Results 1 to 6 of 6
Thread: 3.6 ask to report bug
    Dec 2022
    4
    i can't ad more variable despite using 60% of the RAM, it compile but the prg is stuck at the beginning of the loop()
    i use 1.8.19 arduino IDE
    So i set show verbose et compile "fastest pure code" then it didn't compile and had theses error messages :
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ Quantizer.cpp:79:1: error: insn does not satisfy its constraints:
    (insn 23 22 152 2 (set (reg:SF 31 s15 [121])
    (const_double:SF 4.41e+4 [0x0.ac44p+16])) C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ Quantizer.cpp:38 621 {*thumb2_movsf_vfp}
    (expr_list:REG_EQUIV (const_double:SF 4.41e+4 [0x0.ac44p+16])
    (nil)))
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ Quantizer.cpp:79:1: internal compiler error: in extract_constrain_insn, at recog.c:2246
    Please submit a full bug report,
    with preprocessed source if appropriate.
    See <http://gcc.gnu.org/bugs.html> for instructions.
    "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O3 -mpure-code -D__PURE_CODE__ -g -Wall -ffunction-sections -fdata-sections -nostdlib -mno-unaligned-access -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -D__MK66FX1M0__ -DTEENSYDUINO=157 -DARDUINO=10819 -DARDUINO_TEENSY36 -DF_CPU=180000000 -DUSB_MIDI_AUDIO_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\DELLLA~1\\AppData\\Local\\Temp\\arduin o_build_674652/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teen sy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SD\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SdFat\\src" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\ Audio\\analyze_print.cpp" -o "C:\\Users\\DELLLA~1\\AppData\\Local\\Temp\\arduin o_build_674652\\libraries\\Audio\\analyze_print.cp p.o"
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ Resampler.cpp: In member function 'void Resampler::configure(float, float)':
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ Resampler.cpp:228:1: error: insn does not satisfy its constraints:
    (insn 1077 618 615 34 (set (reg:SI 31 s15 [orig:211 D.16613 ] [211])
    (mem/c:SI (plus:SI (reg/f:SI 13 sp)
    (const_int 56 [0x38])) [11 %sfp+-8 S4 A32])) C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ Resampler.cpp:123 615 {*thumb2_movsi_vfp}
    (nil))
    C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ Resampler.cpp:228:1: internal compiler error: in extract_constrain_insn, at recog.c:2246
    Used: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD
    Not used: C:\Program Files (x86)\Arduino\libraries\SD
    Using library Audio at version 1.3 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio
    Using library SPI at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI
    Using library SD at version 2.0.0 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD
    Using library SdFat at version 2.1.2 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat
    Using library SerialFlash at version 0.5 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Serial Flash
    Using library Wire at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire
    Error compiling for board Teensy 3.6.
    my "code"
    #include <Arduino.h>
    int seti = 2;
    int setj = 1;
    int the8 = 0;
    int cntArpBass = 0;
    int countBass = 0;
    int trigBass =0;
    int tuneB = 0;
    int filtB = 0;
    int msb = 0;
    int lsb = 0;
    bool isPlay = true;
    int tap = 0;
    int setk = 0;
    int exfader8 = 0;
    int flagRec = 3;
    long freqLive;
    int timeSeq =777;
    int freqClock1 = 777;
    int time1T;
    float frqBpm4;
    String songName = "song-one.mdx";
    int songNum = 0;
    const int chipSelect = BUILTIN_SDCARD;
    long timeKick;
    short armRec = 0;
    int flagKick = 0;
    int exBeatfader =0;
    int faderBeat =0;
    int armDrum[12];
    int chr[]={4,7,9,14  };
    int chrb[]={2,4,7,9,14,17 };
    int chord[2][6] ={ {0,5,9,17,22, 27} , {0,7,12,16,21,26} };
    //float arrDist[9] ={-1 ,-0.89,-0.78,-0.54,0,0.49,0.77,0.89,1};
    float arrDist[9] ={-1 ,-0.99,-0.98,-0.94,0,0.94,0.98,0.99,1};
    int theSet []={127,49,81,127,127,119,18,9,49,21,127,48,7,62,36,30,127,90,0,2,107,104,121,10,58,0,47,27,94,87,60,97,67,59,7,90,64,1,49,16,29,28,27,26,25,24,23,22,30,29,28,27,26,25,24,23,31,30,29,28,27,26,25,24,110,84,14,60,74,78,127,72,9,17,11,80,21,5,72,16,47,126,29,61,51,10,20,19,122,127,0,2,82,127,9,81,28,16,26,25,24,23,22,89,29,28,27,26,25,24,23,22,30,29,28,27,26,25,24,23,31,30,29,28,27,26,25,24,18,78,75,50,122,123,18,17,25,30,21,30,21,20,19,18,26,25,24,23,22,21,20,19,111,26,18,24,23,22,21,20,28,27,26,25,24,23,22,21,29,28,27,26,25,24,23,22,30,29,28,27,26,25,24,23,31,30,29,28,27,26,25,24,21,23,22,26,5,19,18,17,30,24,23,41,21,20,19,18,26,25,24,23,22,21,20,19,27,26,100,111,23,22,21,20,28,27,26,25,24,23,22,21,29,28,27,26,25,24,23,22,30,29,28,27,26,25,24,23,31,30,29,28,27,26,25,24,24,23,22,21,127,19,18,17,25,24,23,22,21,20,19,18,26,25,24,23,22,21,20,19,27,26,25,24,23,22,21,20,28,27,26,25,24,23,22,21,29,28,27,26,25,24,23,22,30,29,28,27,26,25,24,23,31,30,29,28,27,26,25,24,24,23,118,21,20,95,18,17,25,24,23,22,21,20,19,18,26,25,24,23,22,21,20,19,27,26,25,24,23,22,21,20,28,27,26,25,24,23,22,21,29,28,27,26,25,24,23,22,30,29,28,27,26,25,24,23,31,30,29,28,27,26,25,24,24,23,22,21,20,19,18,17,25,24,23,22,21,20,127,18,26,25,24,23,22,21,20,19,27,26,25,24,23,22,32,20,5,18,26,25,24,23,22,21,29,28,27,26,25,24,23,22,30,29,28,27,26,25,24,23,31,30,29,28,27,26,25,24,24,23,22,21,20,19,18,17,25,24,23,22,21,20,19,19,26,25,24,23,22,21,20,19,27,26,25,24,23,22,21,127,94,27,26,25,24,111,22,80,29,28,27,26,25,24,23,22,30,29,28,27,26,25,24,23,31,30,29,28,27,26,25,24};
    int delta8 = 0;
    int dirU = 1;
    long cntSnare = 0;
    long cntClap = 0;
    bool onSnare = false;
    bool onClap = false;
    int  startCC;
    int  startDir;
    float startVelo = 127;
    int exDeltaG = 0;
    float veloGuit = 0.30;
    int deltaTG = 0;
     int   uOn = 0;
     int startUltra = 0;
     byte lastCC = 0;
    int okChord[12];
    int r[6] = {2,1 ,   0,   0,  44 , 90};
    int g[6] = {0, 0,  30, 60, 80 , 80 };
    int b[6] = {8, 127,30,   0,   0 , 80};
    const float tune[128] =
        8.1758,    8.6620,    9.1770,    9.7227,    10.3009,    10.9134,    11.5623,    12.2499,
        12.9783,   13.7500,   14.5676,   15.4339,   16.3516,    17.3239,    18.3540,    19.4454,
        20.6017,   21.8268,   23.1247,   24.4997,   25.9565,    27.5000,    29.1352,    30.8677,
        32.7032,   34.6478,   36.7081,   38.8909,   41.2034,    43.6535,    46.2493,    48.9994,
        51.9131,   55.0000,   58.2705,   61.7354,   65.4064,    69.2957,    73.4162,    77.7817,
        82.4069,   87.3071,   92.4986,   97.9989,   103.8262,   110.0000,   116.5409,   123.4708,
        130.8128,  138.5913,  146.8324,  155.5635,  164.8138,   174.6141,   184.9972,   195.9977,
        207.6523,  220.0000,  233.0819,  246.9417,  261.6256,   277.1826,   293.6648,   311.1270,
        329.6276,  349.2282,  369.9944,  391.9954,  415.3047,   440.0000,   466.1638,   493.8833,
        523.2511,  554.3653,  587.3295,  622.2540,  659.2551,   698.4565,   739.9888,   783.9909,
        830.6094,  880.0000,  932.3275,  987.7666,  1046.5023,  1108.7305,  1174.6591,  1244.5079,
        1318.5102, 1396.9129, 1479.9777, 1567.9817, 1661.2188,  1760.0000,  1864.6550,  1975.5332,
        2093.0045, 2217.4610, 2349.3181, 2489.0159, 2637.0205,  2793.8259,  2959.9554,  3135.9635,
        3322.4376, 3520.0000, 3729.3101, 3951.0664, 4186.0090,  4434.9221,  4698.6363,  4978.0317,
        5274.0409, 5587.6517, 5919.9108, 6271.9270, 6644.8752,  7040.0000,  7458.6202,  7902.1328,
        8372.0181, 8869.8442, 9397.2726, 9956.0635, 10548.0818, 11175.3034, 11839.8215, 12543.8540
    AudioOutputAnalog        dac1;
    AudioSynthNoiseWhite     noise1;         //xy=55,125.54546356201172
    AudioSynthSimpleDrum     drum3;          //xy=55.72727966308594,165.99997329711914
    AudioSynthNoisePink      pink1;          //xy=55.88888931274414,214.8888988494873
    AudioSynthWaveformSine   lfo3; //xy=55,737.5511474609375
    AudioSynthWaveformSine   lfo4; //xy=55,777.5511474609375
    AudioSynthWaveformSine   sine1;          //xy=58,271.99999809265137
    AudioSynthWaveformSine   lfo1;          //xy=57,662
    AudioSynthWaveformSine   lfo2; //xy=59.00569152832031,699.5511474609375
    AudioSynthWaveformSineModulated sine_fm3; //xy=62,461.0000476837158
    AudioSynthWaveform       waveform2;      //xy=64,315.66666412353516
    AudioSynthWaveform       waveform1;      //xy=64,1037.181884765625
    AudioEffectEnvelope      ev2; //xy=65.00567626953125,886.4601821899414
    AudioSynthWaveformSineModulated sine_fm2;       //xy=67,561
    AudioEffectEnvelope      ev1;      //xy=66,847
    AudioEffectEnvelope      ev4; //xy=67.00569152832031,963.4601440429688
    AudioSynthSimpleDrum     drum2;          //xy=74.54545593261719,77.27274513244629
    AudioSynthSimpleDrum     drum1;          //xy=75.45454406738281,27.272724151611328
    AudioEffectEnvelope      ev3; //xy=75.00566864013672,920.4601707458496
    AudioSynthNoiseWhite     noise2;         //xy=94,420.9999952316284
    AudioSynthWaveformModulated waveformMod1;   //xy=195.54547119140625,227.6364231109619
    AudioEffectEnvelope      envelope2;      //xy=207.0000343322754,98.99999141693115
    AudioAnalyzePeak         peak4; //xy=209,736.5511474609375
    AudioAnalyzePeak         peak5; //xy=209,776.5511474609375
    AudioAnalyzePeak         peak2;          //xy=211,661
    AudioAnalyzePeak         peak3; //xy=213.0056915283203,698.5511474609375
    AudioSynthWaveformModulated waveformMod2; //xy=214,510
    AudioAnalyzePeak         peak7; //xy=213.00568389892578,885.4601821899414
    AudioAnalyzePeak         peak6;  //xy=214,847
    AudioSynthWaveformSineModulated sine_fm1;       //xy=228,563
    AudioAnalyzePeak         peak9; //xy=231.0057144165039,964.4601573944092
    AudioAnalyzePeak         peak8; //xy=233.00567626953125,923.4601821899414
    AudioSynthKarplusStrong  string2;  //xy=269.00000381469727,323.9999942779541
    AudioSynthKarplusStrong  string1;        //xy=271.0000114440918,293.00001430511475
    AudioSynthKarplusStrong  string6; //xy=270.88888931274414,463.88890838623047
    AudioSynthKarplusStrong  string3; //xy=272.00000762939453,354.99999046325684
    AudioSynthKarplusStrong  string4; //xy=272.00000381469727,390.0000114440918
    AudioSynthKarplusStrong  string5; //xy=271.8888816833496,425.8888931274414
    AudioEffectEnvelope      envelope6; //xy=352.88890838623047,213.88889122009277
    AudioMixer4              mixer1;         //xy=370.4545593261719,35
    AudioEffectEnvelope      envelope1;      //xy=371.54542541503906,112.54545783996582
    AudioEffectEnvelope      envelope4; //xy=393,507
    AudioEffectGranular      granular1;      //xy=395.73292541503906,560.9146976470947
    AudioMixer4              mixer4; //xy=419.00012969970703,305
    AudioMixer4              mixer7; //xy=427.8889274597168,405.88887786865234
    AudioEffectEnvelope      envelope3;      //xy=482.09095764160156,168.54548835754395
    AudioMixer4              mixer5; //xy=522,47
    AudioAnalyzePeak         peak1;          //xy=525.4545593261719,1029.727294921875
    AudioEffectReverb        reverb1;        //xy=535.9999542236328,675.0001268386841
    AudioMixer4              mixer8; //xy=539.8888397216797,334.88891220092773
    AudioEffectEnvelope      envelope5; //xy=559.9999313354492,572.0000057220459
    AudioAmplifier           amp2;           //xy=579.6417121887207,408.9148235321045
    AudioEffectBitcrusher    bitcrusher1;    //xy=584.7329406738281,501.00567054748535
    AudioFilterStateVariable filterBass;        //xy=597.2727165222168,234.99999046325684
    AudioAmplifier           amp1;           //xy=616.9090309143066,125.90907859802246
    AudioFilterLadder        ladder1;        //xy=670.8889007568359,38.88888931274414
    AudioEffectWaveshaper    waveshape1;     //xy=720.0055770874023,345.9147701263428
    AudioMixer4              mixerdist;         //xy=822.6420288085938,259.9147834777832
    AudioMixer4              mixer3;         //xy=857.9999923706055,35
    AudioFilterStateVariable filter3; //xy=886.8237762451172,511.7329330444336
    AudioFilterStateVariable filter2;        //xy=983.7330074310303,221.9147491455078
    AudioMixer4              mixer2;         //xy=988.0909729003906,124.81816482543945
    AudioMixer4              mixer6; //xy=1163.0000495910645,107
    AudioFilterStateVariable filter40; //xy=1300.4447059631348,106.88888168334961
    AudioOutputUSB           usb1;           //xy=1561.2729187011719,98.45458030700684
    AudioConnection          patchCord1(noise1, envelope2);
    AudioConnection          patchCord2(drum3, 0, mixer1, 3);
    AudioConnection          patchCord3(pink1, envelope1);
    AudioConnection          patchCord4(lfo3, peak4);
    AudioConnection          patchCord5(lfo4, peak5);
    AudioConnection          patchCord6(sine1, 0, waveformMod1, 0);
    AudioConnection          patchCord7(lfo1, peak2);
    AudioConnection          patchCord8(lfo2, peak3);
    AudioConnection          patchCord9(sine_fm3, 0, waveformMod2, 0);
    AudioConnection          patchCord10(waveform1, peak1);
    AudioConnection          patchCord11(ev2, peak7);
    AudioConnection          patchCord12(sine_fm2, sine_fm1);
    AudioConnection          patchCord13(ev1, peak6);
    AudioConnection          patchCord14(ev4, peak9);
    AudioConnection          patchCord15(drum2, 0, mixer1, 1);
    AudioConnection          patchCord16(drum1, 0, mixer1, 0);
    AudioConnection          patchCord17(ev3, peak8);
    AudioConnection          patchCord18(waveformMod1, envelope6);
    AudioConnection          patchCord19(envelope2, 0, mixer1, 2);
    AudioConnection          patchCord20(waveformMod2, envelope4);
    AudioConnection          patchCord21(sine_fm1, granular1);
    AudioConnection          patchCord22(string2, 0, mixer4, 1);
    AudioConnection          patchCord23(string1, 0, mixer4, 0);
    AudioConnection          patchCord24(string6, 0, mixer7, 1);
    AudioConnection          patchCord25(string3, 0, mixer4, 2);
    AudioConnection          patchCord26(string4, 0, mixer4, 3);
    AudioConnection          patchCord27(string5, 0, mixer7, 0);
    AudioConnection          patchCord28(envelope6, envelope3);
    AudioConnection          patchCord29(mixer1, 0, mixer5, 0);
    AudioConnection          patchCord30(envelope1, 0, mixer5, 1);
    AudioConnection          patchCord31(envelope4, bitcrusher1);
    AudioConnection          patchCord32(granular1, envelope5);
    AudioConnection          patchCord33(mixer4, 0, mixer8, 0);
    AudioConnection          patchCord34(mixer7, 0, mixer8, 1);
    AudioConnection          patchCord35(envelope3, amp1);
    AudioConnection          patchCord36(mixer5, 0, ladder1, 0);
    AudioConnection          patchCord37(mixer8, 0, mixerdist, 0);
    AudioConnection          patchCord38(mixer8, amp2);
    AudioConnection          patchCord39(envelope5, 0, mixer2, 0);
    AudioConnection          patchCord40(amp2, waveshape1);
    AudioConnection          patchCord41(bitcrusher1, 0, filter3, 0);
    AudioConnection          patchCord42(filterBass, 0, mixer3, 1);
    AudioConnection          patchCord43(amp1, 0, filterBass, 0);
    AudioConnection          patchCord44(ladder1, 0, mixer3, 0);
    AudioConnection          patchCord45(waveshape1, 0, mixerdist, 1);
    AudioConnection          patchCord46(mixerdist, 0, filter2, 0);
    AudioConnection          patchCord47(mixer3, 0, mixer6, 0);
    AudioConnection          patchCord48(filter3, 0, mixer3, 3);
    AudioConnection          patchCord49(filter2, 0, mixer3, 2);
    AudioConnection          patchCord50(mixer2, 0, mixer6, 1);
    AudioConnection          patchCord51(mixer6, 0, filter40, 0);
    AudioConnection          patchCord52(filter40, 2, usb1, 0);
    AudioConnection          patchCord53(filter40, 2, usb1, 1);
    short wave_type[16] = {
      WAVEFORM_SINE,
      WAVEFORM_SQUARE,
      WAVEFORM_SAWTOOTH,
      WAVEFORM_SAWTOOTH_REVERSE,
      WAVEFORM_TRIANGLE,
      WAVEFORM_TRIANGLE_VARIABLE,
       WAVEFORM_PULSE, //WAVEFORM_ARBITRARY,
      WAVEFORM_PULSE,
      WAVEFORM_SAWTOOTH,
      WAVEFORM_TRIANGLE,
      WAVEFORM_SINE,
      WAVEFORM_SQUARE,
      WAVEFORM_SAWTOOTH,
      WAVEFORM_TRIANGLE,
      WAVEFORM_SINE,
      WAVEFORM_SQUARE,
    #define GRANULAR_MEMORY_SIZE 51200  // enough for 290 ms at 44.1 kHz
    int16_t granularMemory[GRANULAR_MEMORY_SIZE];
    int lfo[8] = {0,0,0,0,0,0,0,0};
    int beat[4][32]={  {1,0,0,0,1,0,0,0,1,1,1,0,1,0,0,0,1,0,0,0,1,0,0,0,1,1,1,0,1,0,0,0  },
                       {0,0,1,0,0,0,1,0,0,0,1,0,0,1,0,0,0,0,1,0,0,0,1,0,0,0,1,0,0,1,0,0  } ,
                       {1,1,0,1,1,1,0,1,1,1,1,0,1,1,1,0,1,1,0,1,1,1,0,1,1,1,1,0,1,1,1,0  },
                       {0,0,1,0,0,0,1,0,0,0,1,1,0,0,0,1,0,0,1,0,0,0,1,0,0,0,1,1,0,0,0,1  }  };
    int fatBeat[32];
    int ara [8][8][8];
    int countBeat = 0;
    float bpm = 80 ;
    int world = 440;
    int exsetj = setj;
    int fader5 = 0;
    int fader8 = 0;
    int fader = 0;
    int BT1 = 0;
    int BT2 = 0;
    int currentVoice = 0;
    void myNoteOn(byte b1,byte b2, byte b3)
        if(b1 == 148 && b2 == 121)
          BT1 = 1;
              if(BT1 == 1 && BT2 == 1 && uOn == 1 )savePresets();
              else if(BT1 == 1 && BT2 == 1 && uOn == 0 )loadPresets();
              if(seti == 7 && flagRec == 0){flagRec = 2;  cleanMatrix();}
              else if(seti == 7 && flagRec == 3){flagRec = 4; cleanMatrix();}
              point(  seti, 4 , 1);
        else if(b1 == 148 && b2 == 122){
          BT2 = 1;
         if(seti == 7 )tapTempo();
         point( 0 , setj , 2);
          onNoteUlt(b2,b3);
          uOn = 1;
    void myNoteOff(byte b1,byte b2, byte b3)
        if(b1 == 132 && b2 == 121){
          BT1 = 0;
          if(seti == 7 && flagRec == 1){flagRec = 0; cleanMatrix();}
         else if(seti == 7 && flagRec == 2){flagRec = 3; cleanMatrix();}
          else if(seti == 7 && flagRec == 4){
            countBeat = 0; freqLive = millis();
            flagRec = 0;
          else if(seti == 7 && flagRec == 5){
            flagRec = 0;
            point(setk , 4 , 0);
        else if(b1 == 132 && b2 == 122){
          BT2 = 0;
            if(seti == 7 && tap > 3 ){
             freqClock1 = timeSeq;
             int msb = freqClock1 / 128;
             int lsb = freqClock1 - ( msb * 128);
             ara[7][7][6] = msb;
             ara[7][7][7] = lsb;
             bpm = 60 / ( freqClock1 / 1000 * 8 );
             Serial.print("BPM : ");
             Serial.println(bpm);
          if(seti > 5) drawFaderTrack();
          offNoteUlt(b1);
          uOn = 0;
    void myControlChange(byte b1,byte b2, byte b3)
      if( b2>127 || b3>127 )return;
        if(b1 == 180)
           if(b2 == 3){ ///////////////////////// FADER
            if(b3<12)b3 = 12;
            b3 = map(b3,12,127,0,127);
            fader = b3;
            fader8 = b3/16;
            fader5 = b3/27;
            int fadermod = b3 % 8;
            int okfad = 0;
            if( fadermod > 0 && fadermod < 7)okfad = 1;
                if( flagRec >= 3)flagRec = 3;
                else flagRec = 0;
            if(BT1 == 0 && BT2 == 0  && okfad == 1)
              setk = fader8;
            songNum = fader8;
            if(BT1 == 1 && BT2 == 0){
              if(uOn == 0 && okfad == 1 )//&& setk != fader8
                seti = fader8;
                point(seti , 4 , 1);
              if(seti != exfader8 && uOn == 0 ){
                 exfader8 = seti;
                 if(seti < 6)drawSet();
                 else cleanMatrix();
            if( BT1 == 0 && BT2 == 1)
            else if(b2 == 1)////////////ULTRASONYK
             if(b3 != 0 && b3 != 127)  lastCC = b3;
            if (BT1 == 1 && BT2 == 0)
            if(seti > 5 && uOn == 1)beatFader( b3 );
            else if(BT1 == 0 && BT2 == 1)
              if( uOn == 1 ) setj = 4 - ( b3/15 );
              if(setj < 0)setj = 0;
                   if(exsetj != setj)
                      envelope3.noteOff();
                      envelope2.noteOff();
                      envelope1.noteOff();
                      envelope4.noteOff();
                      envelope5.noteOff();
                      exsetj = setj;
              else if(BT1 == 0 && BT2 == 0)
                  if(setj == 2 && seti ==0 && uOn == 1)playGuit( b3);
                  else if(setj == 0 && seti ==0 && uOn == 1)beatFader( b3 );
                 // else if(setj == 0 && seti ==0 && uOn == 1)beatFader( b3 );
                  else if(seti > 5 && uOn == 1)beatFader( b3 );
            else if(b2 == 2)////////////VELO
               if(b3<63)dirU =-1;
               else dirU = 1;
            else if(b2 == 6)//////////// CC MSB
               msb = b3;
            else if(b2 == 7)//////////// CC MSB
               lsb = b3;
               int big = (msb * 128) + lsb;
               big = big * 2;
               if( big > 16482) big = 16482;
               int small = map(big , 0 , 16482 , 0 , 127 );
              if(seti < 5 && uOn == 1 && BT1 == 1 && BT2 == 0){
              ara[seti][setj][setk] = small;
              changeSet( seti, setj, setk, small);
              vBar(setk , small);
              point( setk , 4 , 0);
    void myBend(byte b1,byte b2, byte b3)
      int big = b2 + (b3 * 128);
      if( seti > 2)
       if(setj == 1)
        int hlf = big;
        int frq = map(hlf,0,16383,filtB/10,filtB + ((filtB/10)*9));
        if(frq < 40)frq = 40;
        filterBass.frequency(frq);
      Serial1.begin(31250);
      /////// BPM osc
    frqBpm4 = bpm * 8 / 60;
    freqClock1 = 1 / (bpm / 60) * 1000 / 8 / 16;
    /////float frqBpm6 = bpm * 6 / 60;
      filter40.frequency(40);
      filter40.resonance(0);
       if (!SD.begin(chipSelect)) {
        Serial.println("SD card failed !");
        return;
      Serial.println("SD card ready");
    waveform1.frequency(frqBpm4);
    waveform1.amplitude(1);
    /// KICK
      drum1.frequency(68);
      drum1.length(1120);
      drum1.secondMix(0.28);
      drum1.pitchMod(0.55);
      ///// SNARE
      drum2.frequency(167);
      drum2.length(130);
      drum2.secondMix(0.4);
      drum2.pitchMod(0.49);
       envelope2.attack(1.85);
       envelope2.hold(0.41);
       envelope2.decay(8.4);
       envelope2.sustain(0.2);
       envelope2.release(9.4);
      noise1.amplitude(0.3);
    /////  HH
      drum3.frequency(2540);
      drum3.length(9);
      drum3.secondMix(2.4);
      drum3.pitchMod(0.35);
      ///// clap
      pink1.amplitude(0.5);
       envelope1.attack(0.13);
       envelope1.hold(0.3);
       envelope1.decay(4.1);
       envelope1.sustain(0.00);
       envelope1.release(0.03);
    ////////////////7  BASSSSSSSSSSSSSSSSSSSSSS
       envelope3.attack(23.15);
       envelope3.hold(9.4);
       envelope3.decay(28.4);
       envelope3.sustain(0.33);
       envelope3.release(726.4);
      amp1.gain(0.7);
      filterBass.frequency(360);
      filterBass.resonance(4.2);
      sine1.frequency( 33 );
    waveformMod1.frequency(68);
      waveformMod1.amplitude(0.3);
    waveformMod2.begin(WAVEFORM_TRIANGLE);
    /////////  synth 1
       envelope4.attack(13.15);
       envelope4.hold(3.4);
       envelope4.decay(8.4);
       envelope4.sustain(0.33);
       envelope4.release(6.4);
       /////////////   syn1
       sine_fm3.frequency(954);
      sine_fm3.amplitude(0.2);
       /////////////   syn2 long
       sine_fm1.frequency(320);
       sine_fm1.amplitude(0.6);
        reverb1.reverbTime(0.3);
       envelope5.attack(43.15);
       envelope5.hold(9.4);
       envelope5.decay(28.4);
       envelope5.sustain(0.33);
       envelope5.release(1726.4);
      AudioMemory(20);
    granular1.begin(granularMemory, GRANULAR_MEMORY_SIZE);
      usbMIDI.begin();
      usbMIDI.setHandleNoteOff(myNoteOff);
      usbMIDI.setHandleNoteOn(myNoteOn);
      usbMIDI.setHandleControlChange(myControlChange) ;
      delay(200);
    initt();
    void loop()    ///LOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOP
      getMidiSerial();
      runIt();
      checkSnare();
    void checkSnare()
        int delta = millis()- cntSnare;
        if( delta > 50 && onSnare ){envelope2.noteOff(); onSnare = false; }
        delta = millis()- cntClap;
        if( delta > 50 && onClap ){envelope1.noteOff(); onClap = false; }
    void runIt()
       int dlt = millis() - freqLive;
       if( dlt >= freqClock1 )
       int modu = the8%16;
         if(modu == 0)
           runBeat();
       runBass();
       the8++;
       if( the8 > 511)the8 = 0;
    void runBeat()
    //  int  kk =0;
    //  if (peak1.available())
    //     kk = peak1.read() * 1000;
      if( trigBass ==1 || trigBass == 2 )
        envelope3.noteOn();
        envelope6.noteOn();
        if(trigBass == 2)trigBass = 3;
        else trigBass = 0;
        //cntArpBass = 0;
      else if(trigBass == 3)
        trigBass = 0;
          if( flagRec == 1 && faderBeat == 0){
            fatBeat[countBeat] = 0;
         if( seti < 5 && flagRec == 0)faderBeat = fatBeat[countBeat];
         else if( seti < 5 && flagRec == 3)faderBeat = faderBeat;
         else if( faderBeat !=0 )faderBeat = faderBeat;
         else if( flagRec == 0 )faderBeat = fatBeat[countBeat];
     if( seti > 5 && flagRec == 1)drawPoint(countBeat%8, countBeat / 8 , faderBeat);
           if(faderBeat == 1)
            drum1.noteOn();
           else if(faderBeat == 4)
            drum2.noteOn();
            envelope2.noteOn();
            onSnare = true;
            cntSnare = millis();
           else if(faderBeat == 3)
            drum3.noteOn();
           if(faderBeat == 2)
            envelope1.noteOn();
            onClap = true;
            cntClap = millis();
            countBeat++;
           if(countBeat >= 32){
           if(flagRec == 1)flagRec = 5;
             countBeat = 0;
      if(seti>5)
         int x = ( countBeat % 8 );
         int y = ( countBeat / 8 );
          if(flagRec != 1)
            if(flagRec == 0)drawPoint(x,y,5);
            int cnt = countBeat-1;
            if (cnt<0)cnt = 31;
             x = ( cnt % 8 );
             y = ( cnt / 8 );
             drawPoint(x,y,fatBeat[cnt]);
        faderBeat = 0;
    void runBass()
      if(seti <= 6 && setj == 1 ) // && uOn == 1
      int dt2 = ara[2][1][2] / 10;
      int ar[]= { 0,128,64,48,32,24,16,12,8,6,4,3,2}; // max 12.9
       int arpSpeed = ar[dt2];
    //  Serial.println( arpSpeed );
    //  if( countBass >= arpSpeed && arpSpeed > 0)
    //     countBass = 0;
    //      switch(cntArpBass) { // arpeggio bass
    //        case 0:
    //       if(ara[2][1][5]/11>0)
    //       waveformMod1.frequency( tune[ tuneB + (ara[2][1][5]/5)] );
    //       break;
    //       case 1:
    //       if(ara[2][1][6]/11>0)
    //       waveformMod1.frequency( tune[ tuneB + (ara[2][1][6]/5)] );
    //      break;
    //      case 2:
    //       if(ara[2][1][7]/11>0)
    //       waveformMod1.frequency( tune[ tuneB + (ara[2][1][7]/5)] );
    //      break;
    //    default:
    //      break;
    //       cntArpBass++;
    //       if(  cntArpBass > 2)cntArpBass = 0;
    //           envelope6.noteOn();
    //     if(dt2 == 4)envelope6.noteOff();
    void getCpu()
     // return;
        Serial.print("Proc = ");
        Serial.print(AudioProcessorUsage());
        Serial.print(" (");
        Serial.print(AudioProcessorUsageMax());
        Serial.print("),  Mem = ");
        Serial.print(AudioMemoryUsage());
        Serial.print(" (");
        Serial.print(AudioMemoryUsageMax());
        Serial.println(")");
    void changeSet( int i, int j, int k, int val)
      float flt = 0.0;
      int  mpx = 0;
       if(val < 0 || val > 127)return;
       if(i == 0)
           if(j == 0){
                switch(k) {
                    case 0: // VOL all drumz
                    flt =  map( val,0,127,0,1000 );
                    flt = flt / 1000;
                     mixer3.gain(0, flt);
                    case 1:
                     ladder1.frequency( map( val,0,127,100,12000 ) );
                    case 2:
                    flt = flt / 1000;
                     ladder1.resonance( flt );
                     case 3:
                    flt =  map( val,0,127,0,7000 );
                    flt = flt / 1000;
                     ladder1.octaveControl( flt );
                     case 4:
                    flt =  map( val,0,127,0,4000 );
                    flt = flt / 1000;
                     ladder1.inputDrive( flt );
                      case 5:
                    flt =  map( val,0,127,0,500 );
                    flt = flt / 1000;
                     ladder1.passbandGain( flt );
                    default:
           else if(j == 1){ /////BASS
               switch (k) {
                    case 0:
                     flt =  map( val,0,127,0,700 );
                     flt = flt/1000;
                     mixer3.gain(1, flt);
                    case 1:
                      if(val < 64)envelope3.attack( map(val,0,63,0, 50 ));
                    else envelope3.attack( map(val,64,127,50, 1400 ));
                    case 2:
                    if(val < 64)
                     envelope3.hold(0);
                     envelope3.decay(map(val,0,127,0, 100) );
                     envelope3.hold( map(val,0,127,100, 1200 ) );
                     envelope3.decay(map(val,0,127,100, 1200 ));
                    case 3:
                    flt =  map(val,0,127,0, 100 );
                    flt = flt / 100;
                     envelope3.sustain( flt );
                    case 4:
                     envelope3.release( map(val,0,127,0, 2600 ));
                    case 5:
                    mpx = val / 16;
                    waveformMod1.begin(wave_type[mpx] );
                    Serial.println(wave_type[mpx]);
                    case 6:
                     filterBass.frequency( map(val,0,127,0, 800 ));
                     filtB =  map(val,0,127,0, 800 );
                    case 7:
                    flt = map(val,0,127,70, 300 );
                    flt = flt/100;
                     filterBass.resonance( flt );
                    default:
                else if(j == 2){///GUITAR
               switch (k) {
                    case 0:
                     flt = flt/1000;
                     mixer3.gain(2, flt);
                    case 1:
                     flt = flt/1000;
                     veloGuit = flt;
                    case 2:
                     flt =  map( val,0,127,0,100 );
                     flt = flt/100;
                     if(val < 40){
                     mixerdist.gain(0, 0.66 + (flt / 1) );
                     mixerdist.gain(1, 0);}
                      else if(val <= 40 && val > 80){
                     mixerdist.gain(0, 1 - flt);
                     mixerdist.gain(1, flt);}
                      else{
                     mixerdist.gain(0, 0);
                     mixerdist.gain(1, flt/2);}
                    case 3:
                    for( int i=1; i < 4; i++)
                       flt = map( val,0,127,950,1000 );
                       arrDist[i] = flt/1000;
                       arrDist[8 - i] = -flt/1000;
                       flt = map( val,0,127,900,1000 );
                        flt = map( val,0,127,850,1000 );
                    case 4:
                     flt =  map( val,0,127,0,6000 );
                     flt = flt/1000;
                     amp2.gain(flt);
                    case 5:
                    flt = map(val,0,127,0, 700 );
                    flt = flt / 100;
                     filter2.octaveControl( flt);
                    case 6:
                     filter2.frequency( map(val,0,127,50, 2000 ));
                    case 7:
                    flt = map(val,0,127,70, 500 );
                    flt = flt / 100;
                     filter2.resonance( flt);
                    default:
                else if(j == 3){/// SYNTH arpg
               switch (k) {
                    case 0: // vol syn 1
                     flt =  map( val,0,127,0,1000 ) / 100;
                     flt = flt / 1000;
                     mixer3.gain(3, flt);
                    case 1:
                      if(val < 64)envelope4.attack( map(val,0,63,0, 200 ));
                    else envelope4.attack( map(val,64,127,200, 2400 ));
                      envelope4.hold(0);
                      envelope4.decay(0);
                       envelope4.sustain(1);
                    case 2:
                      envelope4.release( map(val,0,127,0, 4600 ));
                    case 3:
                       mpx = val / 16;
                    waveformMod2.begin(wave_type[mpx] );
                    case 4:
                      bitcrusher1.bits(map(val,0,127,16, 2 ));
                    case 5:
                      flt =  map(val,0,127,100, 360000 );
                      flt = flt / 400;
                      sine_fm3.frequency( flt);
                    case 6:
                     filter3.frequency( map(val,0,127,40, 2000 ));
                    case 7:
                     flt = flt/100;
                     filter3.resonance( flt);
                    default:
               else if(j == 4){///// synth nappe
               switch (k) {
                    case 0: // vol syn 3
                     flt = flt/1000;
                     mixer2.gain(0, flt);
                    case 1:
                      if(val < 64)envelope5.attack( map(val,0,63,0, 200 ));
                    else envelope5.attack( map(val,64,127,200, 2400 ));
                      envelope5.hold(0);
                      envelope5.decay(0);
                      envelope5.sustain(1);
                    case 2:
                      envelope5.release( map(val,0,127,0, 4600 ));
                      case 3:
                      flt =  map( val,0,127,100,300000 );
                      flt = flt / 1000;
                      sine_fm2.frequency( flt );
                    case 4:
                     flt = flt/1000;
                     sine_fm2.amplitude( flt );
                    case 5:
                     granular1.beginPitchShift( map(val,0,127,1, 95 ));
                    case 6:
                      flt =  map(val,2,127,125, 8000 );
                      flt = flt/1000;
                      granular1.setSpeed(flt);
                    case 7:
                      flt =  map(val,2,127,0, 1156 );
                      granular1.beginFreeze(flt);
                    default:
           else if(i == 1)// ALL DRUMZ
              if(j == 0){//   K I C K
               switch (k) {
                    case 0: //
                     flt = flt / 1000;
                     mixer1.gain(0, flt);
                    case 1:
                    drum1.frequency( map(val,0,127,20, 120));
                    case 2:
                     drum1.length( map( val,0,127,20,700 ));
                    case 3:
                     flt = flt / 1000;
                     drum1.secondMix( flt);
                     case 4:
                      flt =  map( val,0,127,1000,10 );
                     flt = flt / 1000;
                        drum1.pitchMod( flt );
                    default:
             else  if(j == 1){//   snare
               switch (k) {
                    case 0:
                     flt = flt / 1000;
                     mixer1.gain(1, flt);
                    case 1:
                    drum2.frequency( map(val,0,127,120, 250 ));
                    case 2:
                    drum2.length(map(val,0,127,15, 400 ));
                     envelope2.release( map(val,0,127,15, 400 ) );
                    case 3:
                     flt = flt / 1000;
                     drum2.secondMix( flt );
                     case 4:
                     flt = flt / 1000;
                      drum2.pitchMod( flt );
                    case 5:
                     flt = flt / 1000;
                     mixer1.gain(2, flt);
                      case 6:
                     envelope2.hold(0);
                     envelope2.delay(0);
                     envelope2.attack((val)*2);
                     envelope2.decay(val/2);
                     envelope2.hold(0);
                     case 7:
                     flt = flt / 1000;
                     envelope2.sustain( 0.32);
                    envelope2.release(val * 4 );
                    default:
             else  if(j == 2){//   HH
               switch (k) {
                    case 0:
                     flt = flt / 1000;
                     mixer1.gain(3, flt);
                    case 1:
                    drum3.frequency( map(val,0,127,800, 2800 ));
                    case 2:
                     drum3.length( map(val,0,127,1, 80 ));
                    case 3:
                     flt = flt / 1000;
                     drum3.secondMix( flt);
                     case 4:
                     flt =  map( val,0,127,800,20 );
                     flt = flt / 1000;
                      drum3.pitchMod( flt );
                    default:
             else  if(j == 3){//  clap
               switch (k) {
                    case 0:
                     flt = flt / 1000;
                     mixer5.gain(1, flt);
                    case 1:
                     flt = flt / 1000;
                    pink1.amplitude( flt );
                      case 2:
                     envelope1.hold(0);
                     envelope1.attack(val);
                     case 3:
                      envelope1.decay(val * 6  );
                     envelope1.sustain( 0.0 );
                     envelope1.release(0.0 );
                    default:
       else if(i == 2)// FX
          if(j == 1){ /////////      //////////        BASS 2   ////////////////////
               switch (k) {
                    case 0:
                    flt =  map(val,0,127,1, 25000 );
                    flt = flt / 100;
                     sine1.frequency(flt);
                    case 1:
                     flt = flt / 1000;
                     sine1.amplitude(flt);
                    case 2:
                    //////  X 1 - 8 arpegio
                     case 3:
                     envelope6.hold(val/2);
                     envelope6.attack(val );
                     case 4:
                      envelope6.decay( 0  );
                     envelope6.sustain( 1.0 );
                     envelope6.release( val );
                    case 5:
                    case 6:
                    case 7:
                    default:
     else if(i == 3)// LFO
              if(j == 0){
               switch (k) {
                    case 0:
                     lfo1.frequency(map( val,0,127,0.044,world));
                    default:
             else if(j == 1){
               switch (k) {
                    case 0:
                     lfo2.frequency(map( val,0,127,0.044,world));
                    default:
             else if(j == 2){
               switch (k) {
                    case 0:
                     lfo3.frequency(map( val,0,127,0.044,world));
                    default:
             else if(j == 3){
               switch (k) {
                    case 0:
                     lfo4.frequency(map( val,0,127,0.044,world));
                    default:
           else if(i== 7)
              if(j ==7)
                if(k == 7)
                  freqClock1 = (( ara[7][7][6] * 128 ) + val ) / 16 ;
                  bpm = 60 / ( freqClock1  * 8 / 1000) / 8 ;
                  Serial.println(freqClock1);
    void initt()
    filterBass.octaveControl(6);
    filter2.octaveControl(2.5);
      waveformMod1.amplitude(0.99);
    waveformMod1.begin(WAVEFORM_SINE);
    amp1.gain(0.5);
    mixer8.gain(0,1);
    mixer8.gain(1,0.5);
    waveshape1.shape(arrDist , 9  );
       waveformMod2.frequency(598);
      waveformMod2.amplitude(1);
      delay(80);
      loadPresets();
    void loadPresets()
    int cni = 0;
    int cnj = 0;
    int cnk = 0;
    int cnt =0;
    File myFile;
    String track = "track-"+ String(songNum) + ".mdx";
      myFile = SD.open( track.c_str() );
      if (myFile) {
        while (myFile.available()) {
     switch ((char)myFile.peek()) {
          case ',':
          myFile.read();
          case '\r':
          myFile.read();
          default:
          int newV = myFile.parseInt();
       if(cni <= 7){
          ara[cni][cnj][cnk]   = newV;
        changeSet( cni, cnj, cnk, newV);
       else {
        fatBeat[cnt] = newV;
        cnt++;
          cnk++;
          if(cnk == 8){cnk=0; cnj++;}//Serial.println(" " );
          if(cnj == 8){cnj=0; cni++; }//Serial.println(" " ); Serial.println(" " );
        Serial.print(track);
        Serial.println(" loaded");
        myFile.close();
      else {
        Serial.println("error loading song on SD");
        songNum = 0;
        loadPresets();
    void savePresets()
      String allSet = "";
      for( int i=0; i< 8; i++)
        for( int j=0; j<8;j++)
          for( int k=0; k<8;k++)
             int val = ara[i][j][k];
             allSet = allSet + val + ",";
      for( int i=0; i< 32; i++)
        int val = fatBeat[i];
        if( i == 31 )allSet = allSet + val;
        else allSet = allSet + val + ",";
      delay(50);
    String track = "track-"+ String(songNum)+".mdx";
       SD.remove( track.c_str());
       File myFile = SD.open( track.c_str() , FILE_WRITE);
          if (myFile) {
         myFile.println(allSet);
         myFile.close();
         Serial.println( track+ " saved on SD");
         Serial.println("ERROR saving on SD");
       allSet ="";
    void getMidiSerial()
    byte b1;
    byte b2;
    byte b3;
     do{
        if (Serial1.available()){
      b1=Serial1.read();
      while (b1 == 255) b1=Serial1.read();
       b2=Serial1.read();
      while (b2 == 255) b2=Serial1.read();
       b3=Serial1.read();
      while (b3 == 255) b3=Serial1.read();
    if(b1>= 144 && b1 < 160)myNoteOn(b1,b2,b3);
    else if(b1>= 128 && b1 < 144)myNoteOff(b1,b2,b3);
    else if(b1>= 176 && b1 < 192)myControlChange(b1,b2,b3);
    else if(b1>= 224 && b1 < 240)myBend(b1,b2,b3);
      while (Serial1.available() > 2);
    void playGuit( byte b3)
      int delta = (startCC - b3)/8;
      if(delta == exDeltaG)return;
      else exDeltaG = delta;
      if(delta == 7) okChord[0] =1;
      else if(delta == 6) okChord[1] =1;
      else if(delta == 5 && okChord[0] ==1 )
        okChord[2] =1;
        okChord[0] =0;
       if(startUltra <= 49 )  string6.noteOn( tune[startUltra + chord[1][5] ], veloGuit );
      else if(delta == 4 && okChord[1] ==1 )
           okChord[3] =1;
           okChord[1] =0;
        if(startUltra <= 44 ) string5.noteOn( tune[startUltra + chord[1][4] ], veloGuit);
      else if(delta == 3 && okChord[2] ==1 )
        okChord[0] =1;
        okChord[4] =1;
        okChord[2] =0;
         string4.noteOn( tune[startUltra + chord[1][3] ], veloGuit);
      else if(delta ==  2 && okChord[3] ==1 )
        okChord[1] =1;
        okChord[5] =1;
         okChord[3] =0;
         string3.noteOn( tune[startUltra + chord[1][2] ], veloGuit);
      else if(delta ==  1 && okChord[4] ==1 )
         okChord[2]=1;
         okChord[6]=1;
         okChord[4] =0;
         string2.noteOn( tune[startUltra +chord[1][1]] ,veloGuit);
      else if(delta ==  0 &&  okChord[5] ==1 )
         okChord[3]=1;
         okChord[7] =1;
         okChord[5] =0;
         string1.noteOn( tune[startUltra +chord[1][0]] , veloGuit);
      else if(delta ==  -1 && okChord[6] ==1 )
         okChord[4]=1;
         okChord[8] =1;
         okChord[6] =0;
         string2.noteOn( tune[startUltra + chord[1][1] ], veloGuit);
      else if(delta ==  -2 && okChord[7] ==1 )
         okChord[5]=1;
         okChord[9] =1;
         okChord[7] =0;
         string3.noteOn( tune[startUltra + chord[1][2]] , veloGuit);
      else if(delta ==  -3 && okChord[8] ==1 )
         okChord[6]=1;
         okChord[10] =1;
          okChord[8] =0;
         string4.noteOn( tune[startUltra +  chord[1][3]] , veloGuit);
      else if(delta ==  -4 && okChord[9] ==1 )
         okChord[7]=1;
         okChord[9] =0;
         if(startUltra <= 44 )string5.noteOn( tune[startUltra + chord[1][4]] , veloGuit);
      else if(delta ==  -5 && okChord[10] ==1 )
         okChord[8]=1;
          okChord[10] =0;
         if(startUltra <= 49 )string6.noteOn( tune[startUltra +  chord[1][5]] , veloGuit);
     else if(delta == -6) okChord[9] =1;
     else if(delta == -7) okChord[10] =1;
    void onNoteUlt(byte nt , byte vl  )
     if(BT1 == 1 || BT2 == 1)return;
    if(seti == 0)//////////////77 SET 0
      if(setj == 0)
        armDrum[0]=0;
        armDrum[1]=0;
        armDrum[2]=0;
        armDrum[3]=0;
        armDrum[4]=0;
       else if(setj == 1)
             if(nt>11)nt = 11;
             nt =nt/3;
             nt = chr[nt] + 24;
           waveformMod1.frequency( tune[nt] );
           tuneB = nt;
           trigBass = 1;
      else if(setj == 2)
       if(nt>11)nt = 11;
      nt =nt/3;
          startCC = lastCC;
          startDir = dirU;
          nt = chr[nt] + 36;
          startUltra = nt;
          float flt = vl;
          flt = flt / 400;
          string1.noteOn( tune[nt + 0 ], veloGuit );
         okChord[0] = 1;
         okChord[1] = 1;
            okChord[2] = 1;
               okChord[3] = 1;
                  okChord[4] = 1;
                     okChord[5] = 0;
                        okChord[6] = 1;
                        okChord[7] = 1;
                        okChord[8] = 1;
                        okChord[9] = 1;
                        okChord[10] = 1;
                        okChord[11] = 1;
        deltaTG = millis();
        else if(setj == 3)
         if(nt>11)nt = 11;
           nt =nt/3;
            nt = chr[nt] + 48;
           waveformMod2.frequency(tune[nt]);
             envelope4.noteOn();
        else if(setj == 4)
         if(nt>11)nt = 11;
           nt =nt/3;
            nt = chr[nt] + 48;
           sine_fm1.frequency(tune[nt]);
             envelope5.noteOn();
    else if(seti == 1) //////////SET 1
       if(nt>11)nt = 11;
         nt = nt/3;
       nt = setj;
       if(nt >3)nt=3;
       if( nt == 0)drum1.noteOn();
       else if( nt == 1)
        drum2.noteOn();
        envelope2.noteOn();
        onSnare = true;
       else if( nt == 2)drum3.noteOn();
       else if( nt == 3)
        envelope1.noteOn();
        onClap = true;
        cntClap = millis();
     else if(seti >= 2 && seti <= 5 )
        if(setj == 1)
          if(nt>17)nt = 17;
          nt =nt/3;
          nt = chrb[nt] + 24;
            tuneB = nt;
           trigBass = 1;
     else if(seti > 5  || (seti == 0 && setj == 0 ))
     exBeatfader = 99;
        armDrum[0]=0;
        armDrum[1]=0;
        armDrum[2]=0;
        armDrum[3]=0;
        armDrum[3]=0;
    void offNoteUlt(byte b1)
       if(setj == 0  || seti==1)
       if(setj == 1 )
        if( trigBass == 0 )
        else if ( trigBass == 1 )
        trigBass = 2;
      else if(setj == 2)
       // envelope1.noteOff();
      else if(setj == 3)
      else if(setj == 4)
      if(( seti > 5 && flagRec == 0) || (seti == 0 && setj == 0 ) )
          exBeatfader = 99;
        armDrum[0]=0;
        armDrum[1]=0;
        armDrum[2]=0;
        armDrum[3]=0;
        armDrum[3]=0;
      if( seti > 5  )cleanMatrix();
    void beatFader( int nt)
         nt = nt/2;
         if(nt>16)nt=16;
      int delta = -1;
      if(nt != exBeatfader)
         delta = nt - exBeatfader;
        int vl = nt * 7.8;
      if(( seti > 5 && flagRec == 3 ) ||( seti > 5 && flagRec == 0 ) )
     vBar( 3 ,vl );
     vBar( 4 ,vl );
      exBeatfader = nt;
       if( nt == 0 && armDrum[0]==0)
        armDrum[0]=1;
        faderBeat = 1;
        if(flagRec == 2  || flagRec == 4  ){  countBeat = 0; freqLive = millis(); flagRec = 1;}
        if( flagRec == 1 ){
          fatBeat[countBeat] = faderBeat;
       else if( nt == 3  || nt == 2 )
        armDrum[0]=0;
        armDrum[1]=0;
       else if( nt == 5 && armDrum[1]==0 && delta > 0 )
        armDrum[1]=1;
        if(faderBeat == 0){
          faderBeat = 2;
          if(BT1 == 1 && flagRec == 1 ){
             armDrum[4]=0;
        else if( nt == 7 &&  armDrum[4]==0)
        armDrum[4]=1;
        armDrum[1]=0;
        armDrum[2]=0;
    //    drum3.noteOn();
        faderBeat = 3;
       else if( nt >= 9 && nt < 11 && armDrum[2]==0)
       if(faderBeat == 0) {
        faderBeat = 2;
        armDrum[2]=1;
        armDrum[3]=0;
        else if( nt == 11 || nt == 12)
        armDrum[2]=0;
          armDrum[4]=0;
       else if( nt >= 13  && armDrum[3]==0)
        armDrum[3]=1;
        faderBeat = 4;
       if(BT2 == 1 && seti > 5)
       flagKick = 0;
       else if( nt == 14   || nt == 15 )
       else if( nt >= 16 )
    void prepRec()
      for( int i=0; i< 4; i++)
        for( int j=0; j< 16 ;j++)
           beat[i][j] =  0;
    void drawPoint(int x, int y, int z )
             Serial1.write(191);
             Serial1.write(0);
             Serial1.write(x);
             Serial1.write(191);
             Serial1.write(1);
             Serial1.write(y);
             Serial1.write(191);
             Serial1.write(2);
             Serial1.write(r[z] );
              Serial1.write(191);
             Serial1.write(3);
             Serial1.write( g[z] );
              Serial1.write(191);
             Serial1.write(4);
             Serial1.write( b[z] );
              Serial1.write(191);
             Serial1.write(6);
             Serial1.write(0);
    void blinkPoint()
      return;
    int cnt =countBeat - 1;
     if(cnt < 0 )cnt=31;
             Serial1.write(191);
             Serial1.write(0);
             Serial1.write(0+(countBeat%8));
             Serial1.write(191);
             Serial1.write(1);
             Serial1.write(0+(countBeat/8));
             Serial1.write(191);
             Serial1.write(2);
             Serial1.write(120);
              Serial1.write(191);
             Serial1.write(3);
             Serial1.write( 100);
              Serial1.write(191);
             Serial1.write(4);
             Serial1.write(191);
             Serial1.write(6);
             Serial1.write(1);
    drawPoint(  cnt%8 , cnt/8 , fatBeat[cnt] );
    void cleanMatrix()
             Serial1.write(143);
             Serial1.write(1);
             Serial1.write(1);
    void drawFaderTrack()
    //      for( int i=0; i < 7; i++)
    //        drawPoint( i%8 , i/8  , fatBeat[i] );
    void point(int x, int y, int z )
       x = x+1;
       y = y + 1;
             Serial1.write(191);
             Serial1.write(0);
             Serial1.write(x);
             Serial1.write(191);
             Serial1.write(1);
             Serial1.write(y);
             Serial1.write(191);
             Serial1.write(5);
             Serial1.write(z);
    void vBar( int x, int vl )
        Serial1.write(191);
        Serial1.write(0);
        Serial1.write(x+ 1);
        Serial1.write(191);
        Serial1.write(7);
        Serial1.write(vl);
    void tapTempo()
        int dlt = millis() - timeKick;
        if(dlt > 4400 || dlt < 44 )
            timeKick = millis();
            tap = 1;
        else  if(tap == 1 ){
           time1T = millis() - timeKick;
           tap++;
        else if( tap > 1 )
               time1T = ((millis() - timeKick)+ time1T ) / 2;
               frqBpm4 = 8000 / time1T ;
               bpm = 60000 / time1T ;
               Serial.print("BPM ");
               timeSeq = time1T /8;
                   tap++;
    void drawSet()
             vBar( i , ara[seti][setj][i] );
    16,863
    WHat version of TeensyDuino is in use?
    To p#1 added # from the toolbar marker to keep code formatting and make it readable.
    Dec 2022
    4
    Teensyduino is 1.57
    i don't understand the p#1 from toolbar marker sorry
    Dec 2022
    4
    I manage to add variables so trying to finish my code.
    I think there was too much audio nodes, so i removed the last one and it compile and work now, i use optimize:fast
    16,863
    The Post toolbar has a "#" that puts [C0DE] text here [/C0DE] around selected text or to paste between {here replaced 'O' with zero '0' so it won't convert.
    Image is:Click image for larger version.
    1,911
    Your code compiled for me when I set the USB type to "Serial + MIDI + Audio".
    Sketch uses 116360 bytes (11%) of program storage space. Maximum is 1048576 bytes.
    Global variables use 175476 bytes (66%) of dynamic memory, leaving 86668 bytes for local variables. Maximum is 262144 bytes.
    You aren't reading Serial1 properly in getMidiSerial() and also not decoding the MIDI messages correctly.
    The do loop which reads the messages will only work correctly if the only kind of MIDI message received consists of three bytes. If any other kind of message is received, e.g. a Program Change (which is 2 bytes) or an Active Sense (which is one byte), then your code will get out of sync with the messages and won't be able to decode them, nor will it be easy to get back in sync.
    The first byte of a command always has the high order bit set to one, and any following data bytes always have the high-order bit set to zero. That allows you to stay in sync with the commands no matter what they are.
    I'd also suggest that you change this:
    to this:
          while (Serial1.available() < 1);
    and do the same for the other two occurrences.
    Pete
