Results 1 to 9 of 9
Thread: Teensy's low pass frequency response
    Apr 2022
    7
    Hi guys!
    I'm building a guitar pedal with a Teensy 4.0 and an Audio Shield and I came to realize that, even without any processing block, it acts like a low pass. This introduces a lot of mud into the guitar sound and distorts low frequencies.
    This is the audio spectrum obtained in Audacity from a song I recorded using the Teensy without any processing block.
Name:	Screenshot 2022-11-30 140938.png
    Is there anything I can do to correct this? Is this normal?
    Sep 2021
    170
    Quote Originally Posted by Sequoia101 View Post
    Hi guys!
    Your song is probably not very similar to https://en.wikipedia.org/wiki/White_noise Only in this case you would see a more linear spectrum.
    Sep 2021
    170
    If you search the forum, you can find audio-shield spectrum plots.
    Apr 2022
    7
    Quote Originally Posted by Mcu32 View Post
    Well any song will produce a spectrum like this one. Whenever I play my 6th string (the lowest one), the sound heavily distorts.
    Sep 2021
    170
    ?? Any song you record is not white noise. Not sure what you're trying to say. A recorded song will *never* show a linear spectrum.
    Distortions may caused by too high input level?
    Sep 2021
    170
    Also, keep in mind that the shield is consumer quality. But it's quite ok.
    Apr 2022
    7
    Right, but it will rarely show this kind of low pass response. If I reduce the level of input the high frequencies become barely audible. I have no way to test it with white noise now but I will when I can.
    Sep 2021
    170
    Well, the shield is not as bad as your plot shows. There is something wrong. But you simply can't judge that from a song.
    Do you use the linear input? (not mic)
    The user blackadr made a quite good board. I've used it (well, a modification by myself)
    http://blackaddr.com/products/
    Sep 2021
    170
    Here's an article about self-noise : http://openaudio.blogspot.com/2017/0...elf-noise.html
