Results 1 to 5 of 5
Thread: Why is ARM_DWT_CYCCNT Cycle counternot running default on Teensy 3.x? Disadvantages?
    Dec 2016
    EU
    217
    Hi
    Why is ARM_DWT_CYCCNT running default on Teensy 4.x and not on Teensy 3.x?
    Are there disadvantages on having the following code in setup by default?
    if ( ARM_DWT_CYCCNT == ARM_DWT_CYCCNT )
    { // Enable CPU Cycle Counter
        ARM_DEMCR    |= ARM_DEMCR_TRCENA;         // enable debug/trace
        ARM_DWT_CTRL |= ARM_DWT_CTRL_CYCCNTENA;   // enable cycle counter
    16,708
    ARM_DWT_CYCCNT was enabled early in T_4.0 Beta development as a tool to calculate micros() offset from last millis().
    Millis is run from a slow clock (24 MHz IIRC?) and that would not provide good micros() resolution beyond 10's of us.
    So, starting ARM_DWT_CYCCNT to track the cycles since the last millisecond sys tick gave it resolution against typical 600 MHz clock.
    T_LC doesn't have the ARM_DWT_CYCCNT though all other T_3.x's do. And there was never a 'system' need to enable it like the T_4.x.
    Not sure there is a reason it couldn't be done on reset for T_3.x's, but that's how it is - and why T_4.x has it running.
    Sep 2021
    170
    Quote Originally Posted by AlainD View Post
    Hi
    Simple. It's not needed by the firmware on T3. You can enable it, of course.
    27,395
    Teensy LC lacks the ARM DWT hardware. An #ifdef check would be needed to not compile it with Teensy LC.
    Dec 2016
    EU
    217
    I know it doens't run on LC, because absent in the CPU.
