snowsh
So I decided to have a look at Arduino ide 2. I checked to see if I could run the new version 2 alongside my original Arduino (1.8.15) Teensyduino 1.54 - results said yes and that my libraries would remain intact. I dont think that is entirely true as the install seems to have updated all the libraries too...
At first glance I was impressed with the new features. Then I tried to compile a project I have been working on for over a year. I compiled fine before.....
Now I get the dreaded SD library problems, in both versions of Arduino IDE.......
error: #error "Teensy's SD library uses a custom modified copy of SdFat. Standard SdFat was mistakenly used. Arduino should print multiple libraries found for SdFat.h. To resolve this error, you will need to move or delete the copy Arduino is using, or otherwise take steps to cause Teensy's special copy of SdFat to be used."
full error:
For further detail, I include the SD lib like this:
and I startup the SD using a function:
I have looked at the src for the used version of SD...
So to track down which SDFat.h its actully hunting, I searched my drive for "SD_FAT_TEENSY_MODIFIED" - nothing! A quick google search for "SD_FAT_TEENSY_MODIFIED" returns only one result, the github page for the SD.h it is using.....
There must be a better way of dealing with these library includes than relying on the IDE to hunt down "the best choice"....
I am stumped. I want to write code, not troubleshoot installations! Arrghh!
So, which exactly is "Teensy's special copy of SdFat"??
Help!
full error:
In file included from C:\Users\nxx\OneDrive\Documents\Arduino\projects\ASeqCII project\ASeqCII_V1.010-resume-scotland-20092022\ASeqCII_V1.010-resume-scotland-20092022.ino:36:0:
C:\Users\nxx\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.57.0\libraries\SD\src/SD.h:29:2: error: #error "Teensy's SD library uses a custom modified copy of SdFat. Standard SdFat was mistakenly used. Arduino should print multiple libraries found for SdFat.h. To resolve this error, you will need to move or delete the copy Arduino is using, or otherwise take steps to cause Teensy's special copy of SdFat to be used."
Multiple libraries were found for "SdFat.h"
Used: C:\Users\nxx\OneDrive\Documents\Arduino\libraries\SdFat
Not used: C:\Users\nxx\OneDrive\Documents\Arduino\libraries\arduino_468653
Not used: C:\Users\nxx\OneDrive\Documents\Arduino\libraries\SdFat_-_Adafruit_Fork
Not used: C:\Users\nxx\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.57.0\libraries\SdFat
Used: C:\Users\nxx\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.57.0\libraries\SD
Not used: C:\Program Files (x86)\Arduino\libraries\SD
Error compiling for board Teensy 4.1.
void mySdBegin() // begin new SD connection
cardStatus = SD.sdfs.begin(SdioConfig(FIFO_SDIO));
if (!cardStatus)
Serial.println(F("SD card not present"));
delay(2000);
#if !defined(SD_FAT_TEENSY_MODIFIED)
Help!
