clkportreg &= ~clkpin;
  return x;
void vs1053SpiWrite(uint8_t c)
{ // MSB first, clock low when inactive (CPOL 0), data valid on leading edge (CPHA 0)
  SPI.transfer(c);
  //*clkportreg &= ~clkpin;   // Make sure clock ends low
// End .cpp
  while (!Serial) ; // wait for Arduino Serial Monitor
  Serial.println("Adafruit vs1053B SDCard Music Player Test");
  if (! vs1053Begin()) { // initialise the music player
     Serial.println(F("Couldn't find vs1053"));
     while (1);
  Serial.println(F("vs1053 found"));
  SD.begin(SDCS);    // initialise the SD card
  // Set volume for left, right channels. lower numbers is higher volume
  vs1053SetVolume(20,20);
  // If XDREQ is on an interrupt pin (any Teensy pin) can do background audio playing
  vs1053Interrupt();  // XDREQ int
  // Play one file, don't return until complete - i.e. serial "s" or "p" will not interrupt
  //Serial.println(F("Playing track 001"));
  //vs1053PlayFullFile("track001.mp3");
//  Serial.println(F("Playing track 008"));
//  vs1053PlayFullFile("track008.wav");
//  Serial.println(F("Playing SDTEST with super long file name.wav"));
//  vs1053PlayFullFile("/SDTEST with super long file name.wav");
  // Play another file in the background, use interrupt serial "s" or "p" will interrupt
  // Can only do one buffer feed at a time
  //Serial.println(F("Playing track 002 - press p to pause, s to stop"));
  //vs1053StartPlayingFile("track002.mp3");
//  Serial.println(F("Playing track 010 - press p to pause, s to stop"));
//  vs1053StartPlayingFile("track010.wav");
  Serial.println(F("Playing /MusicBee/Music/Deadmau5/4x4=12/09 - Raise Your Weapon (Original Mix).mp3 - press p to pause, s to stop"));
  vs1053StartPlayingFile("/MusicBee/Music/Deadmau5/4x4=12/09 - Raise Your Weapon (Original Mix).mp3");
  if(playingMusic){
    Serial.println("Playback started");
  else{ Serial.println("Playback failed");}
  // File is playing in the background
  if (vs1053Stopped()) {
    Serial.println("Terminated");
    while (1);
  if (Serial.available()) {
    char c = Serial.read();
    // if we get an 's' on the serial console, stop!
    if (c == 's') {
      vs1053StopPlaying();
    // if we get an 'p' on the serial console, pause/unpause!
    if (c == 'p') {
      if (! vs1053Paused()) {
        Serial.println("Pause - press p to pause, s to stop");
        vs1053PausePlaying(true);
        Serial.println("Resumed - press p to pause, s to stop");
        vs1053PausePlaying(false);
  Serial.println("Loop running");
Serial debug is as follows:
vs1053 found
Opened from SD: /MusicBee/Music/Deadmau5/4x4=12/09 - Raise Your Weapon (Original Mix).mp3
Has anyone else worked with the VS1053b before, and know if there are any other commands or hardware requirements that need to be implemented to get sound out?
Arduino 1.8.19, TD 1.56
Keep all your connections as is and install the newest Adafruit VS1023 library - then try the player_simple.ino example in the new library after making the pin changes to what you have. Also check if if you comment out the IRQ part in the example if you can get sound out.
Also look at the VS1053 Pico port on the same github - it is really a minimal amount of code needed to get the vs1053 playing - try to convert that example for your Teensy and vs1053 board. The reason for including the vs1053 library in the 2020 example code may have been solved by the newer adafruit vs1053 library.
Looks like vs1053FeedBuffer() disables interrupts, but never re-enables them. Commented out code involving SREG was probably restoring interrupts to working order.
I found my old Adafruit VS1053 board and connected a Teensy 4.1.
(click for full size)
Here is a copy of the code with vs1053FeedBuffer() slightly modified. It also has the pin numbers changed for the wiring you see in the photos above, and accessing the SD card over SPI on the Adafruit board. Also changed the filename to match what I had already on this SD card.
I'm listening to it play as I type this message. :) Hopefully this helps?
#define XRST  9                // vs1053 reset (output)
#define XCS   10               // vs1053 chip select (output)
#define XDCS  8                // vs1053 Data select (output)
#define XDREQ 3                // vs1053 Data Ready an Interrupt pin (input)
//#define SDCS  BUILTIN_SDCARD   // Use Teensy built-in card
// vs1053B.h
File currentTrack;
// vs1053B.cpp
    vs1053FeedBuffer();
  return true;
    vs1053FeedBuffer();
    return false;
  else {
  return true;
  uint8_t sregsave;
  noInterrupts();           // Clear interrupt enable bit 7 in SREG => disable interrupts
  if ((!playingMusic) || (!currentTrack) || (!vs1053ReadyForData())) {
    running = 0;
    interrupts();
    return;
  interrupts();
  // Send buffer
      running = 0;
      return;
  running = 0;
  return;
  for (uint8_t i = 0; i < buffsiz; i++) {
    vs1053SpiWrite(buffer[i]);  // buffsiz = 32
{ uint16_t v;
  v = left;
  v <<= 8;
  v |= right;
  cli();
  sei();
{ cli();
  sei();
  return t;
void vs1053Reset()
{ if (XRST >= 0)
  vs1053SoftReset();
{ if (XRST >= 0) {
  SPI.begin();
  vs1053Reset();
{ uint16_t data;
  data <<= 8;
  return data;
{ int8_t x;
  x = 0;
  return x;
  SPI.transfer(c);
// End .cpp
    while (1);
  vs1053SetVolume(20, 20);
  Serial.println(F("Playing track001.mp3 - press p to pause, s to stop"));
  vs1053StartPlayingFile("track001.mp3");
  if (playingMusic) {
  else {
    while (1);
    if (c == 's') {
    if (c == 'p') {
This works perfectly, thank you very much Paul!
For anyone using the onboard SD reader on the T4.1, don't forget to switch the SCDS definition back to BUILTIN_SDCARD.
Part of my issue may have been the file I was using for testing. It's a WAV file that plays fine on my Windows machine, and I have had it working through a PCM5012 in the past. Not sure what the difference here is, but when the VS1053 tries to open it, the whole program seems to hang.
Could be a specific format thing. I remember seeing that there are some patches for the VS1053 that VSI have put out, but unfortunately their website seems to be down at the moment so I can't test or see the notes to understand what the patches fixed. I'll investigate this further and update if I find a solution.
Meantime, if you're struggling to get audio using Paul's example, try a different file!
