I put up a gist here: https://gist.github.com/MikahB/67d3e00dac024b8a83895423a229e1be
I'm working my way (relatively slowly) towards a user-configurable input (in the form of mechanical buttons and voltage-generating things) to output (in the form of PWM DC output drivers) control system. I've made myself a list of bits of functionality to tick off one by one, so the overall structure is a bit of a mess, but still very much in the "make this step work" phase.
I've run into something that I can't quite get my head around. In the gist, I've commented out (lines 46, 50, and 54) three `analogWrite` instructions that simply drive the onboard LED at different duty cycles. Because Pin13 is an available PWM pin, I expect that should be fine. But, if I run any `analogWrite` on Pin13, I never get another response from my Bounce2 button objects - they never see any state switching events after that point. But with those 3 lines cancelled out, things work exactly like I'd expect.
I'm struggling to understand what could be the possible relationship between PWM on Pin13 and never getting high/low on Pin2 (my button pin for now) again. Is the program just stopping as soon as I do an analog write? If so, why? Is the program NOT stopping but somehow the button object becomes decoupled from the pin it's attached to?
Appreciate any thoughts and guidance!
Edit1: Added inline code also
Edit2: It seems that the problem, more specifically, is mixing `digitalWrite` and `analogWrite` on the same Pin13. If I convert the "off" state to `analogWrite(13,0)`, then the other analog writes work fine, but none of the Blinks work (which are all `digitalWrite`)
#include <Arduino.h>
#include <Bounce2.h>
#include <EEPROM.h>
// input states
enum inputState{off, low, medium, high, reset};
// input actions
enum inputAction {shortPress, longPress};
// Pin 13 has an onboard LED on the Teensy 4.1
int outputPins[] = {13};
int inputPins[] = {2};
constexpr int bounceTime = 20;
constexpr u_int16_t INPUT0_LASTVAL = 1000;
Button buttons[1];
inputState CurrentInputState;
// this indicates what mode we're starting in
// todo: non-blocking
void Blink(int numBlinks, int timeVal = 100) {
if (numBlinks <= 0) {return;}
for (int i = 0; i < numBlinks; i++) {
digitalWrite(13, LOW);
delay(10);
digitalWrite(13, HIGH);
delay(timeVal);
delay(timeVal);
// this actually sets the output
// note: need to fix terminology between input and output states
void SetOutputState(inputState newState, int outputNumber = 0) {
CurrentInputState = newState;
switch (newState)
case off:
digitalWrite(outputPins[outputNumber], LOW);
return; // explicitly, without changing last state
case low:
Blink(1);
//analogWrite(outputPins[outputNumber], 128);
case medium:
Blink(2);
analogWrite(outputPins[outputNumber], 192);
case high:
Blink(3);
//analogWrite(outputPins[outputNumber], 256);
// if we didn't turn it off, store this value for later
EEPROM.write(INPUT0_LASTVAL, newState);
// this runs the state machine
void UpdateInputState(inputAction action) {
// if it's off, just turn on to previous setting
if (CurrentInputState == off) {
inputState lastSetting = static_cast<inputState>(EEPROM.read(INPUT0_LASTVAL));
SetOutputState(lastSetting);
// if it's NOT off, figure out what to do based on action
else {
if (action == shortPress) {
SetOutputState(off);
else {
// yuck - cast both ways to increment
inputState nextState = static_cast<inputState>(static_cast<int>(CurrentInputState) + 1);
if (nextState == reset) nextState = low; // if we're cycling off off high, go back to low
SetOutputState(nextState);
// set pwm frequency
analogWriteFrequency(13, 1000);
// initialize the output pins
for (int oPin: outputPins)
pinMode(oPin, OUTPUT);
// little different iterate since we need pin# and location
for (uint16_t i = 0; i < (sizeof(inputPins) / sizeof(inputPins[0])); i++) {
int pinNumber = inputPins[i];
pinMode(pinNumber, INPUT_PULLDOWN); // pull low to not float
buttons[i].attach(pinNumber);
buttons[i].interval(bounceTime);
buttons[i].setPressedState(HIGH); // when pin goes high, btn is pressed
buttons[0].update();
if (buttons[0].fell())
//Blink(4);
if (buttons[0].previousDuration() > 1000)
UpdateInputState(longPress);
UpdateInputState(shortPress);
