Results 1 to 5 of 5
Thread: Teensy 4 - FreqCount.begin() - timer units?
    May 2021
    17
    I've noticed that the documentation for FreqCount uses milliseconds for .begin() but example "serial_output_T4" uses microseconds.
    FreqCount.begin(1000000);  //Time in microseconds
    Which is correct?
    Second, does FreqCount block interupts on the serial ports or is it just PWM function that is affected?
    Thanks.
    11,170
    Yes it looks like when it was converted to T4.x it changed. From the header file
    	#if(!defined(__IMXRT1062__))
    		static void begin(uint16_t msec);
    	#else
    		static void begin(uint32_t usec);
    Probably the documentation page: https://www.pjrc.com/teensy/td_libs_FreqCount.html
    Should be updated.
    Edit: Also maybe there should be a couple new versions of begin
    like beginMS(uint16_t ms) and beginUS(uint32_t us);
    That is not platform specific... Calls off to existing one.
    May 2021
    17
    Thanks for that; I almost got caught out by the change!
    Quote Originally Posted by MartinJR View Post
    Here's a FreqCount example program with conditional defines for T3/LC and T4/MM
    /* FreqCount - Example with serial output
     * http://www.pjrc.com/teensy/td_libs_FreqCount.html
     * This example code is in the public domain.
     * Teensy     FreqCount input pin    PWM output pin
     * 4.x/MM     9                      8
     * 3.x        13                     8
     * LC         13                     9
     * 2.0        11                     ?
     * Jumper OUTPUT_PIN to INPUT_PIN
    #include <FreqCount.h>
    #if defined (__IMXRT1062__) // T4.x
    #define PWM_OUTPUT_PIN 8
    #elif defined (KINETISK)    // T3.x
    #elif defined (KINETISL)    // LC
    #define PWM_OUTPUT_PIN 9
    #else
    // define pin for T2.0
      Serial.begin(57600);
      delay(2000);
      analogWriteFrequency(PWM_OUTPUT_PIN, 5000);  // 5 kHz test signal
      analogWrite(PWM_OUTPUT_PIN, 128);
      FreqCount.begin(1000000);  // for T4.x/MM, count time in microseconds
    #else
      FreqCount.begin(1000);     // for T3.x/LC/T2.x, count time in milliseconds
      if (FreqCount.available()) {
        unsigned long count = FreqCount.read();
        Serial.println(count);
    May 2021
    17
    Quote Originally Posted by joepasquariello View Post
    Thanks for that.
