Results 1 to 1 of 1
Thread: Teensy guestbook - No sound when play wav file on my computer
    Hi everyone!
    I am new here and I am with a problem with my project for weeks, any help will be appreciated.
    I'm trying to make a guestbook with a rotary phone like that: https://www.youtube.com/watch?v=dI6ielrP1SE, my issue is that I can't hear audio when I play the wav, the file has size and the player time is running, I tried many things, I tested with 3 different microphones, connections look good, serial monitor look ok as well, the greeting message is ok. I don't know if I need a specific microphone or some connection is wrong, I really appreciate some help guys. If you need more information, images or any specific thing please let me know, since now thanks.
    I am using teensy 4.0 and the audio board Rev D.
    Code is here: https://github.com/playfultechnology...-guestbook.ino
     * Audio Guestbook, Copyright (c) 2022 Playful Technology
     * Tested using a Teensy 4.0 with Teensy Audio Shield, although should work
     * with minor modifications on other similar hardware
     * When handset is lifted, a pre-recorded greeting message is played, followed by a tone.
     * Then, recording starts, and continues until the handset is replaced.
     * Playback button allows all messages currently saved on SD card through earpiece
     * Files are saved on SD card as 44.1kHz, 16-bit, mono signed integer RAW audio format
     * --> changed this to WAV recording, DD4WH 2022_07_31
     * --> added MTP support, which enables copying WAV files from the SD card via the USB connection, DD4WH 2022_08_01
     * Frank DD4WH, August 1st 2022
     * for a DBP 611 telephone (closed contact when handheld is lifted) & with recording to WAV file
     * contact for switch button 0 is closed when handheld is lifted
     * GNU GPL v3.0 license
    #include <Bounce.h>
    #include <TimeLib.h>
    #include <MTP_Teensy.h>
    // DEFINES
    // Define pins used by Teensy Audio Shield
    #define SDCARD_CS_PIN 10
    #define SDCARD_MOSI_PIN 7
    #define SDCARD_SCK_PIN 14
    // And those used for inputs
    #define HOOK_PIN 0
    // GLOBALS
    // Audio initialisation code can be generated using the GUI interface at https://www.pjrc.com/teensy/gui/
    // Inputs
    AudioSynthWaveform waveform1;                       // To create the "beep" sfx
    AudioInputI2S i2s2;                                 // I2S input from microphone on audio shield
    AudioPlaySdWav playWav1;                            // Play 44.1kHz 16-bit PCM greeting WAV file
    AudioRecordQueue queue1;                            // Creating an audio buffer in memory before saving to SD
    AudioMixer4 mixer;                                  // Allows merging several inputs to same output
    AudioOutputI2S i2s1;                                // I2S interface to Speaker/Line Out on Audio shield
    AudioConnection patchCord1(waveform1, 0, mixer, 0); // wave to mixer
    AudioConnection patchCord3(playWav1, 0, mixer, 1);  // wav file playback mixer
    AudioConnection patchCord4(mixer, 0, i2s1, 0);      // mixer output to speaker (L)
    AudioConnection patchCord6(mixer, 0, i2s1, 1);      // mixer output to speaker (R)
    AudioConnection patchCord5(i2s2, 0, queue1, 0);     // mic input to queue (L)
    // Filename to save audio recording on SD card
    char filename[15];
    // The file object itself
    File frec;
    // Use long 40ms debounce time on both switches
    Bounce buttonRecord = Bounce(HOOK_PIN, 40);
    // Keep track of current state of the device
    enum Mode
      Initialising,
      Ready,
      Prompting,
      Recording,
      Playing
    Mode mode = Mode::Initialising;
    float beep_volume = 0.04f; // not too loud :-)
    // variables for writing to WAV file
    unsigned long ChunkSize = 0L;
    unsigned long Subchunk1Size = 16;
    unsigned int AudioFormat = 1;
    unsigned int numChannels = 1;
    unsigned long sampleRate = 44100;
    unsigned int bitsPerSample = 16;
    unsigned long byteRate = sampleRate * numChannels * (bitsPerSample / 8); // samplerate x channels x (bitspersample / 8)
    unsigned int blockAlign = numChannels * bitsPerSample / 8;
    unsigned long Subchunk2Size = 0L;
    unsigned long recByteSaved = 0L;
    unsigned long NumSamples = 0L;
    byte byte1, byte2, byte3, byte4;
      while (!Serial && millis() < 5000)
        // wait for serial port to connect.
      Serial.println("Serial set up correctly");
      print_mode();
      // Configure the input pins
      pinMode(HOOK_PIN, INPUT_PULLUP);
      AudioMemory(60);
      sgtl5000_1.enable();
      // Define which input on the audio shield to use (AUDIO_INPUT_LINEIN / AUDIO_INPUT_MIC)
      // sgtl5000_1.adcHighPassFilterDisable(); //
      sgtl5000_1.volume(0.95);
      mixer.gain(0, 1.0f);
      mixer.gain(1, 1.0f);
      // Play a beep to indicate system is online
      waveform1.begin(beep_volume, 440, WAVEFORM_SINE);
      wait(1000);
      waveform1.amplitude(0);
      // Initialize the SD card
      SPI.setMOSI(SDCARD_MOSI_PIN);
      SPI.setSCK(SDCARD_SCK_PIN);
      if (!(SD.begin(SDCARD_CS_PIN)))
        while (1)
        Serial.println("SD card correctly initialized");
      // mandatory to begin the MTP session.
      MTP.begin();
      // Add SD Card
      //    MTP.addFilesystem(SD, "SD Card");
      MTP.addFilesystem(SD, "Kais Audio guestbook"); // choose a nice name for the SD card volume to appear in your file explorer
      Serial.println("Added SD card via MTP");
      // Value in dB
      //  sgtl5000_1.micGain(15);
      sgtl5000_1.micGain(40); // much lower gain is required for the AOM5024 electret capsule
      // Synchronise the Time object used in the program code with the RTC time provider.
      // See https://github.com/PaulStoffregen/Time
      // Define a callback that will assign the correct datetime for any file system operations
      // (i.e. saving a new audio recording onto the SD card)
      FsDateTime::setCallback(dateTime);
      mode = Mode::Ready;
      print_mode();
      // First, read the buttons
      buttonRecord.update();
      switch (mode)
      case Mode::Ready:
        // Falling edge occurs when the handset is lifted --> 611 telephone
        if (buttonRecord.fallingEdge())
          Serial.println("Handset lifted");
          mode = Mode::Prompting;
          print_mode();
      case Mode::Prompting:
        // Wait a second for users to put the handset to their ear
        wait(1000);
        // Play the greeting inviting them to record their message
        playWav1.play("greeting.wav");
        // Wait until the  message has finished playing
        //      while (playWav1.isPlaying()) {
        while (!playWav1.isStopped())
          // Check whether the handset is replaced
          // Handset is replaced
          if (buttonRecord.risingEdge())
            playWav1.stop();
            mode = Mode::Ready;
            print_mode();
            return;
        // Debug message
        Serial.println("Starting Recording");
        // Play the tone sound effect
        wait(1250);
        // Start the recording function
        startRecording();
      case Mode::Recording:
          // Debug log
          Serial.println("Stopping Recording");
          // Stop recording
          stopRecording();
          // Play audio tone to confirm recording has ended
          end_Beep();
          continueRecording();
      case Mode::Playing: // to make compiler happy
      case Mode::Initialising: // to make compiler happy
      MTP.loop(); // This is mandatory to be placed in the loop code.
    void startRecording()
      // Find the first available file number
      //  for (uint8_t i=0; i<9999; i++) { // BUGFIX uint8_t overflows if it reaches 255
      for (uint16_t i = 0; i < 9999; i++)
        // Format the counter as a five-digit number with leading zeroes, followed by file extension
        snprintf(filename, 11, " %05d.wav", i);
        // Create if does not exist, do not open existing, write, sync after write
        if (!SD.exists(filename))
      frec = SD.open(filename, FILE_WRITE);
      Serial.println("Opened file !");
      if (frec)
        Serial.print("Recording to ");
        Serial.println(filename);
        queue1.begin();
        mode = Mode::Recording;
        print_mode();
        recByteSaved = 0L;
        Serial.println("Couldn't open file to record!");
    void continueRecording()
      // Check if there is data in the queue
      if (queue1.available() >= 2)
        byte buffer[512];
        // into a 512 byte buffer.  The Arduino SD library
        // writes are used.
        memcpy(buffer, queue1.readBuffer(), 256);
        queue1.freeBuffer();
        memcpy(buffer + 256, queue1.readBuffer(), 256);
        // Write all 512 bytes to the SD card
        frec.write(buffer, 512);
        recByteSaved += 512;
    void stopRecording()
      // Stop adding any new data to the queue
      queue1.end();
      // Flush all existing remaining data from the queue
      while (queue1.available() > 0)
        // Save to open file
        frec.write((byte *)queue1.readBuffer(), 256);
        recByteSaved += 256;
      writeOutHeader();
      // Close the file
      frec.close();
      Serial.println("Closed file");
      mode = Mode::Ready;
      print_mode();
    void playAllRecordings()
      // Recording files are saved in the root directory
      File dir = SD.open("/");
      while (true)
        File entry = dir.openNextFile();
        if (strstr(entry.name(), "greeting"))
        if (!entry)
          // no more files
          entry.close();
          end_Beep();
        // int8_t len = strlen(entry.name()) - 4;
        //    if (strstr(strlwr(entry.name() + (len - 4)), ".raw")) {
        //    if (strstr(strlwr(entry.name() + (len - 4)), ".wav")) {
        // the lines above throw a warning, so I replace them with this (which is also easier to read):
        if (strstr(entry.name(), ".wav") || strstr(entry.name(), ".WAV"))
          Serial.print("Now playing ");
          Serial.println(entry.name());
          // Play a short beep before each message
          waveform1.amplitude(beep_volume);
          wait(750);
          // Play the file
          playWav1.play(entry.name());
          mode = Mode::Playing;
          print_mode();
        entry.close();
        //    while (playWav1.isPlaying()) { // strangely enough, this works for playRaw, but it does not work properly for playWav
        { // this works for playWav
          // Button is pressed again
          //      if(buttonPlay.risingEdge() || buttonRecord.risingEdge()) { // FIX
            playWav1.stop();
            mode = Mode::Ready;
            print_mode();
            return;
      // All files have been played
      mode = Mode::Ready;
      print_mode();
    void playLastRecording()
      uint16_t idx = 0;
        // check, if file with index i exists
          idx = i - 1;
      // now play file with index idx == last recorded file
      snprintf(filename, 11, " %05d.wav", idx);
      playWav1.play(filename);
      print_mode();
          playWav1.stop();
          mode = Mode::Ready;
          print_mode();
          return;
      // file has been played
      mode = Mode::Ready;
      print_mode();
      end_Beep();
    // Retrieve the current time from Teensy built-in RTC
    time_t getTeensy3Time()
      return Teensy3Clock.get();
    // Callback to assign timestamps for file system operations
    void dateTime(uint16_t *date, uint16_t *time, uint8_t *ms10)
      // Return date using FS_DATE macro to format fields.
      *date = FS_DATE(year(), month(), day());
      // Return time using FS_TIME macro to format fields.
      *time = FS_TIME(hour(), minute(), second());
      // Return low time bits in units of 10 ms.
      *ms10 = second() & 1 ? 100 : 0;
    // Non-blocking delay, which pauses execution of main program logic,
    // but while still listening for input
    void wait(unsigned int milliseconds)
      elapsedMillis msec = 0;
      while (msec <= milliseconds)
          Serial.println("Button (pin 0) Press");
          Serial.println("Button (pin 0) Release");
    void writeOutHeader()
    { // update WAV header with final filesize/datasize
      //  NumSamples = (recByteSaved*8)/bitsPerSample/numChannels;
      //  Subchunk2Size = NumSamples*numChannels*bitsPerSample/8; // number of samples x number of channels x number of bytes per sample
      Subchunk2Size = recByteSaved;
      ChunkSize = Subchunk2Size + 36;
      frec.seek(0);
      frec.write("RIFF");
      byte1 = ChunkSize & 0xff;
      byte2 = (ChunkSize >> 8) & 0xff;
      byte3 = (ChunkSize >> 16) & 0xff;
      byte4 = (ChunkSize >> 24) & 0xff;
      frec.write(byte1);
      frec.write(byte2);
      frec.write(byte3);
      frec.write(byte4);
      frec.write("WAVE");
      frec.write("fmt ");
      byte1 = Subchunk1Size & 0xff;
      byte2 = (Subchunk1Size >> 8) & 0xff;
      byte3 = (Subchunk1Size >> 16) & 0xff;
      byte4 = (Subchunk1Size >> 24) & 0xff;
      frec.write(byte1);
      frec.write(byte2);
      frec.write(byte3);
      frec.write(byte4);
      byte1 = AudioFormat & 0xff;
      byte2 = (AudioFormat >> 8) & 0xff;
      frec.write(byte1);
      frec.write(byte2);
      byte1 = numChannels & 0xff;
      byte2 = (numChannels >> 8) & 0xff;
      frec.write(byte1);
      frec.write(byte2);
      byte1 = sampleRate & 0xff;
      byte2 = (sampleRate >> 8) & 0xff;
      byte3 = (sampleRate >> 16) & 0xff;
      byte4 = (sampleRate >> 24) & 0xff;
      frec.write(byte1);
      frec.write(byte2);
      frec.write(byte3);
      frec.write(byte4);
      byte1 = byteRate & 0xff;
      byte2 = (byteRate >> 8) & 0xff;
      byte3 = (byteRate >> 16) & 0xff;
      byte4 = (byteRate >> 24) & 0xff;
      frec.write(byte1);
      frec.write(byte2);
      frec.write(byte3);
      frec.write(byte4);
      byte1 = blockAlign & 0xff;
      byte2 = (blockAlign >> 8) & 0xff;
      frec.write(byte1);
      frec.write(byte2);
      byte1 = bitsPerSample & 0xff;
      byte2 = (bitsPerSample >> 8) & 0xff;
      frec.write(byte1);
      frec.write(byte2);
      frec.write("data");
      byte1 = Subchunk2Size & 0xff;
      byte2 = (Subchunk2Size >> 8) & 0xff;
      byte3 = (Subchunk2Size >> 16) & 0xff;
      byte4 = (Subchunk2Size >> 24) & 0xff;
      frec.write(byte1);
      frec.write(byte2);
      frec.write(byte3);
      frec.write(byte4);
      frec.close();
      Serial.println("header written");
      Serial.print("Subchunk2: ");
      Serial.println(Subchunk2Size);
    void end_Beep(void)
      waveform1.frequency(523.25);
      wait(250);
      wait(250);
      wait(250);
      wait(250);
      wait(250);
      wait(250);
      wait(250);
    void print_mode(void)
    { // only for debugging
      Serial.print("Mode switched to: ");
      // Initialising, Ready, Prompting, Recording, Playing
      if (mode == Mode::Ready)
        Serial.println(" Ready");
      else if (mode == Mode::Prompting)
        Serial.println(" Prompting");
      else if (mode == Mode::Recording)
        Serial.println(" Recording");
      else if (mode == Mode::Playing)
        Serial.println(" Playing");
      else if (mode == Mode::Initialising)
        Serial.println(" Initialising");
        Serial.println(" Undefined");
ID:	29353   Click image for larger version.
ID:	29355   Click image for larger version.
