teensyweensyz
Hi PJRC forums,
I have two i2c devices hooked up to i2c-0 and i2c-1 on a Teensy 4.0.
I can talk to the i2c-0 device just fine using Wire because they are the default pins. However, I do not know the most efficient way to talk to a second i2c device that is connected to i2c-1.
I would like to avoid rewiring anything if at all possible.
Should I be modifying the Wire library or using some other method?
Any advice to assist would be welcomed. Thank you.
