Compile problem with I2S and audio shield on Teensy
Teensy 4.0, Audio shield, Arduino IDE 2.0.0
I’m using a Teensy with audio shield to output several .wav files stored on an SD card. The Teensy is to receive commands from a Mega via I2S to play different .wav files.
I have successfully tested the Teensy plays audio with no I2S comms
I have successfully tested the Teensy receives I2S data from a Mega
In separate sketches.
When I try to amalgamate the two sets of code I get compile errors. Cutting the code down to the bare minimum, the incompatibility seems to arise from the #
include files. I suspect it might be a conflict between the I2S from Mega and I2S to shield but I don’t know how to solve this. Can anyone help?
Sketch :-
#include <Arduino.h>
#include <i2c_driver.h>
#include <i2c_driver_wire.h>
// audio stuff
// #include <Wire.h> not needed ??
Verbose compile Concatenated to character limit of 200k c
Using board 'teensy40' from platform in folder: /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0
Using core 'teensy4' from platform in folder: /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0
Detecting libraries used...
*** concatenated
I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/analyze_rms.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/analyze_tonedetect.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/async_input_spdif3.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/control_ak4558.cpp -o /dev/null
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
-> candidates: [Wire@1.0]
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/control_ak4558.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/control_cs42448.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/control_cs4272.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/control_sgtl5000.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/control_tlv320aic3206.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/control_wm8731.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/data_bandlimit_step.c -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/data_spdif.c -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/data_ulaw.c -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/data_waveforms.c -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/data_windows.c -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/effect_bitcrusher.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/effect_chorus.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/effect_combine.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/effect_delay.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/effect_delay_ext.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/effect_envelope.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/effect_fade.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/effect_flange.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/effect_freeverb.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/effect_granular.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/effect_midside.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/effect_multiply.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/effect_rectifier.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/effect_reverb.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/effect_wavefolder.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/effect_waveshaper.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/filter_biquad.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/filter_fir.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/filter_ladder.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/filter_variable.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/input_adc.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/input_adcs.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/input_i2s.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/input_i2s2.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/input_i2s_hex.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/input_i2s_oct.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/input_i2s_quad.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/input_pdm.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/input_pdm_i2s2.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/input_spdif3.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/input_tdm.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/input_tdm2.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/memcpy_audio.S -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/mixer.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/output_adat.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/output_dac.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/output_dacs.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/output_i2s.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/output_i2s2.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/output_i2s_hex.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/output_i2s_oct.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/output_i2s_quad.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/output_mqs.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/output_pt8211.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/output_pt8211_2.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/output_pwm.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/output_spdif.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/output_spdif2.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/output_spdif3.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/output_tdm.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/output_tdm2.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/play_memory.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/play_queue.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/play_sd_raw.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/play_sd_wav.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/play_serialflash_raw.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/record_queue.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/spi_interrupt.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/synth_dc.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/synth_karplusstrong.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/synth_pinknoise.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/synth_pwm.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/synth_simple_drum.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/synth_sine.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/synth_tonesweep.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/synth_waveform.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/synth_wavetable.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/synth_whitenoise.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility/imxrt_hw.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio/utility/sqrt_integer.c -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash/SerialFlashChip.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash/SerialFlashDirectory.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire/Wire.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire/WireIMXRT.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire/WireKinetis.cpp -o /dev/null
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire/utility /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire/utility/twi.c -o /dev/null
Generating function prototypes...
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/sketch/sketch_oct14b.ino.cpp -o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/preproc/ctags_target_for_gcc_minus_e.cpp
/Users/geraldlee/Library/Arduino15/packages/builtin/tools/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-tools/1.57.0/precompile_helper /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3 /Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -x c++-header -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/pch/Arduino.h -o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/pch/Arduino.h.gch
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/pch/Arduino.h.gch
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-g++ -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=157 -DARDUINO=10607 -DARDUINO_TEENSY40 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/pch -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4 -I/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat/src -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash -I/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/sketch/sketch_oct14b.ino.cpp -o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/sketch/sketch_oct14b.ino.cpp.o
Compiling libraries...
Compiling library "teensy4_i2c-1.1.0"
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/teensy4_i2c-1.1.0/tests/ina260_reliability.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/teensy4_i2c-1.1.0/i2c_register_slave.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/teensy4_i2c-1.1.0/imx_rt1060/imx_rt1060_i2c_driver.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/teensy4_i2c-1.1.0/tests/raw_loopback.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/teensy4_i2c-1.1.0/i2c_driver_wire.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/teensy4_i2c-1.1.0/tests/loopback_reliability.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/teensy4_i2c-1.1.0/tests/raspberry_pi_reliability.cpp.o
Compiling library "SPI"
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SPI/SPI.cpp.o
Compiling library "SD"
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SD/SD.cpp.o
Compiling library "SdFat"
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/ExFatLib/ExFatFilePrint.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/ExFatLib/ExFatName.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/ExFatLib/ExFatVolume.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/ExFatLib/ExFatFile.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/ExFatLib/upcase.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/ExFatLib/ExFatPartition.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/ExFatLib/ExFatFileWrite.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/ExFatLib/ExFatFormatter.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/ExFatLib/ExFatDbg.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/FatLib/FatFileSFN.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/FatLib/FatFileLFN.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/FatLib/FatFilePrint.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/FatLib/FatFile.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/FatLib/FatFormatter.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/FatLib/FatName.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/FatLib/FatDbg.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/FatLib/FatPartition.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/FreeStack.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/FsLib/FsNew.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/FatLib/FatVolume.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/MinimumSerial.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/SdCard/SdCardInfo.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/FsLib/FsFile.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/SpiDriver/SdSpiChipSelect.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/SdCard/SdSpiCard.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/SdCard/SdioTeensy.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/FsLib/FsVolume.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/SpiDriver/SdSpiArtemis.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/common/FsCache.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/SpiDriver/SdSpiDue.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/SpiDriver/SdSpiTeensy3.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/SpiDriver/SdSpiSTM32.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/SpiDriver/SdSpiESP.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/SpiDriver/SdSpiSTM32Core.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/SpiDriver/SdSpiParticle.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/common/FsUtf.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/common/FmtNumber.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/common/FsDateTime.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/common/PrintBasic.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/common/FsName.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/common/FsStructs.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/common/upcase.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/iostream/istream.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/iostream/StreamBaseClass.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/iostream/ostream.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/iostream/StdioStream.cpp.o
Compiling library "Audio"
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/analyze_notefreq.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/analyze_peak.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/analyze_rms.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/Quantizer.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/analyze_fft1024.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/analyze_tonedetect.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/analyze_fft256.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/analyze_print.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/Resampler.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/control_cs4272.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/control_cs42448.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/control_wm8731.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/data_bandlimit_step.c.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/control_ak4558.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/async_input_spdif3.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/data_spdif.c.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/control_sgtl5000.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/data_ulaw.c.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/data_waveforms.c.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/control_tlv320aic3206.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/effect_combine.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/effect_chorus.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/effect_delay_ext.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/data_windows.c.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/effect_delay.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/effect_freeverb.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/effect_envelope.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/effect_granular.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/effect_bitcrusher.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/effect_fade.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/effect_flange.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/effect_rectifier.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/effect_multiply.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/effect_wavefolder.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/effect_reverb.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/filter_ladder.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/filter_biquad.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/effect_midside.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/filter_fir.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/input_i2s.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/effect_waveshaper.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/filter_variable.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/input_i2s_hex.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/input_i2s2.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/input_pdm.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/input_adcs.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/input_adc.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/input_i2s_quad.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/input_pdm_i2s2.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/mixer.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/memcpy_audio.S.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/output_dac.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/output_dacs.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/input_i2s_oct.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/input_tdm2.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/input_tdm.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/output_i2s_hex.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/input_spdif3.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/output_i2s.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/output_i2s_oct.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/output_i2s2.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/output_pwm.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/output_adat.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/output_pt8211_2.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/output_tdm.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/output_tdm2.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/output_pt8211.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/output_spdif2.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/output_i2s_quad.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/play_queue.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/output_spdif.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/output_spdif3.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/play_sd_raw.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/output_mqs.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/play_memory.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/synth_karplusstrong.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/synth_dc.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/record_queue.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/play_serialflash_raw.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/synth_pwm.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/spi_interrupt.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/play_sd_wav.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/synth_sine.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/synth_simple_drum.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/synth_pinknoise.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/synth_waveform.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/synth_wavetable.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/synth_whitenoise.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/synth_tonesweep.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/utility/imxrt_hw.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/utility/sqrt_integer.c.o
Compiling library "SerialFlash"
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SerialFlash/SerialFlashChip.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SerialFlash/SerialFlashDirectory.cpp.o
Compiling library "Wire"
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Wire/Wire.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Wire/WireIMXRT.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Wire/WireKinetis.cpp.o
Using previously compiled file: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Wire/utility/twi.c.o
Compiling core...
Using precompiled core: /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-core-cache/core_d65e11fba575bab99f2afbcd4b175309.a
Linking everything together...
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/arm-none-eabi-gcc -O2 -Wl,--gc-sections,--relax -T/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/cores/teensy4/imxrt1062.ld -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/sketch_oct14b.ino.elf /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/sketch/sketch_oct14b.ino.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/teensy4_i2c-1.1.0/i2c_driver_wire.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/teensy4_i2c-1.1.0/i2c_register_slave.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/teensy4_i2c-1.1.0/imx_rt1060/imx_rt1060_i2c_driver.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/teensy4_i2c-1.1.0/tests/ina260_reliability.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/teensy4_i2c-1.1.0/tests/loopback_reliability.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/teensy4_i2c-1.1.0/tests/raspberry_pi_reliability.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/teensy4_i2c-1.1.0/tests/raw_loopback.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SPI/SPI.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SD/SD.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/ExFatLib/ExFatDbg.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/ExFatLib/ExFatFile.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/ExFatLib/ExFatFilePrint.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/ExFatLib/ExFatFileWrite.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/ExFatLib/ExFatFormatter.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/ExFatLib/ExFatName.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/ExFatLib/ExFatPartition.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/ExFatLib/ExFatVolume.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/ExFatLib/upcase.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/FatLib/FatDbg.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/FatLib/FatFile.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/FatLib/FatFileLFN.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/FatLib/FatFilePrint.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/FatLib/FatFileSFN.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/FatLib/FatFormatter.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/FatLib/FatName.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/FatLib/FatPartition.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/FatLib/FatVolume.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/FreeStack.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/FsLib/FsFile.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/FsLib/FsNew.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/FsLib/FsVolume.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/MinimumSerial.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/SdCard/SdCardInfo.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/SdCard/SdSpiCard.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/SdCard/SdioTeensy.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/SpiDriver/SdSpiArtemis.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/SpiDriver/SdSpiChipSelect.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/SpiDriver/SdSpiDue.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/SpiDriver/SdSpiESP.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/SpiDriver/SdSpiParticle.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/SpiDriver/SdSpiSTM32.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/SpiDriver/SdSpiSTM32Core.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/SpiDriver/SdSpiTeensy3.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/common/FmtNumber.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/common/FsCache.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/common/FsDateTime.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/common/FsName.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/common/FsStructs.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/common/FsUtf.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/common/PrintBasic.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/common/upcase.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/iostream/StdioStream.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/iostream/StreamBaseClass.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/iostream/istream.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SdFat/iostream/ostream.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/Quantizer.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/Resampler.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/analyze_fft1024.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/analyze_fft256.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/analyze_notefreq.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/analyze_peak.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/analyze_print.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/analyze_rms.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/analyze_tonedetect.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/async_input_spdif3.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/control_ak4558.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/control_cs42448.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/control_cs4272.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/control_sgtl5000.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/control_tlv320aic3206.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/control_wm8731.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/data_bandlimit_step.c.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/data_spdif.c.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/data_ulaw.c.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/data_waveforms.c.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/data_windows.c.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/effect_bitcrusher.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/effect_chorus.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/effect_combine.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/effect_delay.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/effect_delay_ext.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/effect_envelope.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/effect_fade.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/effect_flange.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/effect_freeverb.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/effect_granular.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/effect_midside.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/effect_multiply.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/effect_rectifier.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/effect_reverb.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/effect_wavefolder.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/effect_waveshaper.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/filter_biquad.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/filter_fir.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/filter_ladder.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/filter_variable.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/input_adc.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/input_adcs.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/input_i2s.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/input_i2s2.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/input_i2s_hex.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/input_i2s_oct.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/input_i2s_quad.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/input_pdm.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/input_pdm_i2s2.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/input_spdif3.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/input_tdm.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/input_tdm2.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/memcpy_audio.S.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/mixer.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/output_adat.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/output_dac.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/output_dacs.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/output_i2s.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/output_i2s2.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/output_i2s_hex.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/output_i2s_oct.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/output_i2s_quad.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/output_mqs.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/output_pt8211.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/output_pt8211_2.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/output_pwm.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/output_spdif.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/output_spdif2.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/output_spdif3.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/output_tdm.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/output_tdm2.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/play_memory.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/play_queue.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/play_sd_raw.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/play_sd_wav.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/play_serialflash_raw.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/record_queue.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/spi_interrupt.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/synth_dc.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/synth_karplusstrong.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/synth_pinknoise.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/synth_pwm.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/synth_simple_drum.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/synth_sine.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/synth_tonesweep.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/synth_waveform.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/synth_wavetable.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/synth_whitenoise.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/utility/imxrt_hw.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Audio/utility/sqrt_integer.c.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SerialFlash/SerialFlashChip.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/SerialFlash/SerialFlashDirectory.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Wire/Wire.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Wire/WireIMXRT.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Wire/WireKinetis.cpp.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Wire/utility/twi.c.o /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/../arduino-core-cache/core_d65e11fba575bab99f2afbcd4b175309.a -L/private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3 -larm_cortexM7lfsp_math -lm -lstdc++
.data.Wire2+0x0): multiple definition of `Wire2'
.bss.Wire2+0x0): first defined here
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ld: Disabling relaxation: it will not work with multiple definitions
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ld: Warning: size of symbol `Wire2' changed from 120 in /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/teensy4_i2c-1.1.0/i2c_driver_wire.cpp.o to 320 in /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Wire/WireIMXRT.cpp.o
/private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Wire/WireIMXRT.cpp.o: In function `Print::availableForWrite()':
/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire/WireIMXRT.cpp:17: multiple definition of `Wire1'
/private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/teensy4_i2c-1.1.0/i2c_driver_wire.cpp.o:/Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0/src/i2c_driver_wire.cpp:139: first defined here
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ld: Warning: size of symbol `Wire1' changed from 120 in /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/teensy4_i2c-1.1.0/i2c_driver_wire.cpp.o to 320 in /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Wire/WireIMXRT.cpp.o
/Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire/WireIMXRT.cpp:17: multiple definition of `Wire'
/Users/geraldlee/Library/Arduino15/packages/teensy/tools/teensy-compile/5.4.1/arm/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ld: Warning: size of symbol `Wire' changed from 120 in /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/teensy4_i2c-1.1.0/i2c_driver_wire.cpp.o to 320 in /private/var/folders/6t/qxn3nfmj70zdrv1mw294z2nh0000gn/T/arduino-sketch-C2F1ECB150CABCC2C9772A60BFC971A3/libraries/Wire/WireIMXRT.cpp.o
collect2: error: ld returned 1 exit status
Using library teensy4_i2c-1.1.0 at version 1.1.0 in folder: /Users/geraldlee/Dropbox/Documents/Trains/Arduino/libraries/teensy4_i2c-1.1.0
Using library SPI at version 1.0 in folder: /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SPI
Using library SD at version 2.0.0 in folder: /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SD
Using library SdFat at version 2.1.2 in folder: /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SdFat
Using library Audio at version 1.3 in folder: /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Audio
Using library SerialFlash at version 0.5 in folder: /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/SerialFlash
Using library Wire at version 1.0 in folder: /Users/geraldlee/Library/Arduino15/packages/teensy/hardware/avr/1.57.0/libraries/Wire
exit status 1
Compilation error: exit status 1
I think you are mixing Arduino headers with Teensy. Try using these for the header:
#include <Arduino.h>
//#include <i2c_driver.h>
//#include <i2c_driver_wire.h>
// audio stuff
Teensy receives I2S data from a Mega
I presume you mean I2C.
Pete
Yes I2C. Compile works, thanks very much. Gerald
- You may not post replies
- You may not edit your posts
Forum Rules
