Results 1 to 3 of 3
Thread: Teensy 108F normal?
    Teensy 108F normal?
    I have a Teensy 4.1 driving about a thousand WS2812 pixels via octoWS2811 library (4 outputs of 250 each).
    The CPU is hitting 108 F. Is that normal? This is for a wearable so anything over body temp is a concern.
    I have the entire Teensy heat shrink wrapped which I know doesn't help.
    Teensy is powered by USB port, and LEDs are powered by 2 usb ports (500 leds per port) each port pulls about 2.2 amps so 4.4 amps total + whatever the teensy is pulling. The LED plugs are also getting hot, can anyone recommend a better plug than what I'm using? (see attachments)
    Complete code if needed:
    #include <OctoWS2811.h>
    const int numPins = 4;
    byte pinList[numPins] = {0, 1, 13, 14};
    const int ledsPerStrip = 250;
    const int bytesPerLED = 3;  // change to 4 if using RGBW
    DMAMEM int displayMemory[ledsPerStrip * numPins * bytesPerLED / 4];
    int drawingMemory[ledsPerStrip * numPins * bytesPerLED / 4];
    const int config = WS2811_GRB | WS2811_800kHz;
    OctoWS2811 leds(ledsPerStrip, displayMemory, drawingMemory, config, numPins, pinList);
    int rainbowColors[180];
    int BRIGHTNESS = 50; // 0-100
      for (int i=0; i<180; i++) {
        int hue = i * 2;
        int saturation = 100;
        int lightness = BRIGHTNESS;
        // pre-compute the 180 rainbow colors
        rainbowColors[i] = makeColor(hue, saturation, lightness);
      leds.begin();
      leds.show();
      rainbow(10, 2500);
    void rainbow(int phaseShift, int cycleTime)
      int color, x, wait;
      wait = cycleTime * 1000 / ledsPerStrip;
      for (color=0; color < 180; color++) {
        for (x=0; x < leds.numPixels(); x++) {
          int index = (color + x) % 180;
          leds.setPixel(x, rainbowColors[index]);
        leds.show();
        delayMicroseconds(wait);
    int makeColor(unsigned int hue, unsigned int saturation, unsigned int lightness)
      unsigned int red, green, blue;
      unsigned int var1, var2;
      if (hue > 359) hue = hue % 360;
      if (saturation > 100) saturation = 100;
      if (lightness > 100) lightness = 100;
      // algorithm from: http://www.easyrgb.com/index.php?X=MATH&H=19#text19
      if (saturation == 0) {
        red = green = blue = lightness * 255 / 100;
        if (lightness < 50) {
          var2 = lightness * (100 + saturation);
          var2 = ((lightness + saturation) * 100) - (saturation * lightness);
        var1 = lightness * 200 - var2;
        red = h2rgb(var1, var2, (hue < 240) ? hue + 120 : hue - 240) * 255 / 600000;
        green = h2rgb(var1, var2, hue) * 255 / 600000;
        blue = h2rgb(var1, var2, (hue >= 120) ? hue - 120 : hue + 240) * 255 / 600000;
      return (red << 16) | (green << 8) | blue;
    unsigned int h2rgb(unsigned int v1, unsigned int v2, unsigned int hue)
      if (hue < 60) return v1 * 60 + (v2 - v1) * hue;
      if (hue < 180) return v2 * 60;
      if (hue < 240) return v1 * 60 + (v2 - v1) * (240 - hue);
      return v1 * 60;
ID:	29791   Click image for larger version.
    27,085
    Yikes, that's hot. Definitely not normal for free air convention cooling, but if tightly wrapped in an insulator, could happen.
    Try reducing the speed in Tools > CPU Speed. If you can run at only 528 MHz or even 396 MHz, it should run quite a bit cooler.
    Thanks for the prompt reply Paul!
    Okay, so glad to know that's not normal, and there might be something I can do.
    The heat shrink was really just to keep the wires in place, so if I move two of the outputs from pins 13,14,Gnd to 22/23/Gnd, I should be able to only heat-shrink the USB port side, and leave the CPU exposed. I will test and write back.
    I had considered reducing the CPU, but I will need to test this extensively. The use case is that this would be worn on stage during a musical performance, where the LEDs must be responsive to the music, so framerate and responsiveness/timing is essential.
    BTW, it won't be audio-reactive via a mic, we're planning on having a laptop running ableton which passes midi data to touch designer, which then creates patterns for the LEDs, and sends it to the Teensy over ethernet.
