AlexisJohn
Hi there,
I was very excited to install the new Arduino 2.0.0 IDE yesterday while still using my old trusted 1.8.8 because that's what I'm used to.
HOWEVER as soon as I installed the new Teensyuiono 1.57 I suddenly I couldn't compile anything on the old IDE.
I tried to uninstall the 2.0.0 IDE but I'm still stuck. Now I'm trying to uninstall the 1.57 but I can't find an easy way to do that either. Please help me someone as it feels like things have irresversibly changed!!!
Here are my error codes I'm getting on the 1.8.8 when I try and compile:
Arduino: 1.8.8 (Windows 10), TD: 1.50, Board: "Teensy 4.0, Serial, 600 MHz, Faster, US English"
Skipping C:\Users\user\AppData\Local\Arduino15\packages\teensy\tools\teensy-compile\5.4.1\avr\builtin_tools_versions.txt; please consider removing that file since it may hurt older Arduino installations
WARNING: Category 'Utility' in library FlexIO_t4 is not valid. Setting to 'Uncategorized'
Multiple libraries were found for "MapFloat.h"
C:\Users\user\Documents\Arduino\libraries\SdFat\SdSpiMK20DX128.cpp:23:23: fatal error: mk20dx128.h: No such file or directory
Used: C:\Users\user\Documents\Arduino\libraries\MapFloat
compilation terminated.
Not used: C:\Users\user\Documents\Arduino\libraries\MapFloat-master
Multiple libraries were found for "Audio.h"
Used: C:\Users\user\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.57.0\libraries\Audio
Not used: C:\Users\user\Documents\Arduino\libraries\Audio
Used: C:\Users\user\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.57.0\libraries\SD
Not used: C:\Program Files (x86)\Arduino\libraries\SD
Multiple libraries were found for "SdFat.h"
Used: C:\Users\user\Documents\Arduino\libraries\SdFat
Not used: C:\Users\user\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.57.0\libraries\SdFat
Not used: C:\Program Files (x86)\Arduino\libraries\SdFat
Multiple libraries were found for "SerialFlash.h"
Used: C:\Users\user\Documents\Arduino\libraries\SerialFlash
Not used: C:\Users\user\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.57.0\libraries\SerialFlash
Error compiling for board Teensy 4.0.
Invalid library found in C:\Program Files (x86)\Arduino\libraries\amd64: no headers files (.h) found in C:\Program Files (x86)\Arduino\libraries\amd64
Invalid library found in C:\Program Files (x86)\Arduino\libraries\AudioAnalyzer: no headers files (.h) found in C:\Program Files (x86)\Arduino\libraries\AudioAnalyzer
Invalid library found in C:\Program Files (x86)\Arduino\libraries\ia64: no headers files (.h) found in C:\Program Files (x86)\Arduino\libraries\ia64
Invalid library found in C:\Program Files (x86)\Arduino\libraries\license: no headers files (.h) found in C:\Program Files (x86)\Arduino\libraries\license
Invalid library found in C:\Program Files (x86)\Arduino\libraries\Microsmooth-master: no headers files (.h) found in C:\Program Files (x86)\Arduino\libraries\Microsmooth-master
Invalid library found in C:\Program Files (x86)\Arduino\libraries\music_v1_14: no headers files (.h) found in C:\Program Files (x86)\Arduino\libraries\music_v1_14
Invalid library found in C:\Program Files (x86)\Arduino\libraries\SdFat_master: no headers files (.h) found in C:\Program Files (x86)\Arduino\libraries\SdFat_master
Invalid library found in C:\Program Files (x86)\Arduino\libraries\Spectrum_Shield_Driver_master: no headers files (.h) found in C:\Program Files (x86)\Arduino\libraries\Spectrum_Shield_Driver_master
Invalid library found in C:\Program Files (x86)\Arduino\libraries\x86: no headers files (.h) found in C:\Program Files (x86)\Arduino\libraries\x86
Invalid library found in C:\Program Files (x86)\Arduino\libraries\__MACOSX: no headers files (.h) found in C:\Program Files (x86)\Arduino\libraries\__MACOSX
Invalid library found in C:\Users\user\Documents\Arduino\libraries\amd64: no headers files (.h) found in C:\Users\user\Documents\Arduino\libraries\amd64
Invalid library found in C:\Users\user\Documents\Arduino\libraries\AudioAnalyzer: no headers files (.h) found in C:\Users\user\Documents\Arduino\libraries\AudioAnalyzer
Invalid library found in C:\Users\user\Documents\Arduino\libraries\ia64: no headers files (.h) found in C:\Users\user\Documents\Arduino\libraries\ia64
Invalid library found in C:\Users\user\Documents\Arduino\libraries\license: no headers files (.h) found in C:\Users\user\Documents\Arduino\libraries\license
Invalid library found in C:\Users\user\Documents\Arduino\libraries\Microsmooth-master: no headers files (.h) found in C:\Users\user\Documents\Arduino\libraries\Microsmooth-master
Invalid library found in C:\Users\user\Documents\Arduino\libraries\music_v1_14: no headers files (.h) found in C:\Users\user\Documents\Arduino\libraries\music_v1_14
Invalid library found in C:\Users\user\Documents\Arduino\libraries\SdFat_master: no headers files (.h) found in C:\Users\user\Documents\Arduino\libraries\SdFat_master
Invalid library found in C:\Users\user\Documents\Arduino\libraries\Spectrum_Shield_Driver_master: no headers files (.h) found in C:\Users\user\Documents\Arduino\libraries\Spectrum_Shield_Driver_master
Invalid library found in C:\Users\user\Documents\Arduino\libraries\x86: no headers files (.h) found in C:\Users\user\Documents\Arduino\libraries\x86
Invalid library found in C:\Users\user\Documents\Arduino\libraries\__MACOSX: no headers files (.h) found in C:\Users\user\Documents\Arduino\libraries\__MACOSX
