teensy_loader_cli with multiple Teensys connected
My system will have multiple Teensy 4.1 boards connected over USB at the same time, on a PC running Ubuntu. I need to deploy a (python) script to update the code running on all the Teensys.
What I have working (now) is a method to update one of them, when no other Teensy's are connected. I started with one, I haven't yet tried scenario where there are multiple.
The problem i see is that teensy_loader_cli doesn't support setting a target for connection. As I understand from researching this topic, teensy_loader_cli will scan the USB devices and update the first one it finds.
While researching this solution, I thought of the idea if I could send a command to the Teensy to reboot into the bootloader, and then run teensy_loader_cli, it would find the device that I just put into the bootloader. But I could not find a software method to put the Teensy into bootloader. I already have method to send the Teensy commands. What I did implement is to set SCB_AIRCR = 0x05FA0004; but this seems to cause a reset, and not jump to bootloader. I found the page on how to set Teensy 1.0 and 2.0 into bootloader, but not teensy 4.1. I am not sure if setting one of the attached Teensy's into bootloader would make it the target of teensy_loader_cli (while the other Teensy's would be running an application, and they all have a serial port opened to the PC).
Looking for general guidance, from which I could probably resolve the details.
Senior Member+
Not seeing that T_4.x has a jump to bootloader - least not found or used here.
Try this tool by @koromix: pjrc.com/threads/27825-Teensy-Qt
> for a normal T_4.x (not encrypted) it should work well.
Senior Member+
Correction call: _reboot_Teensyduino_();
That Teensy will enter bootloader and then active Teensy Loader will upload to that Teensy as it changes to RED LED lit.
Years ago, I had the same situation (programming multiple Teensies connected to PC with same code), so I modified a teensy_loader_cli to enumerate first all Teensies on PC, and then downloaded the code to each of them. You can differentiate the different Teensies by their Comport.
Originally Posted by
defragster
This worked for me. Thank you!
Senior Member+
- You may not post replies
- You may not edit your posts
Forum Rules
