I am very new to the Teensy, so I have been working my way through the Audio tutorial workshop:
https://hackaday.io/project/8292-microcontroller-audio-workshop-had-supercon-2015
I have been able to complete the Section 1 of the tutorial. Here is a picture of my set-up:
Teensy 4.1 with Rev D audio shield
*Note: All connections to the audio shield are soldered.
However, after much trial-and-error, I cannot get the LED to blink while playing music, steps 1-4 and 1-5. I traced the issue in the source code and found that the line...
pinMode(13, OUTPUT)
... is causing the issue. If I comment out this line of code and run the program, I hear the music and all other concurrent functions (ie. printing to process monitor, delays, etc.) work as expected.
After figuring this out I put a new number into the pinMode() method (ie. pinMode(2, OUTPUT)), and the program ran as expected.
Finally, I put in the original code and found where there program is crashing:
if (playSdWav1.isPlaying() == false) {
Serial.println("Start playing");
playSdWav1.play("SDTEST3.WAV");
Serial.println("test");
delay(10); // wait for library to parse WAV info
The added println statement (Serial.println("test")) will not be executed. Therefore, I'm assuming that the line playSdWav1.play("SDTEST3.WAV") is what is causing the program not to work. Other than this println statement, I have not modified the code in any way. Additionally, I don't think there is anything wrong with my LED because I can ran the example blink testing program without issue.
pinMode(13, OUTPUT)
