#include <USBHost_t36.h>
USBHost usbHost;
USBHub usbHub(usbHost);
USBDrive usbDrive(usbHost);
USBFilesystem usbPart(usbHost);
File root;
while (!Serial && millis() < 5000) {
// wait for serial port to connect.
usbHost.begin();
delay(3000);
// if a partition isn't currently connected
if (!usbPart) {
// In case it was previously opened and the disc was removed.
root.close();
// Is there are disk available?
if (usbDrive) {
Serial.print("\nInitializing USB MSC drive...");
if (!usbPart.begin(&usbDrive)) {
Serial.println("Failed!");
return;
Serial.println("Success!");
// No disk is available.
else {
Serial.println("Insert a USB drive / memory stick...");
return;
// Partition is connected, but the filesystem hasn't been opened.
else if (!root){
root = usbPart.open("/");
if (root) {
Serial.println("------------------------------------------");
printDirectory(root, 0);
Serial.println("-------------------------------------------");
void printDirectory(File dir, int numSpaces) {
while(true) {
File entry = dir.openNextFile();
if (! entry) {
//Serial.println("** no more files **");
printSpaces(numSpaces);
Serial.print(entry.name());
if (entry.isDirectory()) {
Serial.println("/");
printDirectory(entry, numSpaces+2);
// files have sizes, directories do not
printSpaces(48 - numSpaces - strlen(entry.name()));
Serial.print(" ");
Serial.println(entry.size(), DEC);
entry.close();
void printSpaces(int num) {
for (int i=0; i < num; i++) {
Serial.print(" ");
Notes: I'm actually surprised that I needed to call root.close() after the drive is removed from the USB host port. I would expect this method to be called automatically when the drive was removed. Perhaps this is a bug?
