Hi all
I have a simple app written in MIT App inventor 2. It's throwing out a text data stream once a second as a text file arranged as the following:
Y
\n
The Y at the beginning lets me know the set of data that I am receiving (in this case, 3 sets of 3 digits). That appears to work fine.
I am using the first letter to determine the following data's job.
The following 9 digits are 3x sets of numerical data. If the Bluetooth module sends a 1 for instance, then it always sends the data as 3 digits (so it sends 001). The variable is always between 0-100.
Maybe this is an odd way of sending the data, but I thought it would work.
But, HC-06 is connected to my Teensy 3.2 and I am having difficulty reading this data effectively. Is once a second too often? I would have thought not.
Excuse the scruffy code, it's prototyping time.
Now there is a delay(30) in the serial reading loop which I know is a big no-no, but it actually works better like that.
I will bin all the serial prints, once I know it is working.
What is a better way to read the incoming BT data? Surely it need to decide that there is data, then loop putting that data into commandbuffer[btcount] until it reaches \n.
Any assistance gratefully received.
Y
\n
#include <wavTrigger.h> //Wav trigger library for SFX and music
wavTrigger wTrig; //Initialise the wav trigger
int led = 13;
//------------------ Variables ----------------------
int gRateOffset = 0; // WAV Trigger sample-rate offset
int gNumTracks; // Number of tracks on SD card
char gWTrigVersion[VERSION_STRING_LEN]; // WAV Trigger version string
char commandbuffer[50];
int Size_of_Assembled_array; // The length of the assembled array, including empty spaces
int btcount;
long actualenginevolume; // The volume we are currently using
long pitch = -32767; // Current pitch of the engine sound effect
byte enginevolumelevel; // Incoming data
byte sfxvolumelevel;
byte vehiclespeed;
byte startsound;
byte startgyro;
byte stopsound;
byte stopgyro;
byte enginesound;
byte sfx1;
byte sfx2;
byte sfx3;
byte oldenginevolumelevel;
byte oldsfxvolumelevel;
byte oldvehiclespeed;
pinMode(led, OUTPUT);
Serial.begin(9600); // Debug serial
Serial2.begin(9600); // Serial comms to the BT module
//-------- Setup the Wav Trigger board -------------
wTrig.start(); // Setup the wav trigger
wTrig.stopAllTracks(); // Stop all the tracks
wTrig.samplerateOffset(0); // Set the sample rate to 0
wTrig.setReporting(true);
wTrig.masterGain(-70); // Reset the master volume gain off the WAV trigger (-70 to +4)
if (wTrig.getVersion(gWTrigVersion, VERSION_STRING_LEN)) {
Serial.print(gWTrigVersion);
Serial.print("\n");
gNumTracks = wTrig.getNumTracks();
Serial.print("Number of WAV tracks = ");
Serial.print(gNumTracks);
Serial.print("\n");
else {
Serial.print("WAV Trigger response not available");
//---------------- Set up the Bluetooth ----------------
Serial.println("Setting up Bluetooth");
Serial2.write("AT+NAMEBornSFX"); // Set up the bluetooth
Serial2.write("AT+PIN1234");
Serial2.write("AT+BAUD4");
Serial.println(F("Bluetooth configuration complete"));
wTrig.trackPlayPoly(64); // Play track 64
wTrig.samplerateOffset(-32767); // -32767 = one octave down. +32767 = Up one octave
wTrig.trackPlayPoly(90); // Play track 90
wTrig.trackLoop(90, 1); // Turn looping of the track on
delay(1500);
if (Serial2.available()) { // If there is BT data, go and get it
do {
commandbuffer[btcount++] = Serial2.read();
delay(30);
} while ((Serial2.available()) && (btcount < 50));
Size_of_Assembled_array = sizeof(commandbuffer);
Serial.print("Incoming data: ");Serial.println(commandbuffer);
if (btcount > 0) { // If something has arrived, then check it
Serial.println(" ");
btcount = 0;
if (commandbuffer[0] == 'X') { // Full data received (after leaving settings or at app boot)
enginevolumelevel = (((commandbuffer[1] - 48) * 100) + ((commandbuffer[2] - 48) * 10) + (commandbuffer[3] - 48));
Serial.print("Engine Volume: "); Serial.println(enginevolumelevel);
sfxvolumelevel = (((commandbuffer[4] - 48) * 100) + ((commandbuffer[5] - 48) * 10) + (commandbuffer[6] - 48));
Serial.print("SFX Volume: "); Serial.println(sfxvolumelevel);
vehiclespeed = (((commandbuffer[7] - 48) * 100) + ((commandbuffer[8] - 48) * 10) + (commandbuffer[9] - 48));
Serial.print("Vehicle speed: "); Serial.println(vehiclespeed);
startsound = (((commandbuffer[10] - 48) * 100) + ((commandbuffer[11] - 48) * 10) + (commandbuffer[12] - 48));
Serial.print("Start sound: "); Serial.println(startsound);
startgyro = (((commandbuffer[13] - 48) * 100) + ((commandbuffer[14] - 48) * 10) + (commandbuffer[15] - 48));
Serial.print("Start gyro: "); Serial.println(startgyro);
stopsound = (((commandbuffer[16] - 48) * 100) + ((commandbuffer[17] - 48) * 10) + (commandbuffer[18] - 48));
Serial.print("Stop sound: "); Serial.println(stopsound);
stopgyro = (((commandbuffer[19] - 48) * 100) + ((commandbuffer[20] - 48) * 10) + (commandbuffer[21] - 48));
Serial.print("Stop gyro: "); Serial.println(stopgyro);
enginesound = (((commandbuffer[22] - 48) * 100) + ((commandbuffer[23] - 48) * 10) + (commandbuffer[24] - 48));
Serial.print("Engine sound: "); Serial.println(enginesound);
sfx1 = (((commandbuffer[25] - 48) * 100) + ((commandbuffer[26] - 48) * 10) + (commandbuffer[27] - 48));
Serial.print("SFX 1: "); Serial.println(sfx1);
sfx2 = (((commandbuffer[28] - 48) * 100) + ((commandbuffer[29] - 48) * 10) + (commandbuffer[30] - 48));
Serial.print("SFX 2: "); Serial.println(sfx2);
sfx3 = (((commandbuffer[31] - 48) * 100) + ((commandbuffer[32] - 48) * 10) + (commandbuffer[33] - 48));
Serial.print("SFX 3: "); Serial.println(sfx3);
else if (commandbuffer[0] == 'Y') { // Partial data received
Serial.print("vehiclespeed: "); Serial.println(vehiclespeed);
else if (commandbuffer[0] == 'T') { // SFX 1
Serial.println("Play SFX 1");
wTrig.trackPlayPoly(110);
wTrig.update();
else if (commandbuffer[0] == 'U') { // SFX 2
Serial.println("Play SFX 2");
wTrig.trackPlayPoly(111);
wTrig.update();
else if (commandbuffer[0] == 'V') { // SFX 3
Serial.println("Play SFX 3");
wTrig.trackPlayPoly(112);
wTrig.update();
wTrig.update();
memset(commandbuffer, 0, sizeof(commandbuffer));
if (enginevolumelevel != oldenginevolumelevel) { // Adjust the engine volume on the fly
actualenginevolume = map(enginevolumelevel, 0, 100, -70, 10);
wTrig.masterGain(actualenginevolume);
wTrig.update();
oldenginevolumelevel = enginevolumelevel;
if (sfxvolumelevel != oldsfxvolumelevel) { // Adjust the SFX on the fly
// Change SFX volume here
oldsfxvolumelevel = sfxvolumelevel;
if (vehiclespeed != oldvehiclespeed) { // Adjust the engine sound on the fly // This may need fine tuning
pitch = map(vehiclespeed, 0, 100, -32767, 32767);
wTrig.samplerateOffset(pitch);
wTrig.update();
oldvehiclespeed = vehiclespeed;
