Hi, I have just soldered some header pins to a newly purchased Teensy 4.1, when plugged in to my pc via USB all that happens is the red LED next to the USB socket flashes 4 times at about 0.5 second intervals with a 2 second delay between flash cycles. The Teensy is not detected by my PC (windows 10) using 2 different USB cables both of which work with my 2 Teensy LC and my newly bought (no headers) 4.0. I stupidly didn't check to see if it worked before I soldered the headers. Is the flashing LED an error code, if so what does it mean as searching could not find me an answer.
Many Thanks.
Many Thanks.
