I've noticed that you can write data to the file system very quickly, about 1.3miliseconds per 8 byte block, but then every time 4096 bytes gets written it stalls for 90miliseconds.
The same effect happens on the ESP8266 but a little slower.
Is there a way to avoid this stalling? Can the async features get round this?
import time
fout = open("data2.txt", "w")
d = [ ]
t0 = time.ticks_ms()
n = 3000
sumdt = 0
i0 = 0
for i in range(n):
t = time.ticks_ms()
fout.write("%08d" % t)
dt = t-t0
if dt > 20:
d.append(((i-i0)*8, dt))
i0 = i
else:
sumdt += dt
t0 = t
fout.close()
t = time.ticks_ms()
print("closetime", t-t0)
if i == n-1:
print("meanshortwrite", sumdt/(n-len(d)))
print("longwrite_ms", d)
result:
meanshortwrite 1.314295
longwrite_ms [(8, 47), (4096, 88), (4096, 89), (4096, 88), (4096, 88), (4096, 89)]
