Hi!
I have a lighting rig that I had built using Arduino Megas and APA102Cs, and just swapped them out for Teensy 3.5s instead - so far everything seems to be working ok, except some MIDI functionality I'm having trouble with. The gist of the setup is that I'm sending MIDI notes to the hardware to trigger various FastLED functions to animate the LED strips - on the Arduinos I had to use interrupts to ensure incoming MIDI notes wouldn't get dropped. In porting the code to Teensy, I'm finding that I can't use the same interrupt code (because of different hardware I assume?), and when I disable the interrupt portion of the code, all the notes still make in, but LEDs don't display simultaneously, and show up staggered instead. I'm guessing this is because the interrupt isn't working here and the LEDs are displaying after each MIDI note sequentially, rather than handling with each MIDI note as they're received in real time as they come in?
Do I need to be using interrupts here again? Unfortunately, I'm still relatively new to interrupts - I found the code I'm using and incorporated it into my setup without too much difficulty, but I still have very little understanding of what it's actually doing.
In my search, I did find this:
https://forum.pjrc.com/threads/42961...ased-interrupt
...but my problem doesn't seem buffer related. Also, they mention avoiding interrupts if possible - is there another way to deal with this then?
Here's a simplified version of the code I've been using for testing:
usbMIDI.read();
for (unsigned char i = 0; i < 128; i++) {
if (notes[i].state == true) {
runAnimation (notes[i].note, notes[i].velocity);
EVERY_N_MILLISECONDS( 20 ) { hue++; }
FastLED.show();
EVERY_N_MILLISECONDS(50) {
fadeToBlackBy(leds_S1, NUM_LEDS_S, globalFadeVal);
fadeToBlackBy(leds_S2, NUM_LEDS_S, globalFadeVal);
fadeToBlackBy(leds_S3, NUM_LEDS_S, globalFadeVal);
fadeToBlackBy(leds_Q1, NUM_LEDS_Q, globalFadeVal);
fadeToBlackBy(leds_Q2, NUM_LEDS_Q, globalFadeVal);
void runAnimation (byte n, byte v) {
switch (n) {
case 0: fill_rainbow( leds_S1, NUM_LEDS_S, hue, 7); break;
case 1: fill_rainbow( leds_S2, NUM_LEDS_S, hue, 7); break;
case 2: fill_rainbow( leds_S3, NUM_LEDS_S, hue, 7); break;
case 3: fill_rainbow( leds_Q1, NUM_LEDS_Q, hue, 7); break;
case 4: fill_rainbow( leds_Q2, NUM_LEDS_Q, hue, 7); break;
FWIW, here's the interrupt code I had going on the Mega:
cli();// stop interrupts
// set timer2 interrupt every 128us
TCCR2A = 0; // set entire TCCR2A register to 0
TCCR2B = 0; // same for TCCR2B
TCNT2 = 0; // initialize counter value to 0
// set compare match register for 7.8khz increments
OCR2A = 255; // = (16*10^6) / (7812.5*8) - 1 (must be <256)
// turn on CTC mode
TCCR2A |= (1 << WGM21);
// Set CS11 bit for 8 prescaler
TCCR2B |= (1 << CS11);
// enable timer compare interrupt
TIMSK2 |= (1 << OCIE2A);
sei(); // allow interrupts
