Results 1 to 1 of 1
Thread: ADS1299 with Teensy 4.1, DRDY stops flagging after some time
    Nov 2022
    1
    I am using the Teensy 4.1 Dev board, with an ADS1299 on a custom PCB.
    I am using this library: https://github.com/ferdinandkeil/ADS129X
    and am uploading this script onto the teensy with an arduino IDE: https://github.com/ferdinandkeil/ADS...erial_OBCI.ino
    The only difference I made is connecting the RESET pin to DVDD via a resistor.
    The problem is, that after some time, the DRDY pin stops going low (flagging there is data ready to be collected). I can't understand why this is.
    Specially, since I used an arduino uno with this example: https://github.com/conorrussomanno/A...9_example1.ino
    and it works perfectly! So it can't be from the circuit/PCB.
    I can't understand what the source of this issue might be :)
    EDIT1: I checked the DRDY pin without running any SPI and it works fine!
