Teensy 4.0 and AirLift-ESP32 SPI communication(using pin 34, 35, 36) doesn't work
I'm working with T4 communicating with Airlift(ESP32, SPI) from Adafruit using the library shown in this page.
https://learn.adafruit.com/adafruit-airlift-breakout/arduino
It woks with this configuration.
#define SPIWIFI SPI // The SPI port
#define SPIWIFI_SS 10 // Chip select pin
#define ESP32_RESETN 5 // Reset pin
#define SPIWIFI_ACK 7 // a.k.a BUSY or READY pin
#define ESP32_GPIO0 -1
#define MOSI_PIN 11
#define MISO_PIN 12
#define SCK_PIN 13
But it doesn't work if I change the configuration like the following.
#define SPIWIFI_SS 35 // Chip select pin
#define ESP32_RESETN 36 // Reset pin
#define SPIWIFI_ACK 34 // a.k.a BUSY or READY pin
#define MOSI_PIN 11
#define MISO_PIN 12
#define SCK_PIN 13
I double checked the soldering on the bottom pads and wiring.
No other connections other than T4 and Ailift.
Since I have to use pin 5, 7, 10 for other purposes, I have to use 34, 35 and 36 for communicating with Air Lift.
Do you have any suggestion to resolve this issue?
Thank you.
Byungjun
#define MOSI_PIN 11
#define MISO_PIN 12
#define SCK_PIN 13
#define MOSI_PIN 11
#define MISO_PIN 12
#define SCK_PIN 13
Thank you.
Byungjun
#include <WiFiNINA.h>
#include <SoftwareSerial.h>
#define SPIWIFI_SS 35// 10//35 // Chip select pin, White
#define ESP32_RESETN 36 // 5//36 // Reset pin, Yellow
#define SPIWIFI_ACK 34 // 7//34 // a.k.a BUSY or READY pin, blue
#define ESP32_GPIO0 -1//37 // 37
#define MOSI_PIN 11
#define MISO_PIN 12
#define SCK_PIN 13
#define S2Tx 8
#define S2Rx 7
//Initialize serial and wait for port to open:
Serial2.begin(115200);
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.println("WiFi Scanning test");
// SPI.setMOSI(MOSI_PIN);
// SPI.setMISO(MISO_PIN);
// SPI.setSCK(SCK_PIN);
// pinMode(ESP32_RESETN, OUTPUT);
// digitalWrite(ESP32_RESETN, HIGH);
// Set up the pins!
WiFi.setPins(SPIWIFI_SS, SPIWIFI_ACK, ESP32_RESETN, ESP32_GPIO0, &SPIWIFI);
// check for the WiFi module:
while (WiFi.status() == WL_NO_MODULE) {
Serial.println("Communication with WiFi module failed!");
// don't continue
if (Serial2.available()) {
// Serial.println("available");
byte read = Serial2.read();
Serial.print(read);
String fv = WiFi.firmwareVersion();
Serial.println(fv);
if (fv < "1.0.0") {
Serial.println("Please upgrade the firmware");
while (1) delay(10);
Serial.println("Firmware OK");
// print your MAC address:
byte mac[6];
WiFi.macAddress(mac);
Serial.print("MAC: ");
printMacAddress(mac);
// scan for existing networks:
Serial.println("Scanning available networks...");
listNetworks();
delay(10000);
void listNetworks() {
// scan for nearby networks:
Serial.println("** Scan Networks **");
int numSsid = WiFi.scanNetworks();
if (numSsid == -1) {
Serial.println("Couldn't get a wifi connection");
while (true);
// print the list of networks seen:
Serial.print("number of available networks:");
Serial.println(numSsid);
// print the network number and name for each network found:
for (int thisNet = 0; thisNet < numSsid; thisNet++) {
Serial.print(thisNet);
Serial.print(") ");
Serial.print(WiFi.SSID(thisNet));
Serial.print("\tSignal: ");
Serial.print(WiFi.RSSI(thisNet));
Serial.print(" dBm");
Serial.print("\tEncryption: ");
printEncryptionType(WiFi.encryptionType(thisNet));
void printEncryptionType(int thisType) {
// read the encryption type and print out the name:
switch (thisType) {
case ENC_TYPE_WEP:
Serial.println("WEP");
case ENC_TYPE_TKIP:
Serial.println("WPA");
case ENC_TYPE_CCMP:
Serial.println("WPA2");
case ENC_TYPE_NONE:
Serial.println("None");
case ENC_TYPE_AUTO:
Serial.println("Auto");
case ENC_TYPE_UNKNOWN:
default:
Serial.println("Unknown");
void printMacAddress(byte mac[]) {
for (int i = 5; i >= 0; i--) {
if (mac[i] < 16) {
Serial.print("0");
Serial.print(mac[i], HEX);
if (i > 0) {
Serial.print(":");
