A replacement for the .ld file for teensy 4.1 to make it mxmrt CMSIS current compatib
georgerosar
PHP:
ENTRY(ImageVectorTable)
/* Memory configuration */
#if MICROPY_HW_FLASH_RESERVED
reserved_size = MICROPY_HW_FLASH_RESERVED;
#if MICROPY_HW_FLASH_TYPE == qspi_nor_flash
flash_start = 0x60000000;
#elif MICROPY_HW_FLASH_TYPE == qspi_hyper_flash
#else
#error Unknown MICROPY_HW_FLASH_TYPE
#if MICROPY_HW_SDRAM_AVAIL
sdram_start = 0x80000000;
sdram_size = MICROPY_HW_SDRAM_SIZE;
flash_size = 0x2000000;
flash_end = DEFINED(reserved_size) ? ((flash_start) + (flash_size - reserved_size)) : ((flash_start) + (flash_size));
flash_config_start = flash_start;
flash_config_size = 0x00001000;
ivt_start = flash_start + 0x00001000;
ivt_size = 0x00001000;
interrupts_start = flash_start + 0x00002000;
interrupts_size = 0x00000400;
text_start = flash_start + 0x00002400;
vfs_start = flash_start + 0x00100000;
text_size = ((vfs_start) - (text_start));
vfs_size = ((flash_end) - (vfs_start));
itcm_start = 0x00000000;
itcm_size = 0x00020000;
dtcm_start = 0x20000000;
dtcm_size = 0x00020000;
ocrm_start = 0x20200000;
ocrm_size = 0x000C0000;
HEAP_SIZE = DEFINED(__heap_size__) ? __heap_size__ : 0x0400;
STACK_SIZE = DEFINED(__stack_size__) ? __stack_size__ : 0x0400;
reserved_size = DEFINED(reserved_size) ? reserved_size : 0k;
MEMORY
m_flash_config (RX) : ORIGIN = flash_config_start, LENGTH = flash_config_size
m_ivt (RX) : ORIGIN = ivt_start, LENGTH = ivt_size
m_interrupts (RX) : ORIGIN = interrupts_start, LENGTH = interrupts_size
m_text (RX) : ORIGIN = text_start, LENGTH = text_size
m_vfs (RX) : ORIGIN = vfs_start, LENGTH = vfs_size
m_reserved (RX) : ORIGIN = (vfs_start + vfs_size), LENGTH = reserved_size
m_itcm (RX) : ORIGIN = itcm_start, LENGTH = itcm_size
m_dtcm (RW) : ORIGIN = dtcm_start, LENGTH = dtcm_size
m_ocrm (RW) : ORIGIN = ocrm_start, LENGTH = ocrm_size
/* ERAM (rwx): ORIGIN = 0x70000000, LENGTH = 16384K */
m_sdram (RWX): ORIGIN = sdram_start, LENGTH = sdram_size
SECTIONS
__flash_start = flash_start;
__sdram_start = sdram_start;
__vfs_start = ORIGIN(m_vfs);
__vfs_end = __vfs_start + LENGTH(m_vfs);
.flash_config :
. = ALIGN(4);
__FLASH_BASE = .;
KEEP(* (.boot_hdr.conf))
. = ALIGN(4);
} > m_flash_config
ivt_begin = ORIGIN(m_flash_config) + LENGTH(m_flash_config);
.ivt : AT(ivt_begin)
. = ALIGN(4);
KEEP(* (.boot_hdr.ivt))
KEEP(* (.boot_hdr.boot_data))
KEEP(* (.boot_hdr.dcd_data))
. = ALIGN(4);
} > m_ivt
.interrupts :
__VECTOR_TABLE = .;
__Vectors = .;
__isr_vector = .;
. = ALIGN(4);
KEEP(*(.isr_vector))
. = ALIGN(4);
} > m_interrupts
__VECTOR_RAM = __VECTOR_TABLE;
__RAM_VECTOR_TABLE_SIZE_BYTES = 0x0;
.text.headers : ALIGN(4) {
FILL(0xFF)
KEEP(*(.flashconfig))
. = 0x1000;
KEEP(*(.ivt))
. = 0x1020;
KEEP(*(.bootdata))
. = ALIGN(1024);
} > m_text
.text :
. = ALIGN(4);
*(EXCLUDE_FILE(*fsl_flexspi.o *gc*.o *vm.o *parse.o *runtime*.o *mpirq.o *map.o) .text*)
/* read only data, this could be part of the issue, if something with the write flag is set here it might break */
*(.rodata)
*(.rodata*)
*(.glue_7)
*(.glue_7t)
*(.eh_frame)
KEEP (*(.init))
KEEP (*(.fini))
KEEP(*(.vectorsram))
. = ALIGN(4);
} > m_text
.text.code : ALIGN(4) {
*(.flashmem*)
KEEP(*(.startup))
. = ALIGN(4);
KEEP(*(.init))
__preinit_array_start = .;
KEEP (*(.preinit_array))
__preinit_array_end = .;
__init_array_start = .;
KEEP (*(.init_array))
__init_array_end = .;
. = ALIGN(4);
} > m_text
.text.progmem : {
*(.progmem*)
. = ALIGN(4);
} > m_text
.data.func : ALIGN(4) {
*(SORT_BY_ALIGNMENT(SORT_BY_NAME(.*__func__*)))
*(SORT_BY_ALIGNMENT(SORT_BY_NAME(.*__PRETTY_FUNCTION__*)))
. = ALIGN(4);
} > m_text
.text.itcm : {
. = . + 32;
*(.fastrun)
*(.text*)
. = ALIGN(16);
} > m_itcm AT> m_text
.data : AT(__DATA_ROM)
. = ALIGN(4);
__DATA_RAM = .;
__data_start__ = .;
__data_section_table = .;
*(m_usb_dma_init_data)
*(.endpoint_queue)
*(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*)))
*(SORT_BY_ALIGNMENT(SORT_BY_NAME(.data*)))
KEEP(*(.jcr*))
. = ALIGN(4);
__data_end__ = .;
__data_section_table_end = .;
} > m_text
.bss :
. = ALIGN(4);
__START_BSS = .;
__bss_start__ = .;
__bss_section_table = .;
*(m_usb_dma_noninit_data)
*(.bss)
*(.bss*)
*(COMMON)
. = ALIGN(4);
__bss_end__ = .;
__bss_section_table_end = .;
__END_BSS = .;
} > m_dtcm
.ARM.exidx : ALIGN(4) {
__exidx_start = .;
*(.gnu.linkonce.armexidx.*)
*(.ARM.exidx.fastrun*)
*(.ARM.exidx.text*)
*(.ARM.exidx)
*(.ARM.exidx.flashmem*)
*(.ARM.exidx.startup*)
. = ALIGN(4);
__exidx_end = .;
*(.ARM.extab* .gnu.linkonce.armextab.*)
. = ALIGN(4);
} > m_ocrm AT > m_text
.bss.dma (NOLOAD) : {
*(.hab_log)
*(SORT_BY_ALIGNMENT(SORT_BY_NAME(.dmabuffers)))
. = ALIGN(32);
} > m_ocrm
.bss.extram (NOLOAD) : ALIGN(32) {
*(SORT_BY_ALIGNMENT(SORT_BY_NAME(.externalram)))
. = ALIGN(32);
} > m_sdram
.text.csf : {
FILL(0xFF)
. = ALIGN(1024);
KEEP(*(.csf))
__text_csf_end = .;
} > m_text
.ctors :
__CTOR_LIST__ = .;
KEEP (*crtbegin.o(.ctors))
KEEP (*crtbegin?.o(.ctors))
KEEP (*(EXCLUDE_FILE(*crtend?.o *crtend.o) .ctors))
KEEP (*(SORT(.ctors.*)))
KEEP (*(.ctors))
__CTOR_END__ = .;
} > m_text
.dtors :
__DTOR_LIST__ = .;
KEEP (*crtbegin.o(.dtors))
KEEP (*crtbegin?.o(.dtors))
KEEP (*(EXCLUDE_FILE(*crtend?.o *crtend.o) .dtors))
KEEP (*(SORT(.dtors.*)))
KEEP (*(.dtors))
__DTOR_END__ = .;
} > m_text
.preinit_array :
PROVIDE_HIDDEN (__preinit_array_start = .);
KEEP (*(.preinit_array*))
PROVIDE_HIDDEN (__preinit_array_end = .);
} > m_text
.init_array :
PROVIDE_HIDDEN (__init_array_start = .);
KEEP (*(SORT(.init_array.*)))
KEEP (*(.init_array*))
PROVIDE_HIDDEN (__init_array_end = .);
} > m_text
.fini_array :
PROVIDE_HIDDEN (__fini_array_start = .);
KEEP (*(SORT(.fini_array.*)))
KEEP (*(.fini_array*))
PROVIDE_HIDDEN (__fini_array_end = .);
} > m_text
__etext = .;
__DATA_ROM = .;
__RAM_FUNCTIONS_ROM = __DATA_ROM + (__data_end__ - __data_start__);
/* problem in ram_functions */
.ram_functions : AT(__RAM_FUNCTIONS_ROM)
. = ALIGN(4);
__ram_function_start__ = .;
*(.ram_functions*)
*(.text*)
*(.got*)
*(.dynamic*)
/* from here below were in DISCARD */
*(.hash*)
*(.dynstr*)
*(.dynsym*)
/* from here above were in DISCARD */
/* from discard pile below */
*(.interp*)
/* from discard pile above */
. = ALIGN(4);
__ram_function_end__ = .;
} > m_itcm
__NDATA_ROM = __DATA_ROM + (__ram_function_end__ - __data_start__);
.ncache.init : AT(__NDATA_ROM)
__noncachedata_start__ = .;
*(NonCacheable.init)
. = ALIGN(4);
__noncachedata_init_end__ = .;
} > m_dtcm
. = __noncachedata_init_end__;
.ncache :
*(NonCacheable)
. = ALIGN(4);
__noncachedata_end__ = .;
} > m_dtcm
__DATA_END = __NDATA_ROM + (__noncachedata_init_end__ - __noncachedata_start__);
text_end = ORIGIN(m_text) + LENGTH(m_text);
ASSERT(__DATA_END <= text_end, "region m_text overflowed with text and data")
.heap :
. = ALIGN(8);
__end__ = .;
PROVIDE(end = .);
__HeapBase = .;
. += HEAP_SIZE;
__HeapLimit = .;
__heap_limit = .;
} > m_dtcm
.stack :
. = ALIGN(8);
. += STACK_SIZE;
} > m_dtcm
/DISCARD/ :
/* some of these need to probably be back in */
/* *(.ARM.exidx*) */
/* not the one above */
/* *(.interp*) */
/* these are not useful */
/* *(.ram_functions*) */
/* *(.got*) */
/* *(.rel.dyn*) */
__StackTop = ORIGIN(m_dtcm) + LENGTH(m_dtcm);
__StackLimit = __StackTop - STACK_SIZE;
_vStackTop = __StackTop;
PROVIDE(__stack = __StackTop);
.ARM.attributes 0 : { *(.ARM.attributes) }
ASSERT(__StackLimit >= __HeapLimit, "region m_dtcm overflowed with stack and heap")
_stext = ADDR(.text.itcm);
_etext = ADDR(.text.itcm) + SIZEOF(.text.itcm);
_stextload = LOADADDR(.text.itcm);
_sdata = ADDR(.data);
_edata = ADDR(.data) + SIZEOF(.data);
_sdataload = LOADADDR(.data);
_sexidx = ADDR(.ARM.exidx);
_eexidx = ADDR(.ARM.exidx) + SIZEOF(.ARM.exidx);
_sexidxload = LOADADDR(.ARM.exidx);
_sbss = ADDR(.bss);
_ebss = ADDR(.bss) + SIZEOF(.bss);
_heap_start = ADDR(.bss.dma) + SIZEOF(.bss.dma);
_heap_end = ORIGIN(m_ocrm) + LENGTH(m_ocrm);
_extram_start = ADDR(.bss.extram);
_extram_end = ADDR(.bss.extram) + SIZEOF(.bss.extram);
_itcm_block_count = (SIZEOF(.text.itcm) + 0x7FFF) >> 15;
_flexram_bank_config = 0xAAAAAAAA | ((1 << (_itcm_block_count * 2)) - 1);
_estack = ORIGIN(m_dtcm) + ((16 - _itcm_block_count) << 15);
_flashimagelen = __text_csf_end - ORIGIN(m_text);
_teensy_model_identifier = 0x25;
.debug_info 0 : { *(.debug_info) }
.debug_abbrev 0 : { *(.debug_abbrev) }
.debug_line 0 : { *(.debug_line) }
.debug_frame 0 : { *(.debug_frame) }
.debug_str 0 : { *(.debug_str) }
.debug_loc 0 : { *(.debug_loc) }
_gc_heap_start = ORIGIN(m_sdram);
/* NOTE THIS HAS TO BE REDUCED FOR THE EXTMEM TO WORK */
_gc_heap_end = ORIGIN(m_sdram) + LENGTH(m_sdram);
#else
/* Use second OCRAM bank for GC heap. */
_gc_heap_start = ORIGIN(m_ocrm);
_gc_heap_end = ORIGIN(m_ocrm) + LENGTH(m_ocrm);
link with -lc -lm -lTeensy41Core -larm_cortexM7lfsp_math -lstdc++ $(shell $(CXX) $(CXXFLAGS) $(CPUOPTIONS) -print-libgcc-file-name)
I honor any mimxrt projects in c that need to have a pkgconfig flag to ignore warnings for redefined macros and should hardline that purpose. in pkg-config .pc
CPUOPTIONS = -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -mthumb
LDFLAGS = -O2 \
-Wl,--cref,--gc-sections,--print-memory-usage,-Map=$@.map -L$(LIBPATHFILEDROP) -L$(abspath $(LIBPATHFILEDROP)/../../../../arm-none-eabi/lib/thumb/v7e-m+dp/hard) --specs=nano.specs
the MicroPython sdram is like this, neo
$(GEN_FLEXRAM_CONFIG_SRC):
	$(ECHO) "Create $@"
	$(Q)$(PYTHON) $(MAKE_FLEXRAM_LD) -d $(TOP)/$(MCU_DIR)/$(MCU_SERIES).h \
		-f $(TOP)/$(MCU_DIR)/$(MCU_SERIES)_features.h -l boards/$(MCU_SERIES).ld -c $(MCU_SERIES) > $(GEN_FLEXRAM_CONFIG_SRC)
just take out that horrible key logger from Teensyduino on Mac, you know we can see that on the new Macs, you're kinda crooked ole pjrc. Snoop on to those that snoop on you.
I have a 125GB tar ball of the work environment, it's huge. I'll transfer it to you when I get the cash, give me a night of rest tho.
Well this is really bizarre. Rather than just quickly delete this as junk (doesn't quite look like spam, no links or usual spammer stuff), does anyone have any idea what this is? Maybe a bot scraping stuff from NXP's community site?
