Results 1 to 12 of 12
Thread: 4.1 pin descriptions
    Most of the time I can figure things out but at the moment the pin definitions on the 4.1 have me a bit confused. In particular the "yellow" pins on the breakout card. Some are understandable like Mqsr, Mclk1 and such but others a a mystery. Is there a more detailed description some where?
    27,348
    Those are the digital audio pins.
    11,371
    Was not enough room on card for Paul to fit everything. But if you look at at other boards cards, yellow shows digital audio.
    Edit, I see Paul beat me to it.
    As I have mentioned before, I have my own excel spreadsheet with more detail.
    Picture of one page
    And?? . Other than using the audio module plugged in is there a description? Not trying to be a pain, but knowledge is everything .
    11,371
    Quote Originally Posted by msaine View Post
    Look at chapters 37-40 in the IMXRT reference manual, and if you have not already downloaded it, you can from the PJRC webpage: https://www.pjrc.com/store/teensy41.html#tech
    For example, some of the pins are for the: Medium Quality Sound (MQS) and the signals are described in chapter 39
    There are also some that are SPDIF chapter 40
    And the others are SAI pins (chapter 38)
    Another page from my excel:
    Note they are marked in blue on this page
    Thanks for the response, I appreciate it. Sometimes what is obvious to some is magic to others. Even at 75 I am still learning daily!
    Nov 2022
    FRANCE
    6
    Hello everyone,
    Do somebody know why pin numbering doesn't match beetween Teensy 4.1 schematics and Xpresso IDE with MIMXRT1062 .
    For example PIN13, the famous LED which is also called B0_03 is routed to pin D8 according to Teensy schematic and B10 according to NXP IDE Click image for larger version.
    I know that is not very important but with such many possible configurations the primary key is pin number.
    Many thx
    Fred
    11,371
    Quote Originally Posted by Fred_B View Post
    Hello everyone,
    Many thx
    Fred
    As you mentioned GPIO_B0_03 is used as logical pin 13 on the Teensy 4, 4.1...
    And on the 12 x 12mm IMX it is on the 12 x 12 BALL named: D8
    Which you can find in the IMXRT data sheets. Which you can download from: https://www.pjrc.com/store/teensy41.html#tech
    As for Xpresso IDE, they may choose to use a completely different naming/numbering convention on how to use the pin named: GPIO_B0_03
    Never used it so, not sure.
    Nov 2022
    FRANCE
    6
    Thank you for your reply.
    It's was my fault, I made a confusion between RT1062DVJB which is the chip on the TEENSY board and RT1062DVNB the sdk loaded in my MCUXpresso config.
    On TEENSY it's a 196 BGA and in my config a 225BGA. OOPS
    Thanks again and sorry it was a stupid question.
    27,348
    Yes. Documentation for all the possible audio interfaces is in the audio library design tool.
    https://www.pjrc.com/teensy/gui/
    As you click on the features on the left side panel, or drag them onto the canvas and click on them, the right side documentation panel updates with the info about the thing you have clicked. All the inputs and outputs have a "Hardware" section in their documentation which tells you the pins and other essential info needed.
    The design tool also knows how each input and output utilizes hardware resources, so if you drag 2 or more onto the canvas which conflict, either by needing the same pins in a non-shared way, or by other types of more subtle conflicts like how audio sample rate controlled, you'll see little yellow error icons appear.
    Feb 2020
    143
    KurtE - can i get a copy of your pin spreadsheet? This looks like something I could use!
    11,371
    Quote Originally Posted by Fluxanode View Post
    It is up in my github project: https://github.com/kurte/teensydocuments
