IIC onReceive is called 3 times for each onRequest weirdness
Purzel
Hi all,
I have the weirdest I²C trouble with my setup, in short, every time the master is sending a "Wire.requestFrom()", the slave not only runs the onRequest function but also the onReceive function. From the code, the slave receives three bytes of data.
My setup:
master: Teensy 4.1
slave: TeensyLC
Pullups: 4k7 on SDA/SCL
VSCode & PlatformIO
Wire Library Version 1.0 (as PlatformIO tells me)
//Master
#include <Wire.h>     //I2C communication
//##### SETUP
void setup(){
  Wire.begin(); //start I2C
//##### LOOP
void loop(){
  Wire.requestFrom(0x08,8,1); //request 8 bytes
  while(Wire.available()){
    Wire.read();
  delay(3000);
  uint8_t send_status = 1;  //send
  while(send_status != 0){
    Wire.beginTransmission(0x08);
    Wire.write(1);
    send_status = Wire.endTransmission();
  delay(3000);
//Slave
volatile uint8_t bytes_in = 0;
uint8_t mybuffer[8] = {0,1,2,3,4,5,6,7};
//##### SETUP
void setup(){
  //I2C Setup
  Wire.begin(0x08);             //join I2C Bus at address 8 (0-7 is reserved)
  Wire.onRequest(sendData);     //what to do when being talked to
  Wire.onReceive(receiveEvent); //what to do with data received
//##### LOOP
void loop(){
  if(bytes_in){
    Serial.println(bytes_in);
    bytes_in = 0;
//##### FUNCTIONS
//send data on request
void sendData(){
    Wire.write(mybuffer,8);
//receive data
void receiveEvent(int bytes_incoming){
    Wire.read();
    bytes_in += 1;
--- Terminal on /dev/ttyACM1 | 9600 8-N-1
--- Available filters and text transformations: colorize, debug, default, direct, hexlify, log2file, nocontrol, printable, send_on_enter, time
--- More details at https://bit.ly/pio-monitor-filters
--- Quit: Ctrl+C | Menu: Ctrl+T | Help: Ctrl+T followed by Ctrl+H
1
3
1
3
1
3
As a side note, using i2c_t3 library, the error is gone. So must be something in the wire library. And to be totally honest, I think I will just use this library.
