Audio board line in piezo voltage question
sorin_jay
Hi, I have a piezoelectric disk that I want to use to pickup audio from a cello. However, the output voltage can get really high, and I don't want to burn out the teensy or audio shield. Recording on the multimeter, I got up to 9 volts, although that takes a running average so it could really be a lot higher. How do i connect that to the teensy?
A lot of the vibrations etc from the cello are low voltage (1 - 3 volts), but if something is loud I don't want to fry anything. What do I do? A voltage divider circuit (3300 and 2200 ohm resistor) doesn't preserve enough accuracy to get quality sound - just scratching and hitting it.
Yes, you do need high voltage protection when connecting a piezo transducer.
This article gives you some more insight. The mentioned TVS diodes are very commonly used parts.
Paul
Piezoelectric crystals are current sources (strictly speaking charge sources), so you can just put a low value resistor across the output to reduce the output voltage. Without any load they drift a lot in DC value anyway so you should already have a load resistor in the circuit with luck - just try reducing its value. Adding something like 1k in series with the output is a very simple way to add a degree of protection (in conjuction with the standard CMOS input protection diodes). Alas increasing this protection resistor in value will increase noise on the audio signal so its a compromize.
