Hello!
I'm currently working on a MIDI controller with 32 potentiometers. I want to design a PCB which has a multiplexer on it, in order to "extend" the amount of pins.
In total, Im going to use four of these PCBs to read out the 32 potis.
One PCB is reading out 8 potentiometers. Right now I'm looking for a proper way to connect the potis to the PCB. I was thinking about using an IDC connector but I also thought about using these ATX cables for this purpose, especially because they have a clamp which makes the connections less likely to get loose.
My question is whether I can use the ATX cable for the potis or should I stick to IDC.
Here is a link to the one I found:
https://www.reichelt.de/kabel-mainb...o_LREBWoikmKuFL7igvBuZIp-MRoCfWkQAvD_BwE&&r=1
Thank you in advance!
