How can I convert this default adafruit font to a format that works with this library? https://github.com/vindar/tgx
Im using vscode with platformio and using teensy 4.1.
This is the format of the font i want:
glcdfont.c
And this is how other fonts look like in tgx for example arial:
font_tgx_Arial.cpp
font_tgx_Arial.h
glcdfont.c
// This is the 'classic' fixed-space bitmap font for Adafruit_GFX since 1.0.
// See gfxfont.h for newer custom bitmap font info.
#ifndef FONT5X7_H
#define FONT5X7_H
#ifdef __AVR__
#include <avr/io.h>
#include <avr/pgmspace.h>
#elif defined(ESP8266)
#include <pgmspace.h>
#elif defined(__IMXRT1052__) || defined(__IMXRT1062__)
// PROGMEM is defefind for T4 to place data in specific memory section
#undef PROGMEM
#define PROGMEM
#else
#define PROGMEM
// Standard ASCII 5x7 font
static const unsigned char font[] PROGMEM = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x3E, 0x5B, 0x4F, 0x5B, 0x3E, 0x3E, 0x6B,
0x4F, 0x6B, 0x3E, 0x1C, 0x3E, 0x7C, 0x3E, 0x1C, 0x18, 0x3C, 0x7E, 0x3C,
0x18, 0x1C, 0x57, 0x7D, 0x57, 0x1C, 0x1C, 0x5E, 0x7F, 0x5E, 0x1C, 0x00,
0x18, 0x3C, 0x18, 0x00, 0xFF, 0xE7, 0xC3, 0xE7, 0xFF, 0x00, 0x18, 0x24,
0x18, 0x00, 0xFF, 0xE7, 0xDB, 0xE7, 0xFF, 0x30, 0x48, 0x3A, 0x06, 0x0E,
0x26, 0x29, 0x79, 0x29, 0x26, 0x40, 0x7F, 0x05, 0x05, 0x07, 0x40, 0x7F,
0x05, 0x25, 0x3F, 0x5A, 0x3C, 0xE7, 0x3C, 0x5A, 0x7F, 0x3E, 0x1C, 0x1C,
0x08, 0x08, 0x1C, 0x1C, 0x3E, 0x7F, 0x14, 0x22, 0x7F, 0x22, 0x14, 0x5F,
0x5F, 0x00, 0x5F, 0x5F, 0x06, 0x09, 0x7F, 0x01, 0x7F, 0x00, 0x66, 0x89,
0x95, 0x6A, 0x60, 0x60, 0x60, 0x60, 0x60, 0x94, 0xA2, 0xFF, 0xA2, 0x94,
0x08, 0x04, 0x7E, 0x04, 0x08, 0x10, 0x20, 0x7E, 0x20, 0x10, 0x08, 0x08,
0x2A, 0x1C, 0x08, 0x08, 0x1C, 0x2A, 0x08, 0x08, 0x1E, 0x10, 0x10, 0x10,
0x10, 0x0C, 0x1E, 0x0C, 0x1E, 0x0C, 0x30, 0x38, 0x3E, 0x38, 0x30, 0x06,
0x0E, 0x3E, 0x0E, 0x06, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x5F,
0x00, 0x00, 0x00, 0x07, 0x00, 0x07, 0x00, 0x14, 0x7F, 0x14, 0x7F, 0x14,
0x24, 0x2A, 0x7F, 0x2A, 0x12, 0x23, 0x13, 0x08, 0x64, 0x62, 0x36, 0x49,
0x56, 0x20, 0x50, 0x00, 0x08, 0x07, 0x03, 0x00, 0x00, 0x1C, 0x22, 0x41,
0x00, 0x00, 0x41, 0x22, 0x1C, 0x00, 0x2A, 0x1C, 0x7F, 0x1C, 0x2A, 0x08,
0x08, 0x3E, 0x08, 0x08, 0x00, 0x80, 0x70, 0x30, 0x00, 0x08, 0x08, 0x08,
0x08, 0x08, 0x00, 0x00, 0x60, 0x60, 0x00, 0x20, 0x10, 0x08, 0x04, 0x02,
0x3E, 0x51, 0x49, 0x45, 0x3E, 0x00, 0x42, 0x7F, 0x40, 0x00, 0x72, 0x49,
0x49, 0x49, 0x46, 0x21, 0x41, 0x49, 0x4D, 0x33, 0x18, 0x14, 0x12, 0x7F,
0x10, 0x27, 0x45, 0x45, 0x45, 0x39, 0x3C, 0x4A, 0x49, 0x49, 0x31, 0x41,
0x21, 0x11, 0x09, 0x07, 0x36, 0x49, 0x49, 0x49, 0x36, 0x46, 0x49, 0x49,
0x29, 0x1E, 0x00, 0x00, 0x14, 0x00, 0x00, 0x00, 0x40, 0x34, 0x00, 0x00,
0x00, 0x08, 0x14, 0x22, 0x41, 0x14, 0x14, 0x14, 0x14, 0x14, 0x00, 0x41,
0x22, 0x14, 0x08, 0x02, 0x01, 0x59, 0x09, 0x06, 0x3E, 0x41, 0x5D, 0x59,
0x4E, 0x7C, 0x12, 0x11, 0x12, 0x7C, 0x7F, 0x49, 0x49, 0x49, 0x36, 0x3E,
0x41, 0x41, 0x41, 0x22, 0x7F, 0x41, 0x41, 0x41, 0x3E, 0x7F, 0x49, 0x49,
0x49, 0x41, 0x7F, 0x09, 0x09, 0x09, 0x01, 0x3E, 0x41, 0x41, 0x51, 0x73,
0x7F, 0x08, 0x08, 0x08, 0x7F, 0x00, 0x41, 0x7F, 0x41, 0x00, 0x20, 0x40,
0x41, 0x3F, 0x01, 0x7F, 0x08, 0x14, 0x22, 0x41, 0x7F, 0x40, 0x40, 0x40,
0x40, 0x7F, 0x02, 0x1C, 0x02, 0x7F, 0x7F, 0x04, 0x08, 0x10, 0x7F, 0x3E,
0x41, 0x41, 0x41, 0x3E, 0x7F, 0x09, 0x09, 0x09, 0x06, 0x3E, 0x41, 0x51,
0x21, 0x5E, 0x7F, 0x09, 0x19, 0x29, 0x46, 0x26, 0x49, 0x49, 0x49, 0x32,
0x03, 0x01, 0x7F, 0x01, 0x03, 0x3F, 0x40, 0x40, 0x40, 0x3F, 0x1F, 0x20,
0x40, 0x20, 0x1F, 0x3F, 0x40, 0x38, 0x40, 0x3F, 0x63, 0x14, 0x08, 0x14,
0x63, 0x03, 0x04, 0x78, 0x04, 0x03, 0x61, 0x59, 0x49, 0x4D, 0x43, 0x00,
0x7F, 0x41, 0x41, 0x41, 0x02, 0x04, 0x08, 0x10, 0x20, 0x00, 0x41, 0x41,
0x41, 0x7F, 0x04, 0x02, 0x01, 0x02, 0x04, 0x40, 0x40, 0x40, 0x40, 0x40,
0x00, 0x03, 0x07, 0x08, 0x00, 0x20, 0x54, 0x54, 0x78, 0x40, 0x7F, 0x28,
0x44, 0x44, 0x38, 0x38, 0x44, 0x44, 0x44, 0x28, 0x38, 0x44, 0x44, 0x28,
0x7F, 0x38, 0x54, 0x54, 0x54, 0x18, 0x00, 0x08, 0x7E, 0x09, 0x02, 0x18,
0xA4, 0xA4, 0x9C, 0x78, 0x7F, 0x08, 0x04, 0x04, 0x78, 0x00, 0x44, 0x7D,
0x40, 0x00, 0x20, 0x40, 0x40, 0x3D, 0x00, 0x7F, 0x10, 0x28, 0x44, 0x00,
0x00, 0x41, 0x7F, 0x40, 0x00, 0x7C, 0x04, 0x78, 0x04, 0x78, 0x7C, 0x08,
0x04, 0x04, 0x78, 0x38, 0x44, 0x44, 0x44, 0x38, 0xFC, 0x18, 0x24, 0x24,
0x18, 0x18, 0x24, 0x24, 0x18, 0xFC, 0x7C, 0x08, 0x04, 0x04, 0x08, 0x48,
0x54, 0x54, 0x54, 0x24, 0x04, 0x04, 0x3F, 0x44, 0x24, 0x3C, 0x40, 0x40,
0x20, 0x7C, 0x1C, 0x20, 0x40, 0x20, 0x1C, 0x3C, 0x40, 0x30, 0x40, 0x3C,
0x44, 0x28, 0x10, 0x28, 0x44, 0x4C, 0x90, 0x90, 0x90, 0x7C, 0x44, 0x64,
0x54, 0x4C, 0x44, 0x00, 0x08, 0x36, 0x41, 0x00, 0x00, 0x00, 0x77, 0x00,
0x00, 0x00, 0x41, 0x36, 0x08, 0x00, 0x02, 0x01, 0x02, 0x04, 0x02, 0x3C,
0x26, 0x23, 0x26, 0x3C, 0x1E, 0xA1, 0xA1, 0x61, 0x12, 0x3A, 0x40, 0x40,
0x20, 0x7A, 0x38, 0x54, 0x54, 0x55, 0x59, 0x21, 0x55, 0x55, 0x79, 0x41,
0x22, 0x54, 0x54, 0x78, 0x42, // a-umlaut
0x21, 0x55, 0x54, 0x78, 0x40, 0x20, 0x54, 0x55, 0x79, 0x40, 0x0C, 0x1E,
0x52, 0x72, 0x12, 0x39, 0x55, 0x55, 0x55, 0x59, 0x39, 0x54, 0x54, 0x54,
0x59, 0x39, 0x55, 0x54, 0x54, 0x58, 0x00, 0x00, 0x45, 0x7C, 0x41, 0x00,
0x02, 0x45, 0x7D, 0x42, 0x00, 0x01, 0x45, 0x7C, 0x40, 0x7D, 0x12, 0x11,
0x12, 0x7D, // A-umlaut
0xF0, 0x28, 0x25, 0x28, 0xF0, 0x7C, 0x54, 0x55, 0x45, 0x00, 0x20, 0x54,
0x54, 0x7C, 0x54, 0x7C, 0x0A, 0x09, 0x7F, 0x49, 0x32, 0x49, 0x49, 0x49,
0x32, 0x3A, 0x44, 0x44, 0x44, 0x3A, // o-umlaut
0x32, 0x4A, 0x48, 0x48, 0x30, 0x3A, 0x41, 0x41, 0x21, 0x7A, 0x3A, 0x42,
0x40, 0x20, 0x78, 0x00, 0x9D, 0xA0, 0xA0, 0x7D, 0x3D, 0x42, 0x42, 0x42,
0x3D, // O-umlaut
0x3D, 0x40, 0x40, 0x40, 0x3D, 0x3C, 0x24, 0xFF, 0x24, 0x24, 0x48, 0x7E,
0x49, 0x43, 0x66, 0x2B, 0x2F, 0xFC, 0x2F, 0x2B, 0xFF, 0x09, 0x29, 0xF6,
0x20, 0xC0, 0x88, 0x7E, 0x09, 0x03, 0x20, 0x54, 0x54, 0x79, 0x41, 0x00,
0x00, 0x44, 0x7D, 0x41, 0x30, 0x48, 0x48, 0x4A, 0x32, 0x38, 0x40, 0x40,
0x22, 0x7A, 0x00, 0x7A, 0x0A, 0x0A, 0x72, 0x7D, 0x0D, 0x19, 0x31, 0x7D,
0x26, 0x29, 0x29, 0x2F, 0x28, 0x26, 0x29, 0x29, 0x29, 0x26, 0x30, 0x48,
0x4D, 0x40, 0x20, 0x38, 0x08, 0x08, 0x08, 0x08, 0x08, 0x08, 0x08, 0x08,
0x38, 0x2F, 0x10, 0xC8, 0xAC, 0xBA, 0x2F, 0x10, 0x28, 0x34, 0xFA, 0x00,
0x00, 0x7B, 0x00, 0x00, 0x08, 0x14, 0x2A, 0x14, 0x22, 0x22, 0x14, 0x2A,
0x14, 0x08, 0x55, 0x00, 0x55, 0x00, 0x55, // #176 (25% block) missing in old
// code
0xAA, 0x55, 0xAA, 0x55, 0xAA, // 50% block
0xFF, 0x55, 0xFF, 0x55, 0xFF, // 75% block
0x00, 0x00, 0x00, 0xFF, 0x00, 0x10, 0x10, 0x10, 0xFF, 0x00, 0x14, 0x14,
0x14, 0xFF, 0x00, 0x10, 0x10, 0xFF, 0x00, 0xFF, 0x10, 0x10, 0xF0, 0x10,
0xF0, 0x14, 0x14, 0x14, 0xFC, 0x00, 0x14, 0x14, 0xF7, 0x00, 0xFF, 0x00,
0x00, 0xFF, 0x00, 0xFF, 0x14, 0x14, 0xF4, 0x04, 0xFC, 0x14, 0x14, 0x17,
0x10, 0x1F, 0x10, 0x10, 0x1F, 0x10, 0x1F, 0x14, 0x14, 0x14, 0x1F, 0x00,
0x10, 0x10, 0x10, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x1F, 0x10, 0x10, 0x10,
0x10, 0x1F, 0x10, 0x10, 0x10, 0x10, 0xF0, 0x10, 0x00, 0x00, 0x00, 0xFF,
0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0x10, 0xFF, 0x10, 0x00,
0x00, 0x00, 0xFF, 0x14, 0x00, 0x00, 0xFF, 0x00, 0xFF, 0x00, 0x00, 0x1F,
0x10, 0x17, 0x00, 0x00, 0xFC, 0x04, 0xF4, 0x14, 0x14, 0x17, 0x10, 0x17,
0x14, 0x14, 0xF4, 0x04, 0xF4, 0x00, 0x00, 0xFF, 0x00, 0xF7, 0x14, 0x14,
0x14, 0x14, 0x14, 0x14, 0x14, 0xF7, 0x00, 0xF7, 0x14, 0x14, 0x14, 0x17,
0x14, 0x10, 0x10, 0x1F, 0x10, 0x1F, 0x14, 0x14, 0x14, 0xF4, 0x14, 0x10,
0x10, 0xF0, 0x10, 0xF0, 0x00, 0x00, 0x1F, 0x10, 0x1F, 0x00, 0x00, 0x00,
0x1F, 0x14, 0x00, 0x00, 0x00, 0xFC, 0x14, 0x00, 0x00, 0xF0, 0x10, 0xF0,
0x10, 0x10, 0xFF, 0x10, 0xFF, 0x14, 0x14, 0x14, 0xFF, 0x14, 0x10, 0x10,
0x10, 0x1F, 0x00, 0x00, 0x00, 0x00, 0xF0, 0x10, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xF0, 0xF0, 0xF0, 0xF0, 0xF0, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00,
0x00, 0x00, 0xFF, 0xFF, 0x0F, 0x0F, 0x0F, 0x0F, 0x0F, 0x38, 0x44, 0x44,
0x38, 0x44, 0xFC, 0x4A, 0x4A, 0x4A, 0x34, // sharp-s or beta
0x7E, 0x02, 0x02, 0x06, 0x06, 0x02, 0x7E, 0x02, 0x7E, 0x02, 0x63, 0x55,
0x49, 0x41, 0x63, 0x38, 0x44, 0x44, 0x3C, 0x04, 0x40, 0x7E, 0x20, 0x1E,
0x20, 0x06, 0x02, 0x7E, 0x02, 0x02, 0x99, 0xA5, 0xE7, 0xA5, 0x99, 0x1C,
0x2A, 0x49, 0x2A, 0x1C, 0x4C, 0x72, 0x01, 0x72, 0x4C, 0x30, 0x4A, 0x4D,
0x4D, 0x30, 0x30, 0x48, 0x78, 0x48, 0x30, 0xBC, 0x62, 0x5A, 0x46, 0x3D,
0x3E, 0x49, 0x49, 0x49, 0x00, 0x7E, 0x01, 0x01, 0x01, 0x7E, 0x2A, 0x2A,
0x2A, 0x2A, 0x2A, 0x44, 0x44, 0x5F, 0x44, 0x44, 0x40, 0x51, 0x4A, 0x44,
0x40, 0x40, 0x44, 0x4A, 0x51, 0x40, 0x00, 0x00, 0xFF, 0x01, 0x03, 0xE0,
0x80, 0xFF, 0x00, 0x00, 0x08, 0x08, 0x6B, 0x6B, 0x08, 0x36, 0x12, 0x36,
0x24, 0x36, 0x06, 0x0F, 0x09, 0x0F, 0x06, 0x00, 0x00, 0x18, 0x18, 0x00,
0x00, 0x00, 0x10, 0x10, 0x00, 0x30, 0x40, 0xFF, 0x01, 0x01, 0x00, 0x1F,
0x01, 0x01, 0x1E, 0x00, 0x19, 0x1D, 0x17, 0x12, 0x00, 0x3C, 0x3C, 0x3C,
0x3C, 0x00, 0x00, 0x00, 0x00, 0x00 // #255 NBSP
// allow clean compilation with [-Wunused-const-variable=] and [-Wall]
static inline void avoid_unused_const_variable_compiler_warning(void) {
(void)font;
#endif // FONT5X7_H
font_tgx_Arial.cpp
#include "font_tgx_Arial.h"
static const unsigned char font_tgx_Arial_8_data[] = {
0x00,0x00,0x18,0x03,0x00,0x16,0x44,0x06,0x62,0xA4,
0xD0,0x0B,0x00,0x34,0x15,0xF8,0x53,0xF1,0x40,0x0B,
0x27,0xB1,0xCA,0xA8,0x74,0x15,0x53,0x84,0x13,0x00,
0x51,0x89,0x12,0x83,0x40,0x16,0x81,0x48,0x8C,0x0D,
0x00,0x38,0xC8,0x48,0x61,0x44,0x68,0x8E,0x80,0x02,
0x62,0x94,0xC0,0x07,0x47,0x20,0x96,0x42,0x10,0x07,
0x47,0x22,0x16,0x12,0x40,0x06,0x82,0x21,0x39,0x28,
0x0A,0xA0,0xB4,0x11,0xF8,0x20,0x02,0x6F,0x1C,0xC0,
0x06,0x21,0x23,0x80,0x02,0x28,0x1A,0x07,0x00,0x1C,
0x1A,0x51,0x00,0x0B,0x00,0x31,0xD9,0x13,0x80,0x07,
0x00,0x30,0x9A,0xD9,0x0B,0x00,0x31,0xC8,0xC0,0x42,
0x10,0x87,0xC0,0x0B,0x00,0x31,0xC8,0x82,0x34,0x05,
0x13,0x80,0x0B,0x00,0x30,0x43,0x42,0x92,0x7E,0x04,
0x0B,0x00,0x31,0xE4,0x20,0xF4,0x05,0x13,0x80,0x0B,
0x00,0x31,0xC8,0xA0,0xF4,0xC4,0xE0,0x0B,0x00,0x33,
0xF0,0x28,0x24,0xA0,0x0B,0x00,0x31,0xD1,0x13,0xA6,
0x27,0x00,0x0B,0x00,0x31,0xD3,0x13,0xC1,0x44,0xE0,
0x02,0xC0,0x1B,0x44,0x03,0x07,0x1B,0x49,0x80,0x0A,
0xA0,0xB0,0x27,0x20,0x70,0x20,0x0A,0x61,0x33,0xE0,
0x3E,0x0A,0xA0,0xB2,0x07,0x02,0x72,0x00,0x0B,0x00,
0x31,0xC8,0x82,0x14,0x10,0x01,0x00,0x15,0x47,0x58,
0x7C,0x30,0x44,0xD5,0x26,0xC5,0x12,0xA6,0x93,0x61,
0x01,0x1F,0xC0,0x0F,0x00,0x40,0x44,0x94,0x22,0x3E,
0x88,0x20,0x0D,0x00,0x3B,0xE8,0x85,0xFC,0xC2,0xF8,
0x0D,0x00,0x38,0xE2,0x35,0x01,0x11,0xC0,0x0D,0x00,
0x3B,0xC4,0x55,0x0A,0x27,0x80,0x0B,0x00,0x33,0xF1,
0x07,0xE6,0x0F,0x80,0x0B,0x00,0x33,0xF1,0x07,0xAA,
0x00,0x0F,0x00,0x40,0xE1,0x12,0x0A,0x02,0x3A,0x09,
0x10,0xE0,0x0D,0x00,0x3C,0xC2,0xFE,0xA1,0x03,0x00,
0x16,0xD0,0x09,0x00,0x2D,0x8C,0x49,0x80,0x0D,0x00,
0x3A,0x14,0x49,0x16,0x34,0x88,0x90,0x80,0x0B,0x00,
0x36,0xC1,0xF0,0x0F,0x00,0x42,0x0C,0x63,0x9A,0xB1,
0x24,0x0D,0x00,0x3A,0x16,0x31,0x4C,0x4A,0x8D,0x08,
0x0F,0x00,0x40,0xE1,0x15,0x41,0x22,0x1C,0x0B,0x00,
0x33,0xD3,0x17,0xA6,0x00,0x0F,0x00,0x40,0xE1,0x14,
0xC1,0x4D,0x22,0x1F,0x0D,0x00,0x3B,0xE8,0x85,0xF2,
0x48,0x89,0x08,0x0D,0x00,0x39,0xE4,0x28,0x0C,0x06,
0x02,0x84,0xF0,0x0B,0x00,0x33,0xFA,0x40,0x0D,0x00,
0x3E,0xC2,0x78,0x0F,0x00,0x44,0x41,0x84,0x50,0x52,
0x04,0x00,0x17,0x18,0x52,0x10,0xA2,0x8C,0x25,0x28,
0x51,0x50,0x41,0x00,0x0D,0x00,0x3A,0x18,0x4A,0x0C,
0x84,0x90,0x80,0x0F,0x00,0x42,0x0C,0x22,0x14,0xA1,
0x00,0x0D,0x00,0x39,0xF0,0x50,0x24,0x10,0x41,0xF8,
0x05,0x47,0x1B,0xD9,0x30,0x07,0x00,0x1C,0x4A,0x50,
0x40,0x05,0x47,0x1B,0xD4,0xB0,0x0A,0x82,0x28,0x90,
0xA4,0x40,0x0C,0x27,0x33,0xF0,0x04,0x43,0x22,0x20,
0x0A,0xC0,0x31,0xC8,0x9E,0x8A,0x6E,0x80,0x0B,0x00,
0x34,0x41,0x66,0x62,0x2C,0xAC,0x0A,0xC0,0x31,0xC8,
0xC4,0x11,0x38,0x0B,0x00,0x34,0x04,0xD4,0xE2,0x29,
0x9A,0x0A,0xC0,0x31,0xC8,0xBE,0x82,0x27,0x00,0x07,
0x00,0x20,0x93,0xDA,0x0B,0x07,0x31,0xA9,0xC4,0x53,
0x34,0x17,0x80,0x0B,0x00,0x34,0x41,0x66,0x6A,0x20,
0x03,0x00,0x12,0x64,0x05,0x5F,0x11,0x1A,0xA0,0x09,
0x00,0x2C,0x42,0x54,0xC7,0x29,0x20,0x03,0x00,0x16,
0xD0,0x0E,0xC0,0x42,0xF3,0x4D,0x49,0x0A,0xC0,0x33,
0xD7,0x10,0x0A,0xC0,0x31,0xD5,0x13,0x80,0x0B,0x07,
0x32,0xCC,0xC4,0x59,0x5A,0x20,0x0B,0x07,0x31,0xA9,
0xC4,0x53,0x36,0x02,0x06,0xC0,0x22,0xB5,0x40,0x0A,
0xC0,0x31,0xC8,0x98,0x12,0x27,0x00,0x07,0x18,0x1C,
0x27,0xA4,0x60,0x0A,0xC0,0x35,0x45,0x33,0x40,0x0A,
0xC0,0x34,0x46,0x15,0x04,0x12,0xC0,0x52,0x22,0x94,
0xC2,0xAA,0x08,0x80,0x0A,0xC0,0x32,0x25,0x41,0x0A,
0x44,0x0B,0x07,0x34,0x46,0x15,0x24,0x20,0x0A,0xC0,
0x33,0xE1,0x41,0x08,0x7C,0x07,0x47,0x20,0xCA,0x4A,
0x42,0x03,0x47,0x16,0xE6,0x07,0x4F,0x22,0x4A,0x1A,
0x48,0x0A,0x42,0x33,0xAB,0x00,};
/* font data size: 656 bytes */
static const unsigned char font_tgx_Arial_8_index[] = {
0x00,0x00,0x30,0x1C,
0x0B,0x04,0xC1,0xC0,0x9C,0x31,0x0D,0x43,0xB1,0x04,
0x46,0x13,0x05,0x01,0x50,0x57,0x17,0x46,0x31,0xA0,
0x71,0x1E,0x88,0x22,0x2C,0x93,0x26,0x8A,0x22,0xA8,
0xAE,0x2C,0xCB,0xA2,0xFC,0xC6,0x33,0xCD,0xF3,0xA0,
0xF0,0x3E,0x10,0x04,0x21,0x0F,0x46,0x92,0x04,0x91,
0x2A,0x4D,0x13,0x95,0x05,0x4A,0x54,0x95,0x95,0x89,
0x6B,0x5D,0x57,0xA5,0xFD,0x88,0x65,0x19,0xD6,0x95,
0xAE,0x6C,0xDB,0x96,0xF9,0xC4,0x72,0x1C,0xC7,0x51,
0xDC,0x78,0xDE,0xB7,0xCD,0xF8,0x80,0x60,0x88,0x32,
0x11,0x86,0x61,0xD8,0x8E,0x28,0x8B,0xA3,0x68,0xFA,
0x43,0x92,0xE5,0x19,0x5E,0x5D,0x99,0xA6,0xD9,0xD2,
0x7B,0xA0,0x68,0x5A,0x2C,
/* font index size: 119 bytes */
const ILI9341_t3_font_t font_tgx_Arial_8 = {
font_tgx_Arial_8_index,
0,
font_tgx_Arial_8_data,
1,
0,
32,
126,
0,
0,
10,
4,
4,
2,
4,
4,
11,
8
font_tgx_Arial.h
#ifndef _font_tgx_Arial_H_
#define _font_tgx_Arial_H_
#include "tgx.h"
//#ifdef __cplusplus
//extern "C" {
//#endif
extern const ILI9341_t3_font_t font_tgx_Arial_8;
//} // extern "C"
//#endif
