* Audio Library for Teensy 3.X
* Copyright (c) 2014, Paul Stoffregen, paul@pjrc.com
* Development of this audio library was funded by PJRC.COM, LLC by sales of
* Teensy and Audio Adaptor boards. Please support PJRC's efforts to develop
* open source software by purchasing Teensy or other PJRC products.
* THE SOFTWARE.
ElectroTechnique 2020
Added WAVEFORM_SILENT, sync()
#ifndef synth_waveform_h_
#define synth_waveform_h_
#include <Arduino.h>
#include "AudioStream.h"
#include "arm_math.h"
// waveforms.c
extern "C" {
extern const int16_t AudioWaveformSine[257];
extern uint8_t LFO1mode;
extern uint8_t LFO2mode;
extern uint8_t LFO3mode;
extern boolean lfo1oneShoot;
extern boolean lfo2oneShoot;
extern boolean lfo3oneShoot;
extern uint8_t LFO1phase;
extern uint8_t LFO2phase;
extern uint8_t LFO3phase;
extern uint8_t lfo1ph;
extern uint8_t lfo2ph;
extern uint8_t lfo3ph;
extern int8_t Lfo3Modoutput;
extern boolean LFO1randomFlag;
extern boolean LFO2randomFlag;
extern boolean LFO3randomFlag;
extern uint32_t LFO1delayTime;
extern uint32_t LFO2delayTime;
extern uint32_t LFO3delayTime;
extern uint8_t SupersawSpreadA;
extern uint8_t SupersawSpreadB;
extern float Supersaw_gain1A;
extern float Supersaw_gain2A;
extern float Supersaw_gain1B;
extern float Supersaw_gain2B;
// Oscillator
#define WAVEFORM_SINE 0
#define WAVEFORM_TRIANGLE 1
#define WAVEFORM_SAWTOOTH 3
#define WAVEFORM_SQUARE 2
#define WAVEFORM_PULSE 4
#define WAVEFORM_SAWTOOTH_REVERSE 5
#define WAVEFORM_SAMPLE_HOLD 6
#define WAVEFORM_TRIANGLE_VARIABLE 7
#define WAVEFORM_BANDLIMIT_SAWTOOTH_REVERSE 8
#define WAVEFORM_BANDLIMIT_SAWTOOTH 9
#define WAVEFORM_BANDLIMIT_SQUARE 10
#define WAVEFORM_BANDLIMIT_PULSE 11
#define WAVEFORM_ARBITRARY 12
#define WAVEFORM_SUPERSAW 30
#define WAVEFORM_SILENT 19
// LFO1 (OSC)
#define WAVEFORM_ARBITRARY1 20
#define WAVEFORM_SAMPLE_HOLD1 21
// LFO2 (FILTER)
#define WAVEFORM_ARBITRARY2 22
#define WAVEFORM_SAMPLE_HOLD2 23
// LFO3 (AMP)
#define WAVEFORM_ARBITRARY3 24
#define WAVEFORM_SAMPLE_HOLD3 25
#define PWM_WAVEFORM_SINE 26
#define PWM_WAVEFORM_TRIANGLE 27
#define PWM_WAVEFORM_SAWTOOTH 28
#define PWM_WAVEFORM_SQUARE 29
typedef struct step_state
int offset ;
bool positive ;
} step_state ;
class BandLimitedWaveform
public:
BandLimitedWaveform (void) ;
int16_t generate_sawtooth (uint32_t new_phase, int i) ;
int16_t generate_square (uint32_t new_phase, int i) ;
int16_t generate_pulse (uint32_t new_phase, uint32_t pulse_width, int i) ;
void init_sawtooth (uint32_t freq_word) ;
void init_square (uint32_t freq_word) ;
void init_pulse (uint32_t freq_word, uint32_t pulse_width) ;
private:
int32_t lookup (int offset) ;
void insert_step (int offset, bool rising, int i) ;
int32_t process_step (int i) ;
int32_t process_active_steps (uint32_t new_phase) ;
int32_t process_active_steps_saw (uint32_t new_phase) ;
int32_t process_active_steps_pulse (uint32_t new_phase, uint32_t pulse_width) ;
void new_step_check_square (uint32_t new_phase, int i) ;
void new_step_check_pulse (uint32_t new_phase, uint32_t pulse_width, int i) ;
void new_step_check_saw (uint32_t new_phase, int i) ;
uint32_t phase_word ;
int32_t dc_offset ;
step_state states [32] ; // circular buffer of active steps
int newptr ; // buffer pointers into states, AND'd with PTRMASK to keep in buffer range.
int delptr ;
int32_t cyclic[16] ; // circular buffer of output samples
bool pulse_state ;
uint32_t sampled_width ; // pulse width is sampled once per waveform
class AudioSynthWaveformTS : public AudioStream
public:
AudioSynthWaveformTS(void) : AudioStream(0,NULL),
phase_accumulator(0), phase_increment(0), phase_offset(0),
magnitude(0), pulse_width(0x40000000),
arbdata(NULL), sample(0), tone_type(WAVEFORM_SINE),
tone_offset(0),syncFlag(0) {
void frequency(float freq) {
if (freq < 0.0) {
freq = 0.0;
} else if (freq > AUDIO_SAMPLE_RATE_EXACT / 2) {
freq = AUDIO_SAMPLE_RATE_EXACT / 2;
phase_increment = freq * (4294967296.0 / AUDIO_SAMPLE_RATE_EXACT);
if (phase_increment > 0x7FFE0000u) phase_increment = 0x7FFE0000;
void phase(float angle) {
if (angle < 0.0) {
angle = 0.0;
} else if (angle > 360.0) {
angle = angle - 360.0;
if (angle >= 360.0) return;
phase_offset = angle * (4294967296.0 / 360.0);
void sync() {
syncFlag = 1;
void amplitude(float n) { // 0 to 1.0
if (n < 0) {
n = 0;
} else if (n > 1.0) {
n = 1.0;
magnitude = n * 65536.0;
void offset(float n) {
if (n < -1.0) {
n = -1.0;
n = 1.0;
tone_offset = n * 32767.0;
void pulseWidth(float n) { // 0.0 to 1.0
if (n < 0) {
n = 0;
n = 1.0;
pulse_width = n * 4294967296.0;
void begin(short t_type) {
phase_offset = 0;
tone_type = t_type;
if (t_type == WAVEFORM_BANDLIMIT_SQUARE)
band_limit_waveform.init_square (phase_increment) ;
else if (t_type == WAVEFORM_BANDLIMIT_PULSE)
band_limit_waveform.init_pulse (phase_increment, pulse_width) ;
else if (t_type == WAVEFORM_BANDLIMIT_SAWTOOTH || t_type == WAVEFORM_BANDLIMIT_SAWTOOTH_REVERSE)
band_limit_waveform.init_sawtooth (phase_increment) ;
void begin(float t_amp, float t_freq, short t_type) {
amplitude(t_amp);
frequency(t_freq);
phase_offset = 0;
begin (t_type);
void arbitraryWaveform(const int16_t *data, float maxFreq) {
arbdata = data;
virtual void update(void);
private:
uint32_t phase_accumulator;
uint32_t phase_increment;
uint32_t phase_offset;
int32_t magnitude;
uint32_t pulse_width;
const int16_t *arbdata;
int16_t sample; // for WAVEFORM_SAMPLE_HOLD
int16_t sample2; // for WAVEFORM_SAMPLE_HOLD and oneShot
short tone_type;
int16_t tone_offset;
int16_t syncFlag;
BandLimitedWaveform band_limit_waveform;
class AudioSynthWaveformModulatedTS : public AudioStream
public:
AudioSynthWaveformModulatedTS(void) : AudioStream(2, inputQueueArray),
phase_accumulator(0), phase_increment(0), modulation_factor(32768),
magnitude(0), arbdata(NULL), sample(0), tone_offset(0),
tone_type(WAVEFORM_SINE), modulation_type(0), syncFlag(0) {
if (freq < 0.0) {
freq = 0.0;
if (n < 0) {
n = 0;
n = 1.0;
void sync() {
syncFlag = 1;
if (n < -1.0) {
n = -1.0;
n = 1.0;
tone_type = t_type;
band_limit_waveform.init_pulse (phase_increment, 0x80000000u) ;
amplitude(t_amp);
frequency(t_freq);
begin (t_type) ;
arbdata = data;
void frequencyModulation(float octaves) {
if (octaves > 12.0) {
octaves = 12.0;
} else if (octaves < 0.1) {
octaves = 0.1;
modulation_factor = octaves * 4096.0;
modulation_type = 0;
void phaseModulation(float degrees) {
if (degrees > 9000.0) {
degrees = 9000.0;
} else if (degrees < 30.0) {
degrees = 30.0;
modulation_factor = degrees * (65536.0 / 180.0);
modulation_type = 1;
private:
audio_block_t *inputQueueArray[2];
uint32_t modulation_factor;
int32_t magnitude;
uint32_t phasedata[AUDIO_BLOCK_SAMPLES];
uint8_t tone_type;
uint8_t modulation_type;
int16_t syncFlag;
uint32_t data_qs_phase[3];
*Audio Library for Teensy 3.X
* Copyright (c) 2018, Paul Stoffregen, paul@pjrc.com
* THE SOFTWARE.
Added WAVEFORM_SILENT, syncFlag
#include "synth_waveform.h"
#include "utility/dspinst.h"
// uncomment for more accurate but more computationally expensive frequency modulation
//#define IMPROVE_EXPONENTIAL_ACCURACY
#define BASE_AMPLITUDE 0x6000 // 0x7fff won't work due to Gibb's phenomenon, so use 3/4 of full range.
void AudioSynthWaveformTS::update(void)
audio_block_t *block;
int16_t *bp, *end;
int32_t val1, val2;
int16_t val3;
int16_t magnitude15;
uint32_t i, ph, index, index2, scale;
const uint32_t inc = phase_increment;
uint32_t phaseX;
if(syncFlag == 1) {
phase_accumulator = 0;
phaseX = 0;
syncFlag = 0;
LFO1randomFlag = false;
LFO2randomFlag = false;
ph = phase_accumulator + phase_offset;
phaseX = phase_accumulator;
if (magnitude == 0) {
phase_accumulator += inc * AUDIO_BLOCK_SAMPLES;
return;
block = allocate();
if (!block) {
return;
bp = block->data;
switch(tone_type) {
// PWM SINE
case PWM_WAVEFORM_SINE:
for (i=0; i < AUDIO_BLOCK_SAMPLES; i++) {
index = ph >> 24;
val1 = AudioWaveformSine[index];
val2 = AudioWaveformSine[index+1];
scale = (ph >> 8) & 0xFFFF;
val2 *= scale;
val1 *= 0x10000 - scale;
*bp++ = multiply_32x32_rshift32(val1 + val2, magnitude);
ph += inc;
case PWM_WAVEFORM_TRIANGLE:
uint32_t phtop = ph >> 30;
if (phtop == 1 || phtop == 2) {
*bp++ = ((0xFFFF - (ph >> 15)) * magnitude) >> 16;
*bp++ = (((int32_t)ph >> 15) * magnitude) >> 16;
ph += inc;
// PWM SAWTOOTH (LFO offset 0.0f)
case PWM_WAVEFORM_SAWTOOTH: // normal sawtooth and inv sawtooth
*bp++ = signed_multiply_32x16t(magnitude, ph >> 1);
ph += inc;
// PWM SQUARE (LFO offset 1.0)
case PWM_WAVEFORM_SQUARE:
magnitude15 = signed_saturate_rshift(magnitude, 16, 1);
//if (ph & 0x80000000) {
*bp++ = -magnitude15;
*bp++ = magnitude15;
ph += inc;
case WAVEFORM_ARBITRARY1:
if (!arbdata) {
release(block);
return;
// len = 256
index = ph >> 24;
index2 = index + 1;
if (LFO1mode == 0) {
if (index2 >= 256) index2 = 0; // loop
else {
if (index2 >= 256) index2 = 255; // one shot
val1 = *(arbdata + index);
val2 = *(arbdata + index2);
val2 *= scale;
uint32_t ph_old = ph;
uint32_t phaseX_old = phaseX;
if (LFO1phase == 0) { // Shape normal
ph += inc;
phaseX += inc;
else {
ph -= inc;
phaseX -= inc; // Shape inverse
if (lfo1oneShoot == true && phaseX < inc) {
ph = ph_old;
phaseX = phaseX_old;
case WAVEFORM_ARBITRARY2:
if (!arbdata) {
release(block);
return;
// len = 256
index = ph >> 24;
index2 = index + 1;
if (LFO2mode == 0) {
else {
if (index2 >= 255) index2 = 255; // one shot
val2 *= scale;
if (LFO2phase == 0) { // Shape normal
ph += inc;
phaseX += inc;
else {
ph -= inc;
if (lfo2oneShoot == true && phaseX < inc) {
ph = ph_old;
case WAVEFORM_ARBITRARY3:
if (!arbdata) {
release(block);
return;
// len = 256
index = ph >> 24;
index2 = index + 1;
if (LFO3mode == 0) {
else {
val2 *= scale;
//*bp++ = multiply_32x32_rshift32(val1 + val2, magnitude);
val3 = multiply_32x32_rshift32(val1 + val2, magnitude);
*bp++ = val3;
Lfo3Modoutput = val3 >> 8;
if (LFO3phase == 0) { // Shape normal
ph += inc;
phaseX += inc;
else {
ph -= inc;
if (lfo3oneShoot == true && phaseX < inc) {
ph = ph_old;
case WAVEFORM_SAMPLE_HOLD1:
uint32_t newph = ph + inc;
if (lfo1oneShoot == true && LFO1randomFlag == false) { // one shot
sample = random(magnitude) - (magnitude >> 1);
sample2 = sample;
LFO1randomFlag = true;
else if (newph < ph && lfo1oneShoot == false) {
else if (lfo1oneShoot == true && LFO1randomFlag == true) {
sample = sample2;
*bp++ = sample;
ph = newph;
case WAVEFORM_SAMPLE_HOLD2:
if (lfo2oneShoot == true && LFO2randomFlag == false) { // one shot
sample2 = sample;
LFO2randomFlag = true;
else if (newph < ph && lfo2oneShoot == false) {
else if (lfo2oneShoot == true && LFO2randomFlag == true) {
sample = sample2;
*bp++ = sample;
ph = newph;
case WAVEFORM_SAMPLE_HOLD3:
if (lfo3oneShoot == true && LFO3randomFlag == false) { // one shot
sample2 = sample;
LFO3randomFlag = true;
else if (newph < ph && lfo3oneShoot == false) {
else if (lfo3oneShoot == true && LFO3randomFlag == true) {
sample = sample2;
*bp++ = sample;
ph = newph;
phase_accumulator = ph - phase_offset;
if (tone_offset) {
bp = block->data;
end = bp + AUDIO_BLOCK_SAMPLES;
do {
val1 = *bp;
*bp++ = signed_saturate_rshift(val1 + tone_offset, 16, 0);
} while (bp < end);
transmit(block, 0);
release(block);
void AudioSynthWaveformModulatedTS::update(void)
audio_block_t *block, *moddata, *shapedata;
int16_t *bp, *end;
int32_t val1, val2;
uint32_t i, ph, index, index2, scale, priorphase;
uint32_t phase_spread;
uint32_t saw_phase_increment;
uint32_t increments[3];
uint32_t ph_1;
uint32_t ph_2;
uint32_t ph_3;
uint32_t ph_4;
int16_t Ssaw_value;
moddata = receiveReadOnly(0);
shapedata = receiveReadOnly(1);
if(syncFlag==1){
syncFlag = 0;
// Pre-compute the phase angle for every output sample of this update
ph = phase_accumulator;
priorphase = phasedata[AUDIO_BLOCK_SAMPLES-1];
if (moddata && modulation_type == 0) {
// Frequency Modulation
bp = moddata->data;
int32_t n = (*bp++) * modulation_factor; // n is # of octaves to mod
int32_t ipart = n >> 27; // 4 integer bits
n &= 0x7FFFFFF; // 27 fractional bits
#ifdef IMPROVE_EXPONENTIAL_ACCURACY
// exp2 polynomial suggested by Stefan Stenzel on "music-dsp"
// mail list, Wed, 3 Sep 2014 10:08:55 +0200
int32_t x = n << 3;
n = multiply_accumulate_32x32_rshift32_rounded(536870912, x, 1494202713);
int32_t sq = multiply_32x32_rshift32_rounded(x, x);
n = multiply_accumulate_32x32_rshift32_rounded(n, sq, 1934101615);
n = n + (multiply_32x32_rshift32_rounded(sq,
multiply_32x32_rshift32_rounded(x, 1358044250)) << 1);
n = n << 1;
#else
// exp2 algorithm by Laurent de Soras
// https://www.musicdsp.org/en/latest/Other/106-fast-exp2-approximation.html
n = (n + 134217728) << 3;
n = multiply_32x32_rshift32_rounded(n, n);
n = multiply_32x32_rshift32_rounded(n, 715827883) << 3;
n = n + 715827882;
uint32_t scale = n >> (14 - ipart);
uint64_t phstep = (uint64_t)inc * scale;
uint32_t phstep_msw = phstep >> 32;
if (phstep_msw < 0x7FFE) {
ph += phstep >> 16;
ph += 0x7FFE0000;
phasedata[i] = ph;
release(moddata);
} else if (moddata) {
// Phase Modulation
bp = moddata->data;
// more than +/- 180 deg shift by 32 bit overflow of "n"
uint32_t n = (uint16_t)(*bp++) * modulation_factor;
phasedata[i] = ph + n;
ph += inc;
release(moddata);
// No Modulation Input
phasedata[i] = ph;
ph += inc;
phase_accumulator = ph;
//Amplitude is always 1 on TSynth when oscillator is sounding
//magnitude must be set to zero, otherwise digital noise comes through
if(tone_type == WAVEFORM_SILENT){
magnitude = 0;
}else{
magnitude = 65536.0;
// If the amplitude is zero, no output, but phase still increments properly
if (shapedata) release(shapedata);
return;
block = allocate();
if (!block) {
return;
bp = block->data;
// Now generate the output samples using the pre-computed phase angles
switch(tone_type) {
case WAVEFORM_SINE:
ph = phasedata[i];
index = ph >> 24;
val2 *= scale;
case WAVEFORM_ARBITRARY:
if (!arbdata) {
release(block);
return;
// len = 256
ph = phasedata[i];
index = ph >> 24;
index2 = index + 1;
val2 *= scale;
case WAVEFORM_PULSE:
if (shapedata) {
uint32_t width = ((shapedata->data[i] + 0x8000) & 0xFFFF) << 16;
if (phasedata[i] < width) {
} // else fall through to orginary square without shape modulation
case WAVEFORM_SQUARE:
if (phasedata[i] & 0x80000000) {
case WAVEFORM_BANDLIMIT_PULSE:
if (shapedata)
int32_t val = band_limit_waveform.generate_pulse (phasedata[i], width, i) ;
*bp++ = (int16_t) ((val * magnitude) >> 16) ;
case WAVEFORM_BANDLIMIT_SQUARE:
for (i = 0 ; i < AUDIO_BLOCK_SAMPLES ; i++)
int32_t val = band_limit_waveform.generate_square (phasedata[i], i) ;
*bp++ = (int16_t) ((val * magnitude) >> 16);
// Quadsaw
case WAVEFORM_SAWTOOTH:
phase_spread = (phase_increment >> 14) * SupersawSpreadA;
++phase_spread;
saw_phase_increment = (phase_increment & 0x0000FFFF);
for (uint8_t i = 0; i < 3; ++i) {
saw_phase_increment += phase_spread;
increments[i] = saw_phase_increment;
data_qs_phase[0] += increments[0];
data_qs_phase[1] += increments[1];
data_qs_phase[2] += increments[2];
ph_1 = phasedata[i];
ph_2 = (ph_1 + data_qs_phase[0]);
ph_3 = (ph_2 + data_qs_phase[1]);
ph_4 = (ph_3 + data_qs_phase[2]);
Ssaw_value = signed_multiply_32x16t(magnitude * Supersaw_gain1A, ph_1);
Ssaw_value += signed_multiply_32x16t(magnitude * Supersaw_gain2A, ph_2);
Ssaw_value += signed_multiply_32x16t(magnitude * Supersaw_gain2A, ph_3);
Ssaw_value += signed_multiply_32x16t(magnitude * Supersaw_gain2A, ph_4);
*bp++ = Ssaw_value;
case WAVEFORM_SAWTOOTH_REVERSE:
*bp++ = signed_multiply_32x16t(0xFFFFFFFFu - magnitude, phasedata[i]);
case WAVEFORM_BANDLIMIT_SAWTOOTH:
case WAVEFORM_BANDLIMIT_SAWTOOTH_REVERSE:
int16_t val = band_limit_waveform.generate_sawtooth (phasedata[i], i) ;
val = (int16_t) ((val * magnitude) >> 16) ;
*bp++ = tone_type == WAVEFORM_BANDLIMIT_SAWTOOTH_REVERSE ? (int16_t) -val : (int16_t) +val ;
case WAVEFORM_TRIANGLE_VARIABLE:
if (shapedata) {
uint32_t width = (shapedata->data[i] + 0x8000) & 0xFFFF;
uint32_t rise = 0xFFFFFFFF / width;
uint32_t fall = 0xFFFFFFFF / (0xFFFF - width);
uint32_t halfwidth = width << 15;
uint32_t n;
ph = phasedata[i];
if (ph < halfwidth) {
n = (ph >> 16) * rise;
*bp++ = ((n >> 16) * magnitude) >> 16;
} else if (ph < 0xFFFFFFFF - halfwidth) {
n = 0x7FFFFFFF - (((ph - halfwidth) >> 16) * fall);
*bp++ = (((int32_t)n >> 16) * magnitude) >> 16;
n = ((ph + halfwidth) >> 16) * rise + 0x80000000;
ph += inc;
} // else fall through to orginary triangle without shape modulation
case WAVEFORM_TRIANGLE:
ph = phasedata[i];
case WAVEFORM_SAMPLE_HOLD:
ph = phasedata[i];
if (ph < priorphase) { // does not work for phase modulation
priorphase = ph;
*bp++ = sample;
if (tone_offset) {
bp = block->data;
do {
val1 = *bp;
} while (bp < end);
transmit(block, 0);
release(block);
// BandLimitedWaveform
#define SUPPORT_SHIFT 4
#define SUPPORT (1 << SUPPORT_SHIFT)
#define PTRMASK ((2 << SUPPORT_SHIFT) - 1)
#define SCALE 16
#define SCALE_MASK (SCALE-1)
#define N (SCALE * SUPPORT * 2)
#define GUARD_BITS 8
#define GUARD (1 << GUARD_BITS)
#define HALF_GUARD (1 << (GUARD_BITS-1))
#define DEG180 0x80000000u
#define PHASE_SCALE (0x100000000L / (2 * BASE_AMPLITUDE))
extern "C"
extern const int16_t step_table [258] ;
int32_t BandLimitedWaveform::lookup (int offset)
int off = offset >> GUARD_BITS ;
int frac = offset & (GUARD-1) ;
int32_t a, b ;
if (off < N/2) // handle odd symmetry by reflecting table
a = step_table [off+1] ;
b = step_table [off+2] ;
a = - step_table [N-off] ;
b = - step_table [N-off-1] ;
return BASE_AMPLITUDE + ((frac * b + (GUARD - frac) * a + HALF_GUARD) >> GUARD_BITS) ; // interpolated
// create a new step, apply its past waveform into the cyclic sample buffer
// and add a step_state object into active list so it can be added for the future samples
void BandLimitedWaveform::insert_step (int offset, bool rising, int i)
while (offset <= (N/2-SCALE)<<GUARD_BITS)
if (offset >= 0)
cyclic [i & 15] += rising ? lookup (offset) : -lookup (offset) ;
offset += SCALE<<GUARD_BITS ;
i ++ ;
states[newptr].offset = offset ;
states[newptr].positive = rising ;
newptr = (newptr+1) & PTRMASK ;
// generate value for current sample from one active step, checking for the
// dc_offset adjustment at the end of the table.
int32_t BandLimitedWaveform::process_step (int i)
int off = states[i].offset ;
bool positive = states[i].positive ;
int32_t entry = lookup (off) ;
off += SCALE<<GUARD_BITS ;
states[i].offset = off ; // update offset in table for next sample
if (off >= N<<GUARD_BITS) // at end of step table we alter dc_offset to extend the step into future
dc_offset += positive ? 2*BASE_AMPLITUDE : -2*BASE_AMPLITUDE ;
return positive ? entry : -entry ;
// process all active steps for current sample, basically generating the waveform portion
// due only to steps
// square waves use this directly.
int32_t BandLimitedWaveform::process_active_steps (uint32_t new_phase)
int32_t sample = dc_offset ;
int step_count = (newptr - delptr) & PTRMASK ;
if (step_count > 0) // for any steps in-flight we sum in table entry and update its state
int i = newptr ;
do
i = (i-1) & PTRMASK ;
sample += process_step (i) ;
} while (i != delptr) ;
if (states[delptr].offset >= N<<GUARD_BITS) // remove any finished entries from the buffer.
delptr = (delptr+1) & PTRMASK ;
// can be upto two steps per sample now for pulses
if (newptr != delptr && states[delptr].offset >= N<<GUARD_BITS)
return sample ;
// for sawtooth need to add in the slope and compensate for all the steps being one way
int32_t BandLimitedWaveform::process_active_steps_saw (uint32_t new_phase)
int32_t sample = process_active_steps (new_phase) ;
sample += (int16_t) ((((uint64_t)phase_word * (2*BASE_AMPLITUDE)) >> 32) - BASE_AMPLITUDE) ; // generate the sloped part of the wave
if (new_phase < DEG180 && phase_word >= DEG180) // detect wrap around, correct dc offset
dc_offset += 2*BASE_AMPLITUDE ;
return sample ;
// for pulse need to adjust the baseline according to the pulse width to cancel the DC component.
int32_t BandLimitedWaveform::process_active_steps_pulse (uint32_t new_phase, uint32_t pulse_width)
return sample + BASE_AMPLITUDE/2 - pulse_width / (0x80000000u / BASE_AMPLITUDE) ; // correct DC offset for duty cycle
// Check for new steps using the phase update for the current sample for a square wave
void BandLimitedWaveform::new_step_check_square (uint32_t new_phase, int i)
if (new_phase >= DEG180 && phase_word < DEG180) // detect falling step
int32_t offset = (int32_t) ((uint64_t) (SCALE<<GUARD_BITS) * (sampled_width - phase_word) / (new_phase - phase_word)) ;
if (offset == SCALE<<GUARD_BITS)
offset -- ;
if (pulse_state) // guard against two falling steps in a row (if pulse width changing for instance)
insert_step (- offset, false, i) ;
pulse_state = false ;
else if (new_phase < DEG180 && phase_word >= DEG180) // detect wrap around, rising step
int32_t offset = (int32_t) ((uint64_t) (SCALE<<GUARD_BITS) * (- phase_word) / (new_phase - phase_word)) ;
offset -- ;
if (!pulse_state) // guard against two rising steps in a row (if pulse width changing for instance)
insert_step (- offset, true, i) ;
pulse_state = true ;
// Checking for new steps for pulse waveform has to deal with changing frequency and pulse width and
// not letting a pulse glitch out of existence as these change across a single period of the waveform
// now we detect the rising edge just like for a square wave and use that to sample the pulse width
// parameter, which then has to be checked against the instantaneous frequency every sample.
void BandLimitedWaveform::new_step_check_pulse (uint32_t new_phase, uint32_t pulse_width, int i)
if (pulse_state && phase_word < sampled_width && (new_phase >= sampled_width || new_phase < phase_word)) // falling edge
offset -- ;
if ((!pulse_state) && phase_word >= DEG180 && new_phase < DEG180) // detect wrap around, rising step
// sample the pulse width value so its not changing under our feet later in cycle due to modulation
sampled_width = pulse_width ;
offset -- ;
if (pulse_state && new_phase >= sampled_width) // detect falling step directly after a rising edge
//if (new_phase - sampled_width < DEG180) // detect falling step directly after a rising edge
offset -- ;
// new steps for sawtooth are at 180 degree point, always falling.
void BandLimitedWaveform::new_step_check_saw (uint32_t new_phase, int i)
int32_t offset = (int32_t) ((uint64_t) (SCALE<<GUARD_BITS) * (DEG180 - phase_word) / (new_phase - phase_word)) ;
offset -- ;
// the generation function pushd new sample into cyclic buffer, having taken out the oldest entry
// to return. The output is thus 16 samples behind, which allows the non-casual step function to
// work in real time.
int16_t BandLimitedWaveform::generate_sawtooth (uint32_t new_phase, int i)
new_step_check_saw (new_phase, i) ;
int32_t val = process_active_steps_saw (new_phase) ;
int16_t sample = (int16_t) cyclic [i&15] ;
cyclic [i&15] = val ;
phase_word = new_phase ;
return sample ;
int16_t BandLimitedWaveform::generate_square (uint32_t new_phase, int i)
new_step_check_square (new_phase, i) ;
int32_t val = process_active_steps (new_phase) ;
return sample ;
int16_t BandLimitedWaveform::generate_pulse (uint32_t new_phase, uint32_t pulse_width, int i)
new_step_check_pulse (new_phase, pulse_width, i) ;
int32_t val = process_active_steps_pulse (new_phase, pulse_width) ;
int32_t sample = cyclic [i&15] ;
return (int16_t) ((sample >> 1) - (sample >> 5)) ; // scale down to avoid overflow on narrow pulses, where the DC shift is big
void BandLimitedWaveform::init_sawtooth (uint32_t freq_word)
phase_word = 0 ;
newptr = 0 ;
delptr = 0 ;
for (int i = 0 ; i < 2*SUPPORT ; i++)
phase_word -= freq_word ;
dc_offset = phase_word < DEG180 ? BASE_AMPLITUDE : -BASE_AMPLITUDE ;
uint32_t new_phase = phase_word + freq_word ;
cyclic [i & 15] = (int16_t) process_active_steps_saw (new_phase) ;
void BandLimitedWaveform::init_square (uint32_t freq_word)
init_pulse (freq_word, DEG180) ;
void BandLimitedWaveform::init_pulse (uint32_t freq_word, uint32_t pulse_width)
phase_word = 0 ;
newptr = 0 ;
delptr = 0 ;
if (phase_word < pulse_width)
dc_offset = BASE_AMPLITUDE ;
dc_offset = -BASE_AMPLITUDE ;
cyclic [i & 15] = (int16_t) process_active_steps_pulse (new_phase, pulse_width) ;
BandLimitedWaveform::BandLimitedWaveform()
newptr = 0 ;
delptr = 0 ;
phase_word = 0 ;
