Results 1 to 3 of 3
Thread: Platformio build and monitor helper
    Aug 2022
    7
    Admittedly I get annoyed by dumb things, so when using PIO with teensy the upload and monitor never works properly (at least for me) because teensy is still uploading when the monitor tries to start. This also happens with other boards that are still resetting when the the monitor starts causing it to timeout.
    So after asking for a feature that would add a delay and being shown a workaround I wound up with a nice simple script that can use a config property named monitor_delay
    See final post here https://github.com/platformio/platfo...re/issues/4416
    Hope this helps someone else
    Germany
    1,916
    :-) know that feeling...
    My solution is to use the TyTools https://github.com/Koromix/tytools for uploading and monitoring.
    Here one of my platformio.ini files (windows, changing for other OS should be straight forward I assume)
    [platformio]
    [env]
    framework = arduino
    [TeensyBase]
    platform = teensy
    upload_command = C:\toolchain\TyTools\tyCommanderC upload $SOURCE --autostart --wait --multi
    [env:T4.0]
    extends =TeensyBase
    board = Teensy40
    [env:T3.2]
    extends = TeensyBase
    board = Teensy31
    [env:SAMD21-seeed_xiao]
    platform = atmelsam
    board = seeed_xiao
    upload_protocol = jlink
    16,468
    TyTools / TyCommander is the icing on the Teensy cake!
    Note: it cannot upload encrypted eHex to T_4.x's that need it.
    @koromix added option: --delegate >> as used in github.com/Defragster/Tset/.../TSet.cmd2#L55
    After asking for 'which board' it then hits 'auto software Button' and steps aside for Teensy Loader to do the job, and waits for return without locking Loader out of the USB port.
    Not sure it has any use - other than .eHex builds that only PJRC can upload.
