Senior Member+
Originally Posted by
PaulStoffregen
@Defragster - please start a new thread regarding any issues other than this problem where Arduino 2.0.2's Upload becomes disabled. Maybe edit msg #13 & msg #14 to be just a link to that new thread? Let's keep this thread only about the issue where Upload gets disabled (for reasons as-yet unknown...)
Paul - I created a new thread... I have not edited the ones above. Probably Defragster would be better at transferring the applicable information from those postings into the other thread.
Arduino has opened issue #1772 regarding this problem (Upload menu disabled, not the new thread about lack of serial monitor screen refresh)
https://github.com/arduino/arduino-ide/issues/1722
Since the issue specifically mentions 4 Arduino brand products affected, seems likely they'll fix it sooner rather than later.
Senior Member+
Indeed, KurtE caught the 'new thread' note before I saw it - moved those long 'repro' posts over ... New thread is: Arduino-IDE2-Serial-Monitor-sometimes-does-not-work-continue-from-Upload-Thread
Just came back from 'title' scanning open IDE 2 issues and didn't see anything covering that issue - got as far as the olde issue I created where 'Serial Print Speed' sketch at 480 Mbps won't allow disable of AUtoScroll.
Looked at issue\1508 and that is a 'port open by other' conflict that doesn't apply. Perhaps will make cleaner sketch and post there and if clear repro open an IDE issue ...
- You may not post replies
- You may not edit your posts
Forum Rules
