Jan Tieghem
My prototype of a small MIDI-controller was working fine as long as it was on breadboard. Now I'm trying to use these https://www.benl.ebay.be/itm/274958617109?var=575239312093 to connect to the Teensy that sits inside an enclosure, by wiring USB V+, D-, D+ and GND to the pads on the bottom of the Teensy, but the board isn't showing up in the Tools->Port menu of Teensyduino, neither does my DAW find the MIDI device.
Double checked wiring, all is fine. Connecting through the standard Micro USB socket of the board works fine, both from Teensyduino as from within MIDI software. Replacing the above USB-C connector with an USB-A bus didn't help. What am I doing wrong? Micro USB has 5 wires, but I don't see why connecting only V+, D-, D+ and GND wouldn't work. I don't use any external power, just the USB +5V, and the above USB-C bus has only the mentioned connections.
TIA!
TIA!
