Hi friends!
I'm using a Teensy 4.0 with the audio adapter for a new instrument, and as part of the project I've incorporated an audioEffectDelay object.
It works great, but I'm having a problem getting the stated 4 seconds of delay time out of it.
This is the section in delay.h which talks about limits:
As far as I can tell, these numbers check out, and should let the T4 do 4 seconds of delay. However, I run into a limit at about 2.4 seconds.
This simple code example demonstrates the issue, by running a simple drum through a delay object, and having a potentiometer connected on pin 15 to change the delay time:
When running this code, the audioMemoryUsageMax, as shown in the serial monitor tops out at 896 blocks, which is about 2.4 seconds.
I've tried different values for audioMemory, but that doesn't change this limit.
Digging into the forum a bit to figure this out, I found a thread from 2019 where Paul talks about updating the limits for T4. Here's the thread: https://forum.pjrc.com/threads/58295-Maximum-delay-for-Teensy-4-0
But when I look at the github commit he mentions (in post#3), I can see that the T4 limit is updated to the same value as the T3.6: https://github.com/PaulStoffregen/Audio/commit/9712139aedde94989218b7dccfe3e114ce763a15
In the latest version of the library it's higher for the T4, so it was obviously changed again at a later date.
He also mentions that you can change the limit to whatever you want in delay.cpp, but I don't see how that's possible, as it just calls the DELAY_QUEUE_SIZE from delay.h, and those limits don't seem to respected anyway.
But to thicken the plot even further, I found this thread from 2017, where Paul specifically mentions (in post#6) setting a limit for the T3.6 at 896 blocks, exactly the number that I get in my tests..... : https://forum.pjrc.com/threads/45053-Problems-with-AudioEffectDelay-Teensy3-2-vs-Teensy3-6
Is it possible that there is a hard limit still hiding somewhere in the library, that's keeping the Teensy 4.0 from reaching its full awesome delay potential?
I'm probably missing some very obvious detail, which is usually the case, so thanks in advance for any guidance or helpful suggestions.
Jeppe
#if defined(__IMXRT1062__)
// 4.00 second maximum on Teensy 4.0
#define DELAY_QUEUE_SIZE (176512 / AUDIO_BLOCK_SAMPLES)
#elif defined(__MK66FX1M0__)
// 2.41 second maximum on Teensy 3.6
#define DELAY_QUEUE_SIZE (106496 / AUDIO_BLOCK_SAMPLES)
#elif defined(__MK64FX512__)
// 1.67 second maximum on Teensy 3.5
#define DELAY_QUEUE_SIZE (73728 / AUDIO_BLOCK_SAMPLES)
#elif defined(__MK20DX256__)
// 0.45 second maximum on Teensy 3.1 & 3.2
#define DELAY_QUEUE_SIZE (19826 / AUDIO_BLOCK_SAMPLES)
#else
// 0.14 second maximum on Teensy 3.0
#define DELAY_QUEUE_SIZE (6144 / AUDIO_BLOCK_SAMPLES)
#include <synth_simple_drum.h>
#include <ResponsiveAnalogRead.h>
ResponsiveAnalogRead timeKnob(15, true);
AudioSynthSimpleDrum drum;
AudioEffectDelay delay1;
AudioMixer4 mixer;
AudioOutputI2S i2s1;
AudioConnection patchCord1(drum, 0, mixer, 0);
AudioConnection patchCord2(drum, 0, delay1, 0);
AudioConnection patchCord3(delay1, 0, mixer, 1);
AudioConnection patchCord4(mixer, 0, i2s1, 0);
AudioConnection patchCord5(mixer, 0, i2s1, 1);
static uint32_t next;
int16_t delayTime = 1000;
// audio library init
AudioMemory(1500);
next = millis() + 1000;
AudioNoInterrupts();
drum.frequency(60);
drum.length(300);
drum.secondMix(0.0);
drum.pitchMod(1.0);
mixer.gain(0, 0.5);
mixer.gain(1, 0.5);
sgtl5000_1.enable();
sgtl5000_1.volume(0.5);
delay1.delay(0, delayTime);
AudioInterrupts();
timeKnob.update();
if(timeKnob.hasChanged()){
int tempVal = timeKnob.getValue();
delayTime = map(tempVal, 0, 1023, 100, 4000);
if(millis() == next){
drum.noteOn();
Serial.print("Diagnostics: ");
Serial.print(AudioMemoryUsage());
Serial.print(" ");
Serial.println(AudioMemoryUsageMax());
Jeppe
