Any help would be super appreciated. I struggle to understand why this doesn't work and have been stuck for some weeks no without any idea what to test next. I've also tested with another Teensy 3.2 (both installed on an OctoWS2811) so I think I can exclude malfunction of the Teensy's.
In case that's not easily seen on the pictures these are the connections I have now in place -
Teensy 3.2 <--> RS 485 board
Pin 0 (but also tested pin 1) <--> TXD
Pin 1 (but also tested pin 0)<--> RXD
5V <--> VCC
GND <--> GND
RS 485 <--> DMX 3-pin
A+ <--> Pin 3, Data +
B- <--> Pin 2, Data -
GND <--> Pin 1, GND
For the record: Naturally, also tested the BasicReceive example which also does not seem to receive data.
* A basic toy receive example, demonstrating single- and
* multi-byte reads.
* This example is part of the TeensyDMX library.
* (c) 2019-2020 Shawn Silverman
#include <cstring>
#include <TeensyDMX.h>
namespace teensydmx = ::qindesign::teensydmx;
// Create the DMX receiver on Serial1.
teensydmx::Receiver dmxRx{Serial1};
// The last value on the channel, for knowing when to print a change
// (Example 1).
uint8_t lastValue = 0;
// Buffer in which to store packet data (Example 2).
uint8_t packetBuf[3]{0};
// The last values received on channels 2-4, initialized to zero.
uint8_t rgb[3]{0};
// Serial initialization, for printing things
while (!Serial && millis() < 4000) {
// Wait for initialization to complete or a time limit
Serial.println("Starting BasicReceive.");
// Turn on the LED, for indicating activity
pinMode(LED_BUILTIN, OUTPUT);
digitalWriteFast(LED_BUILTIN, HIGH);
// Start the receiver
dmxRx.begin();
// Print the first values
lastValue = dmxRx.get(1);
Serial.printf("Channel 1: %d\n", lastValue);
// Note: If this reads < 3 bytes then the other values will stay at
// zero (because 'rgb' was initialized to zero, above)
dmxRx.readPacket(rgb, 10, 3);
Serial.printf("RGB: %d %d %d\n", rgb[0], rgb[1], rgb[2]);
// The following two examples print values when they change
// Example 1. Get the current value of channel 1.
// This will return zero for no data (and also for data that's zero)
uint8_t v = dmxRx.get(1);
if (v != lastValue) {
lastValue = v;
Serial.printf("Channel 1: %d\n", v);
// Example 2. Read channels 2-4.
// A return of -1 means no data, and a value < 3 means that there
// was data, but the received packet wasn't large enough to contain
// channels 10-12
int read = dmxRx.readPacket(packetBuf, 2, 3);
if (read == 3) {
if (memcmp(packetBuf, rgb, 3) != 0) {
memcpy(rgb, packetBuf, 3);
